Question about Dell (E210882) Motherboard
Want to upgrade my ram.
What is the maximum I can put in? e210882 motherboard
  • adhocltd Feb 05, 2008
    I am trying to upgrade a Dimension 1100 with the e210882 motherboard. am about to purchase 2*1gb memory sticks:-
    GB PC3200 DDR 400 RAM 400Mhz 2x 1GB 2 GB G DIMM MEMORY
    Specifications:2GB (1GB x2 KIT) 400MHZ 184PIN DDR Memory, No-ECC. Higher performance over mainstream PC100 or PC133 memory. Up to 3.2 GB/sec of peak bandwidth using PC3200 DIMMs (with DDR400 memory chips). JEDEC Standard. 184 pin DIMM, non-ECC. DIMM Lead pitch: 1.27 mm. 2.5 Volts. SSTL-2 I/O Interface. SPD Support. Support for Memory Chip Stacking.
    Apparently this memory is high density. Does anyone know if this memory will work on this motherboard?????
    Many thanks for all help.
    Genius:
  • 1,601 Answers
Support for up to 4 GB DDR-2 of system memory.
Posted on Dec 20, 2007
I NEED RAM FOR MB 210882
This is the specs for the RAM you require.
Memory
The Dell E210882 system board is compatible with PC2-3200 (400MHz) or PC2-4300 (533MHz) DDR2 non-ECC and unbuffered SDRAM. The motherboard has four slots for memory. Compatible capacities include: 128MB, 256MB, 512MB or 1GB. The maximum installable RAM is 4GB.
Google search the Internet for this RAM
Sep 20, 2012 | Intel Motherboard
What ram to use
The Dell E210882 system board is compatible with PC2-3200 (400 MHz) or PC2-4300 (533 MHz) DDR2 non-ECC and unbuffered SDRAM. The motherboard has four slots for memory. Capacities compatible include: 128 MB, 256 MB, 512 MB or 1GB. The maximum installable RAM is 4 GB.
Sep 29, 2011 | Dell (E210882) Motherboard
What is the max memory that i can install on an intel motherboard e210882
let me know if it helps you : ) replay to me as soon as you solve your problem : )
Sep 15, 2011 | Intel Motherboard
No display even if i upgraded my ram,and my video card.please help me
flash the CMOS and remove the battery and put it back again.. put the CMOS jumper in 2-3 settings.. after 5sec put it back again in 1-2 settings.
Jul 04, 2011 | Dell (E210882) Motherboard
How much ram will a e210882 mother board support
this is likely a dell dimension 3000 mob, and should hold a maximum 2GB ram at maximum 400Mhz Front side bus speed
Nov 07, 2009 | Dell (E210882) Motherboard
Will dell motherboard support a sata 320gb hard
yes it will and make sure that your system has minimum of 1 gb ram ,this configuration will actually make your system run faster and in full throttle mode
so leave all your worries and upgrade to 320
kindly rate this solution
thanks and regards
Oct 31, 2009 | Dell (E210882) Motherboard
Maximum ram capacity for the board
You can look it up at this site: http://support.intel.com/support/motherboards/desktop/d865gvhz/sb/cs-010872.htm
but I believe it will be max. 2 GB per slot(DIMM)'s, so depending on the no. of slots on your MB x 2 will be the max. RAM capacity................sodeep
Jul 26, 2009 | Intel Motherboard
RAM for Intel E210882 mboard
This are the compatible RAM for this mobo :Support for DDR 400, DDR 333, and DDR 266 and you can upgrade up to 4GIG or RAM this is the complete specs for this mobo http://www.gearxs.com/gearxs/product_info.php?products_id=8076
Hope that helps..........
Sep 10, 2008 | Intel Motherboard
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
Dell (E210882) Motherboard Logo
183 people viewed this question
Clive
Clive
Alun Cox
