Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
When i try to use my scanner it comes up with 'scanner not ready'
Scanner is not ready. (Power may have been cycled.)
unplug it for 10 minutes and try again.
Apr 06, 2015 | Fujitsu fi6670
Canon MX892 - when I scan, an error code 2156 comes up saying scanner is turned off or usb cable unplugged
Hi.
Try to check up first scanner power cable and network wireless router.
If it are running running good. your scanner have defective parts. like
IC chipset.
Second option : try to general cleaning your Canon PIXMA MX892 Network-Ready Wireless All-In-One Printer. using vacuum.
Hope can help you.
Sep 15, 2012 | Canon PIXMA MX892 Network-Ready Wireless...
I have just upgraded to windows 7 and cannot install my scanoscan Lide 20/30 flatbed scanner
I have repaired Canon scanners for many years so here is my suggestion for you.
Canon like all vendors was not ready for Windows 7. I would google Canon CanoScan LIDE 30 drivers. Im sure there up to speed by now and probably have new drivers avalible for your scanner. Make sure you download the drivers from Canon's official website. Once the new drivers are downloaded disconnect your scanner cable from your computer. Now install the new drivers you just downloaded. Once the new drivers are installed, with your scanner powered on reconnect the cable that comes from the scanner to your computer. A pop up window should come up saying new drivers are being installed. Once that process completes I would suggest you reboot your computer and you now should be ready to scan.
I hope this helps you out.
Mar 14, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
I have umax 4700 scanner. When I tried to scan something it shows "scanner lamp has not warm up yet" & keep counting upto 30 seconds. It will take 4 to five time this exercise than it's ready...
hi rakyansfi,
Is that scanner old?because lamp has its own life span.
it cannot scan if the lamp is insufficient power or light.
regards,
mastergani
Dec 30, 2010 | Umax Astra 6700 Flatbed Scanner
My screen comes up with the Insfficient memory
it could be ether hardware or software problem. try installing the scanner on a friends computer and see if it does the same thing. if it does then your scanner if faulty, if not then try uninstalling you scanner drivers restart your computer and go to http://www.mustek.com.tw/Download/driv_scanr/europe/b4800tapro.html
to download the new drivers to reinstall.
Aug 18, 2009 | Mustek Bear Paw 4800 TA Pro Flatbed...
Scanner won't communicate with computer
Try this,
Go to Control Panel >> Device Manager, look for the scanner in 'Device Manager' under 'Imaging Devices'
Right click on it and select 'Uninstall' and allow it to be uninstalled.
Remove the USB lead from the scanner.
Re-boot the Computer.
Once windows appears and is ready toi use, re-connect the scanner USB lead.
Windows should re-install the drivers and tell you the scanner is ready to use................hopefully!
Mar 25, 2009 | Canon CanoScan 4400f MultiFunction Color...
Sanner
TWAIN Driver and EPSON Scan Utility v3.04A
http://www.epson.com/
Hi, try this version just visit epson web site to download scanner driver.
Jan 13, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Microtek Scanmaker 9800 XL
JKL Components was able to create a new bulb for me. Worked perfectly. Call Larry: 818-896-0019 ext 124. Very nice, and very helpful
Sep 12, 2007 | Microtek ScanMaker 9800XL Flatbed Scanner
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
37 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
