Question about Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop
Wont recognize additional ram
I added a 256 meg DDR ram chip in open ram bay,,computer wont recognize it,,I swapped chips,,putting new chip in first bay,,computer booted great,,swapped chips around,,still,not recognizing second ram chip,,am i doing something wrong,,went to crucial,,ran their scan,,it doesnt see the extra ram either,,thanks,,any help is appreciated.
  • banjer23 Dec 20, 2007
    yea,,same brand,,I pulled it from my HP which is very close to this Compaq,,but,,motherboard,,evidently doesnt like it.
  • Anonymous Mar 27, 2014
    THE PROBLEM IS POSSIBLY VERY COMPLICITED BUT, I JUST NEED TO KNOW FOR NOW WHICH CONNECTOR ON THE MOTHERBOARD IS THE CORRECT ONE FOR THE PROCESSOR FAN? ALSO, JUST OUT OF CURIOSITY: SILKSCREENING ON THE BOARD REFERS TO A "JP6" TO ENABLE OR DISABLE THE ONBOARD SOUND CHIP BUT I SEE NO JP6. THERE IS A JP8 BUT LOOKS LIKE IT'S FOR SOMETHING ELSE. I LOVE THIS COMPUTER AND GREATLY APPRECIATE ANY HELP. DENNIS
  • 37 Answers
It could be the wrong ram that u are using when i put extra ram in I make sure they are all the same brand. some boards take 2 different types of ram (speeds) i would go back to crucial with your good ram in and then do a check and see what ram your board needs
Posted on Dec 20, 2007
Where can I get DDR RAM for my old PC?
You can buy them new or used on E-bay also I have seen them in my local cash convertors and Cex shop.
Mar 27, 2017 | Chips Computers & Internet
INSTALLED NEW RAM UPGRADE TO BOOST FROM 1G TO 2G COMPUTER DOES NOT RECOGNIZE NEW RAM STILL SHOWS 1G.
Make sure it is the correct ram for your computer. If you just added one ram chip then try swapping them and make sure they have a tight fit.
To test the new chip replace the old one with it and turn on your machine. If it doesn't see it then it is either bad or not the correct one.
Let me know how it goes.
Dec 14, 2010 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
Adding memory, new total not recognized: IBM Thinkpad R51e-1844
Ram should always be paired. Same type, speed and size in each slot. You may have 1 SIMM/DIMM/DDR that has 2 sides of chips and the other with 1 which will do exactly what you state. RAM reads across the chips simultaneously. So if you have a different one in each slot it can go bonkers and do goofy stuff on you.
Jun 14, 2009 | IBM ThinkPad R51 Notebook
Toshiba Satellite Pro M15-S405 Memory upgrade problem
This usually happens when the laptop is not able to take more then a certain amount of memory, as the system BIOS does not support higher. By saying ACPI as the blue screen, that tells me that the power subsystem does not 'like' having more then 512MB of RAM. I am 95% sure this is your BIOS because of that information. Check and see if you can find a BIOS upgrade for your computer model, and that might fix the issue, if an update is available.
Jan 21, 2009 | Toshiba Satellite Pro M15-S405 Notebook
Computer wont boot after memory upgrade
when working on computers you have to be carefull to ground your self before touching the inside of them. when installing memory you dont need to unpluge everythinf just the main power cord on the back of it.the blinking green light means you have something no pluged in right,double check everything you unpluged make sure it back in the right areas.on memory the slots are mark 1,2,3,4
make sure if the memory is diffrent in speeds the lagger ons go first.the first to slots normally have to be the same speed and size ram.if that does not work let me know i can look into it for you.
Dec 15, 2008 | ASUS P5RD1-VM Motherboard
Adding ram
Supported RAM TechnologyDDR SDRAMRAM Installed ( Max )0 MB / 2 GB (max)Supported RAM SpeedPC2100, PC1600, PC2700The above is the specification for RAM for your M/board
It can take up to 2Gb ram 2 X 1GB sticks you may have to change BIOS settings aand your computer will definitely run fasterPlease give me a FIXYA
Sep 13, 2008 | MSI KM4M-V KM400 SocketA 333FSB 2DDR...
Weird (?) RAM problems (screenshot included)
First of all, make sure the ram are identical, becuase having 3 different random access memory chips in the computer can cause problems. Also make sure the ram chip is sitting in there properly. Next you should check under start go to run and type in "dxdiag".See how much memory it reports the computer has. If it reports 700etc mb,, then the one memory chip might be faulty. Also, check with the system manufacturuer, and make sure you're not overclocking the computer. Overclocking is when you put too much memory in a computer and it doesnt recognize one of the chips. 700etc mb might be the maximum your computer can handle.
Jul 17, 2008 | Computers & Internet
Sdram capacity
its that 512 mb total capacity for your computer memory?? if so read this:
To find the total amount of RAM that can be added , subtract the amount of RAM currently in the computer from the maximum amount of memory the computer can hold. For example, a computer has 256 MB of RAM. If the maximum amount of memory the computer can hold is 512 MB, then 256 MB is the amount of RAM that can be added. this info from the HP website , to find out more , go to http://www.hp.com/support , enter the model number , and look for more information about your computer specs, hope this helps , please rate & thanks AJ
May 24, 2008 | HP Pavilion 8860 (P2941A) PC Desktop
Monitor wont turn on after upgraded memory to 512 from 256
theres a driver conplict, run device manager and remove auknown device. restart the computer
Mar 11, 2008 | Computers & Internet
Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop Logo
132 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
