Question about LG DLE5977 Electric Dryer
My lg dryer wont turn on yet the light comes on when i open the door
4 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: I moved. I changed the
Hello. Test the receptacle. If one of the hot leads isn't hot (120 volts), The light may come on, but the dryer may not operate. With breakers that throw two switches at one time (one to each bus bar, 120 volts each), it is possible that one side may be defective, or simply did not reset. If the receptacle is found to not have power on one of the hot leads, go back and reset the breaker several times. You can also test the output of the breaker with a volt meter, but extreme caution should be used if working behind the shield in a breaker box. You may have to go there anyway if the breaker is bad.
If all of this tests good, the next thing to check would be your wiring connections at the back of the dryer. Make sure that the outside leads of the pigtail are connected to the hot legs and the two inside leads are connected to the common and the ground lugs. If the receptacle tests out properly, you can also test the voltage at the dryer terminals. It could be as simple as a bad cord. It happens, rarely, but it does.
Best regards, --W/D--
Posted on Feb 23, 2011
heatman101
  • 43501 Answers
SOURCE: Lg model #dle0332w dryer won't turn open it up
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 12, 2011
Macmarkus
  • 2605 Answers
SOURCE: My LG 2050w dryer wont
Hello, welcome to FixYa.
Based on your post I'd suspect the belt has broken, come off it's pulley system or the kill switch is defective. These dryers have a "kill switch" by the motor that prevents the unit from starting if the belt breaks or comes off.
The service of LG dryers is mostly from the front, with some at top. As far as tear-down/repairing most LG dryers is essentially the same.
**insure the unit is unplugged from the wall...safety first**
Now remove the top via taking out two screws at the back, slide it towards the back and inch or so and lift up, it will come off.
(you will be able to identify if the belt is off or broke before proceeding)
Next step is to remove the control panel. It will snap off the the top part, and some have a screw located on either side, i.e.
pull up or pry with a small screwdriver to release console clips from notches in metal support...
Pull the console towards you slightly (from front facing it) and reach in and disconnect the wire harness.
Set the console to the side ...
Now to remove the front panel...careful here the edges are sharp. Remove the screws at the top, and the two inside the door by the lint screen i.e.
Now the front panel will come forward enough to unplug the lamp...
Move the front panel to the side and you should be able to access and check the belt and switch. This is what to look for...
If the belt is off you can simply put it back on, obviously if it is broke you'll need to replace it.
Hope that helps get you fixed up, or moves you forward at least. Let me know what you find.
Good luck. Keep me posted.
Regards,
Macmarkus :)
Posted on Aug 24, 2011
Eaton Viking 5 Dryer wont turn on
The door switch is a 3 way switch. Though the light comes on when the door is open the other part of the switch may be out for the dryer to start.
Feb 19, 2015 | Dryers
Dryer light stays on when door is shut nd wont run
check the door switch,i don't work on lg but on any other dryer if the wsitch is broke the dryer won't start and if the light is on the switch shuts off the light and dryer will start.if you send the model number i can look up the switch for you.open the door and look around the frame where the door closes into,there should be a push button switch or a little paddle that the door hits,when you push in on the switch it should make a clicking sound or i've seen the paddle broke off.hope this helps or if you removed any wires to the door switch you might of wired it wrong
Mar 30, 2013 | LG Dryers
Lg dryer wont turn off
If the dryer continues to run when you open the door you will need to replace the door switch. Here is the part to order.
Nov 03, 2012 | Dryers
Lg electric dryer will not turn on
just check if the switch door its in good condition and if it make a click sound when u close the door!!if thats not the problem u'll have to open it and look for a white fuse and test it and see if thas the problem cuz if the white fuse ist working it wont turn on
Aug 26, 2012 | LG DLE2532W Electric Dryer
Dryer wont turne on but inside light comes on
check the door switch as this switch has 2 positions one for the light on/door open and the other door closed light off and dryer can operate,depending the make & model will determine how to access this door switch
Feb 12, 2012 | Dryers
The dryer won't turn on when plugged in. However, when I open the door, the drum light turns on.
I have the same dryer and the same problem...I have power to the unit but it wont turn on....the light in the door is on....there is a small cllick to the top left when I try and start it..thats it..!!...did you get a solution yet?..thanks..mike
May 15, 2011 | LG DLGX7188 Gas Dryer
LG DLGX2502V not turning on when start button is pressed. The light comes on when the door is open so I know it can not be a power problem.
heatman101 ..
Oct 20, 2010 | LG DX2502V Dryer
My lg tromm DLG3788W gas dryer is not heating, it says check filter. other wise it works fine. where is the filter at, i know the one where i open the door and clean the vent everytime i use it. thanks
I just cleaned those sensors at the bottom of the filter, it worked like a charm. The dryer is now drying perfectly, I did not know you were not supposed to use fabric sheets with this dryer. Now I know, Thank you for the good information.
Jul 30, 2009 | LG DLG5932W Gas Dryer
Dryer light comes on but unit will not power up or turn on
Check & reset breaker in breaker box.
Your problem may be you have lost one side of your voltage coming in. Light in dryer comes on but circuit to start motor is off.
Msg back if that does not work& we will go further.
Mar 11, 2009 | LG DLEX0001TM Dryer
LG DLE5977 Electric Dryer Logo
252 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
