Question about Lands Phones
KEY PAD IS LOCKED - Lands Phones
Safe won't stay locked, key missing but have key pad.
You might need to have the key set to lock in order to use the keypad or check the battery in side the door
Mar 08, 2013 | Locks & Locksmithing
Key pad flashing se . key pad locked pease tell me what to do iam a disabled lady need help please
"SE" error means you have a shorted membrane keypad.
You would need to have either the membrane keypad itself replaced, or the control panel frame assembly which comes with a new keypad, or the whole controller.
Part numbers and prices will of course depend on the model number.
Dec 27, 2012 | Samsung Microwave Ovens
Key pad locked on k800 sony erricsson
press menu button and star when unlocked go in to settings and change it
Aug 14, 2009 | Cell Phones
LG shine key pad is locked
just call cumstumer service and they can tell u what ur keypad password is or click the unlock on ur phone
May 27, 2009 | LG Shine KE970 Cellular Phone
Hi i locked my bmw 323i with key pad now it wont
the BMW is complicated since i had a similar problem with mine. the keypad is connected partly to the ECM and the TDS. the connector to the keypad partially gets corroded over time and wont send the correct signal to disable the alarm. Check the connection first. if it is fine. disconnect the power to the battery for 5 minutes to let the TDS reset and try again. if it fails then chances are the key pad is faulty
Apr 23, 2009 | 1999 BMW 323 Series
Key pad locked up
Press the NumLoc key on the key pad and the numbers keys will work.
Feb 01, 2009 | Acer Aspire 5100 Notebook
Dishwasher locked key has been activated.
To turn on Lock:
Press and hold Heat Dry for at least 4 seconds. The Locked light
glows. If you press any pad while your dishwasher is locked, the
light flashes 3 times.
To turn off Lock:
Press and hold Heat Dry for at least 4 seconds. The Control Lock
light turns off.
Dec 18, 2008 | Whirlpool Dishwashers
Nokia Phones
boss ....go to menu... and > settings.. >..phone settings..>.. there uou will find the option to lock ur key pad. cheers!!
Aug 03, 2008 | Nokia 3110 Cellular Phone
Keyboard and touch pad locked
reboot- if that does not work the keyboard/touchpad may be disconnected or bad. ram is under an access panel on the bottom in the middle- you need a small screwdriver to add ram (ddr)
Nov 19, 2007 | Dell Latitude D800 Notebook
Lands Phones Logo
24 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
