Question about Sony DCR-HC26 Mini DV Digital Camcorder
Touchscreen won't work. I can go into the calibration mode and move the x around the screen. But, I never get out of calibration mode. It just sits there flashing the x.
  • nke003 Jul 08, 2010
    Same exact problem here! Still can't find solution. Has else found a fix yet?
I'm having the same problem, my camcorder gave up on me on Christmas day. I can also access the calibration mode and move the x around but that is it.
ANY HELP PLEASE!!!!!!!!
Posted on Dec 26, 2009
Touch screen not responsive after speaker replacement It worked before speaker replacement.
To calibrate the touchscreen on a nuvi 300 or 600 series:
1. Power the unit On.
2. From the Where to? / View map screen, touch Settings (wrench icon).
3. Touch Display.
4. Touch Recalibrate.
5. A new screen will display that says Press Dot.
6. Touch the center of the dot.
7. Keep touching the center of the dot as it moves around the screen.
8. When Calibration Complete appears on the screen, please touch OK.
The touch-screen will now be recalibrated.
Nov 04, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
My garmin nuvi 660 touch screen dosen't work
  3. Touch Display.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
When I turn on my nuvi 200 it says press dot. When I press the dot it just moves around the screen to different location.
To calibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position. Once unit powers on release the power button.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 09/30/2010
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Friend has a problem with his Garmin nuvi: when typing the letter to the left appears. what can be done?
It needs to be calibrated
To calibrate the touchscreen on your nuvi 200W follow the steps below:
Aug 14, 2010 | Garmin nuvi 200W GPS Receiver
My Garmin nuvi 200w behaves erratically until it has been turned on and warmed up for around 10 minutes. Before this time the touch screen may not work or when pressed respond as if pressed at another...
First make sure the batteries are good and at normal room temperature.
Second, based on your question your touch screen is bad or needs calibrating....
Then
Try to recalibrate your screen:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
The screen on my Garmin Nuvi 200W won't respond. I tried the recalibration but the screen doesn't respond when I touch the dot. I also tried a hard reset and that didn't help either. Help please!
There is more than one calibration procedure, but for the 200 it is:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 follow the steps below:
If this doesn't work you have two choices
Buy a new one
Or
Send your in for repair. Go here for this option
http://www8.garmin.com/support/outofwarranty.html
Aug 23, 2009 | Garmin nuvi 200W GPS Receiver
I'm getting inaccurate letter entry on the letters I type. For example, when I type a B an M appears - I'm noticing it on the bottom row of letters at this time. Solution?
Are you sure you pressed the correct location on your screen???
If so, you may need to calibrate the screen.
Do this:
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Can't get past the calibration page, keeps shutting off
Does the calibrator keep looping or not seem to work?
If you can access the calibrator, but it loops through the target sequence (repeatedly asking you to tap the targets), there may be a physical problem that's causing your touchscreen to be confused:
  • Do you use an adhesive screen protector? A screen protector which is trapped under the screen edge may interfere with touchscreen calibration. Occasionally, just having the screen protector on the screen can cause the issue. Try removing the screen protector.
  • You may have debris trapped under the edge of the screen. Use the corner of a piece of thin, stiff paper (copier paper works well) to very gently slide all around the edge of the screen. Don't let the corner of the paper travel more than an eighth of an inch under the screen edge frame. By doing this, you may be able to dislodge small particles of debris trapped under the frame.
  • A heavy impact or scrape to the touchscreen can cause permanent damage. If your touchscreen is damaged, you may need a repair
Did you install any 3rd party apps?
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/
?St=2,E=0000000000825403011,K=4996,Sxi=18,Case=Obj(26419)
Diagnosing problems by 3rd parties- http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE?
New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(27908)
Aug 31, 2007 | HP iPAQ RX3715 Pocket PC
Sony DCR-HC26 Mini DV Digital Camcorder Logo
463 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
