I need to install x4 canon irc-2380i drums - Office Equipment & Supplies
    President:
  • 1,653 Answers
1 Open the front cover of the main unit.
2 Turn the knob that corresponds with the toner colour you want to replace in the direction of the arrow.
IMPORTANT Turn the knob on the toner cartridge until the arrow points to 'Unlock'.
3 Grip the top notch on the toner cartridge, and pull the toner cartridge out of the toner supply port.
IMPORTANT If the toner cartridge cannot be pulled out, check that the knob is turned all the way to the appropriate position.
4 Hold the new toner cartridge in your hands and gently tilt it up and down five times.
5 Push the new toner cartridge in as far as possible.
IMPORTANT When replacing toner cartridges, make sure that the colour of the toner cartridge matches the colour of the toner supply port. If the colour is different, the toner cartridge will not fit into the port.
6 Return the knob to its original position.
IMPORTANT Before you turn the knob, make sure that the toner cartridge is pushed into the machine as far as possible.
7 Close the front cover of the main unit confirm the message displayed on the touch panel display.
NOTE If several toner cartridges are replaced simultaneously, a message for each is displayed in order.
Posted on Oct 01, 2009
  • Karl Wright
    Karl Wright Oct 01, 2009
    When the waste toner container is full, the procedure for replacing the container appears on the touch panel display. Follow the instructions on the touch panel display, and the procedure described below to help you replace the waste toner container.
    If you press [Recover Later], you can continue operations, such as setting modes and scanning originals, even if you do not replace the waste toner container immediately.
    2 Lift the lever.
    3 Pull out the waste toner container.
    CAUTION
    When removing the waste toner container, be careful not to tilt it, as the toner may spill and get onto your hands or clothing. If toner gets onto your hands or clothing, wash them immediately with cold water. Washing them with warm water will set the toner, and make it impossible to remove the toner stains.
    4 Use the provided cover to cover up the opening of the used waste toner container.
    5 Insert the new waste toner container.
    When inserting the new waste toner container, line up the part indicated by the circle on the waste toner container with the main unit,
    6 Return the lever to its original position.
    7 Close the front cover of the main unit.
I have a Canon IRC 2380i and it is displaying E000355-0001 anytime i switch it on. pls help me solve this problem. Thanks.
that is
E000355 When turning ON the power, inconsistency among the serial No. PCB, the controller PCB (SRAM), and the counter memory PCB is detected
May 23, 2018 | Canon Office Equipment & Supplies
I have Canon IRC 2380i and it is displaying E000355-0001 when I switch it on. Pls Help me. Thanks
that error means there is a malfunction in the digital counter board, maybe is defective
May 21, 2018 | Canon Office Equipment & Supplies
I have Canon IRC 2380i and it is pisplaying E000355-0001 anytime I switch it on. Pls to help me. Thanks.
E000355 When turning ON the power, inconsistency among the serial No. PCB, the controller PCB (SRAM), and the counter memory PCB is detected.
you can try to clean the SRAM, or you change it
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Canon irc 3080i error code e000020-0023
NITIAL FAULT IS ERROR CODE DUE TO WORN BLACK DRUM GIVING PATCHY IMAGE, ON FITTING A NEW DRUM IT CREATES ANOTHER ERROR CODE ABOVE E020, ON RE-FITTING OLD ONE ERROR DISAPPEARS. PATCH CREATED ON ITB IS UNDERTONED DUE TO LESS INTENSITY LASER BEAM PASSING THRO, THE RESIDUE ON THE GLASS, HENCE E020-0023.
THE CLEANING TOOL ON THE DOOR IS INADEQUATE TO CLEAN THIS RESIDUE. PULL OUT PROCESS UNIT TO MAX. LIMIT. PRISE UP THE DUST SHUTTER, THEN CLEAN WITH DAMP WIPE AND DRY IT. REPEAT IF NECESSARY OR TAKE LASER UNIT OUT
Mar 28, 2012 | Office Equipment & Supplies
Hi i have a canon irc 2380i and all of a sudden it has started producing 3 black line on any doc to come out of the machine .... any ideas michael rutherford
It appears that the drum is scratched. Remove the drum and do a physical inspection. If that is the case, the only solution is to replace it.
Sep 22, 2011 | Office Equipment & Supplies
Error code E000025-0003 on canon IRC 2380i
I have canon coper IRC2380 appears code 000025-0003 ...plz help me
Nov 15, 2010 | Office Equipment & Supplies
Canon irc 2100 showing the coad # E020-02A0
The Magenta drum unit needs to be replaced. Good day
Nov 06, 2009 | Canon Office Equipment & Supplies
19 people viewed this question
k24674
jasbo
jasbo
