Question about Brother IntelliFAX 4100 Laser Fax
PROBLEMS WITH CLARITY OF INCOMING FAXES /BLACK STREAKS DOWN ENTIRE PAGE/VERY HARD TO READ SOME OF THE INCOMING FAXES.RECENTLY REPLACED DRUM AND TONER/WHAT WOULD BE CAUSING THIS PROBLEM?
    President:
  • 3,085 Answers
First, make a copy of something to determine if your machine is at fault.
Move the blue slider on the drum cartridge back and forth 10 times.
Posted on Oct 02, 2009
Black lines going straight across paper. 1 every inch down
If the streaks are narrow black and run the entire length of the page, replace the soft plastic wiper blade on the drum (and hope the drum is not scratched). Black smudges are related to the toner/developer purity. Replace both.
Jul 06, 2011 | Canon PC981 Copier
Vertical Lines through incoming faxes and copies.
Sometimes you may see vertical streaks/black lines
on the faxes you receive. Either your FAX/MFC's
primary corona wire for printing may be dirty, or
the sending party's fax scanner may be dirty. Clean
your primary corona wire (see pages 13-18), or ask
the sender to make a copy to see if the problem is
with the sending machine.
Cleaning the Drum Unit
We recommend you place the drum unit on a drop cloth or large piece of
disposable paper to avoid spilling and scattering toner.
1 Carefully turn the drum unit upside down.
2 Clean the primary corona wire inside the drum unit by gently sliding the tab
from right to left several times.
3 Return the tab to the Home
position (  ) before
reinstalling the drum unit.
Jan 31, 2011 | Brother IntelliFax-2920 Plain Paper Fax,...
WE HAVE A FAX MACHINE THAT HAS A BLACK LINE GOING DOWN THE PAGE WITH FAX IN AND FAX OUT
For outgoing fax lines, check your scaner rail for any streaks, dirts or similar and clean scaner.
For incoming fax streaks, you can only check your drum unit for lines on surface and replace it, or lines is there because other side has dirt or similar on their scaner.
Hope that helps!
Aug 09, 2010 | Office Equipment & Supplies
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
2 streaks down middle of page
Do the black lines go from the lead edge to the trail edge? Also, were the lines there before you replaced the drum? If so the problem lies in the fixing unit.... You most likely need a upper fixing roller.
Mar 19, 2009 | Ricoh Office Equipment & Supplies
Black lines on incoming faxes
Pull out the drum cartridge. There should not be any toner on it.
(it could be defective [drum cleaning blade] especcially if it's a refilled unit.
There might be a small blue tab on top of the unit that you can slide back and forth to clean the charge wire.
But then again, if you just changed the drum, it sounds like it's defective.
Sep 09, 2008 | Brother IntelliFAX 4100 Laser Fax
Dark toner streaks
can only be toner, drum or fuser, pull out drum and look at surface are you streaks present? usually drum.
Stop a print half way threw machine and then remove drum and look at print, pre hot bit (fuser) are you marks there? If so it is drum, if not fuser.
Nov 21, 2007 | Brother IntelliFAX 4100 Laser Fax
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Light print of incoming faxes, cannot read
are copies light too? if not then it is sending fax, but most times it is inferior ink or drum causing the problem sometimes damp paper (try printing on reverse side as well)
Oct 31, 2007 | Brother IntelliFAX 2600 Fax
Black streaks on the fax
Yes it does, the rubber blade that cleans the drum is not doing its thing properly, hence leaving your mark, pull the drum unit out and expose drum by pulling back the cover underneath it, you should see your mark on the drum, don't touch drum with fingers or brush/clean it, it is photosensitive too so keep away from light for any period of time.
Oct 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
155 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
