Question about Bunn 10 Cup Home Coffee Brewer
My bunn GRXB leaks from the bottom when i add water. please help
    Genius:
  • 1,036 Answers
Hi.
This needs surgery - so make sure it's unplugged, then remove the base & covers.
Look for leaks around seals and pipes.
80% of the time - it's a seal that is faulty. You can contact the manufacturer for a replacement - or - just use standard silicone sealant to apply a thin layer over the defective area of seal - then re-assemble.
Silicone is so effective thesedays - that engine sumps are "glued on" rather than using a solid gasket. I'ts cheap and effective for repairs like this also.
Posted on Oct 01, 2009
Lid is broken on my grxb bunn coffee maker can I purchase a new lid
Fixya does not sell replacement Bunn lids. Check with a local appliance parts supplier.
Nov 03, 2016 | Bunn Coffee Makers & Espresso Machines
Bunn NHB model leaks water out of the bottom
Please call customer service at 800-352-2866 with the date code from the bottom of your brewer. We will be happy to assist you with this issue.
Dec 31, 2010 | Bunn NHB Coffee Maker
My bunn model b10-b is leaking at the bottom out onto my counter top. so when i add 10 cups of water, I get about 8 cups. It appears to be leaking from the holding tank. The code date is 202103. Is...
There is a seal kit that is successful about 90-95 percent of the time in fixing the leaking issue. If you will call customer service at 800-352-2866 with your name and address, we will be able to send you a kit to resolve your issue.
Dec 04, 2010 | Bunn B10 Coffee Maker
My bunn coffee maker is leaking water out of the
Please get the model and code date located on the bottom of the brewer. The machine has a 3 year warranty and if it is 3 years old or less, it will be replaced at no cost. If it is older than 3 years old, it will be replaced at a discounted price. Once you have this information please call customer service.
Oct 24, 2009 | Bunn NHB Coffee Maker
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
I have a GRXB bunn 900 watt 10 cup coffee maker that leaks from the bottom when you add water. can you help me find the problem
If sounds like a bad seal/gasket. Please call customer service with the model and date code. If your machine is 3 years old or less, it will be replaced at no cost. If it is over 3 years, depending on the date code, there is a seal kit available to repair the leak. Or we can replace it at a reduced price.
Oct 01, 2009 | Bunn 10 Cup Home Coffee Brewer
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
Jul 13, 2009 | Bunn 10 Cup Home Coffee Brewer
Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Apr 29, 2009 | Bunn 10 Cup Home Coffee Brewer
Bunn 10 Cup Home Coffee Brewer Logo
163 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
