Question about Rockford Fosgate Punch 500S Car Audio Amplifier
Why does my old punch 500a amp push more than my new punch 500s
  • 3 Answers
Because those amps have unregulated power supplies. the impedance also could be incorrect.  Check the resistive load that the amp sees.
Posted on Oct 02, 2009
WHAT HD & SIZE RECOMMENDED FOR MY GATEWAY 500S PC WITH OS XP?
You cannot use a SATA (serial ATA HDD in this machine. You need a PATA (parallel ATA) HDD, also known as IDE, ULTRA IDE, ULTRA ATA. This has a 40-pin ribbon connector & a 4-pin power connector.
Sizes generally available would be 80GB up to 250GB, although very few PATA drives are now sold since SATA is the new standard.
Jan 25, 2013 | Gateway GT5220 PC Desktop
I just bought and installed my first punching bag at home. I thought it would be good for releasing stress. Where do I begin? Is there a proper technique to using a punching bag?
The best advice I can give you is to take your time. It is very important to take some time to first develop proper body mechanics of punching before hitting away. Remember to stay focused on your balance, keep your wrists straight, protect your hands, and never push the punching bag.
Aug 07, 2012 | Boxing
How to insert bobbin case on singer 500a
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 500 ) do not put (a) in the box & click search
May 10, 2012 | Singer Sewing Machines
The red light and blue light in on permanently. The earpiece has been charged all night but when I push the earpiece to sync, the blue light on top of the base doesn't flash therefore no connection. Please...
Unplug the AC power from the Plantronics 500A base, leave it unplugged at least overnight if possible, no lights should be illuminated on the base. Then plug the power back in, charge the headset, and try re-pairing the headset to the Plantronics 500A base unit. Here is the link for the pairing instructions:
Plantronics Voyager 500A User's Guide
Good luck from Headsets Direct!
Apr 02, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I want to hook up a crossfire bmf 12 to my 500s. It is a dual 4 ohm speaker which config will i get the most power out of the amp. Wired at 8ohm bridged or each voice coil on a channel. That amp wont run...
You are correct, the amp will not support 2 ohms bridged. your best bet would probably be to have one voice coil on each channel. You could run them in parallel on one channel. but you will be getting the same power to each sub as if you put one on each channel. If you run them at 8 ohm bridged you will be getting less than 125 wrms per voice coil because of amp inefficiency at such a high resistance. It will sound cleaner also if you have one voice coil per channel.
Mar 09, 2011 | Rockford Fosgate Punch 500S Car Audio...
Rockford Fosgate Punch 500a amp wont turn on
check the internal fuses inside the amp its self these burn up real easy plus if it is them it will save you some money
Mar 31, 2010 | Rockford Fosgate Punch 500a2 Car Audio...
Old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Sep 22, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
Multi amp hook-up
honestly i dont think those to amps will push cvxs no matter how you wire them up.
the rms on the 200 should be used to push a door speaker.
the 800watt should deff just be hooked to 1 cvx but still wont max it out.
Dec 25, 2008 | Rockford Fosgate Punch 301M Car Audio...
Rockford Fosgate Punch 500S Car Audio Amplifier Logo
98 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
