Question about Dishwashers
Whirlpool Quiet Wash Plus dishwasher Model DU920PFGZ3. Worked fine until I replaced the insinkerator and forgot to punch the drain plug leaving water standing on the bottom of the machine. I punched the drain opening, and pushed the cancel/drain cycle button. It drained fine but since no water comes from the spray arms. I have removed the arm all the way down..NOTHING!! Some research indicated it could be the water inlet valve. When the buttons are pushed, it cycles but no spray or water.
SOURCE: dishwasher pump will drain but not force water into spray arms
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Posted on Feb 09, 2008
reg501
  • 413 Answers
SOURCE: water not spraying hard enough
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Posted on Jun 08, 2008
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Check water level:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
SOURCE: I have a Frigidaire Ultra
I may have the answer. I had what sounded to be the same problem. I found the dishes were dirty after they were cleaned, but I found there may have been a big pot lid blocking the upper arm. I decided to run the machine again, and after a bit opened the dishwasher after to make sure it was not a problem with the arm. Sure enough, the arm wasn't moving. However, I found out on the Frigidaire webpage that some models have an alternating spray cycle, where only one arm spins at any given time. After reading this I checked again, and it had moved by that time. I checked a few times more to confirm this. So it ended up it was an arm blockage after all. Hope this helped...good luck.
www.frigidaire.com/support/FAQ-Dishwasher.asp#6
Posted on Dec 14, 2008
SOURCE: Dishwasher upper arm does not spray
possible ball valve problem
Posted on Jan 03, 2009
Dishwasher not emptying out water
If you recently replaced your garbage disposal make sure the "knock out" plug was punched out to allow drain water into the disposal. The guy who replaced my disposal forgot to do it and my dishwasher would not empty. It's an easy fix. Just remove the drain hose from the dishwasher that attachs to your garbage disposal. Look inside with a flashlight and you will see if it is still there.
If it is, take a hammer and screw driver or punch and knock it out. TURN OFF POWER to your disposal and you can retrieve the "knock out" plug (piece of plastic about the size of a dime). Replace your drain hose to the disposal and try your dishwasher again. Worked for me! Good luck.
Oct 05, 2014 | Dishwashers
I have a Whirlpool Gold Quiet Series Plus, Model GU940SCGT3, not working. It ran a cycle, cleaned the dishes, but the water didn't drain and the "CLEAN" light is stuck on. It is now...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 31, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Quiet Wash Plus won't drain.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you
Aug 27, 2010 | Whirlpool Dishwashers
Whirlpool dishwasher model DU920PFGB4 will not start.
my dishwasher is only 2years old and will not start. the lights on the panel come on but wont start.
Sep 26, 2009 | Dishwashers
Whirlpool Quiet Partner 2
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Wash Plus Dishwasher is not despensing the detergent properly. After a wash cycle there is still some left.
My Whirlpool Quiet Wash plus dishwasher seems to have died. No power. None of the buttons work, it quiet mid-cycle. No breaker issue, my garbage disposal runs off same breaker and is working fine. Any ideas? I was thinking the comp. board that the buttons work off of is fried. If this is the case any idea how much to replace it? Would it be cheaper to buy a new dishwasher?
Apr 21, 2008 | Dishwashers
Dishwashers Logo
93 people viewed this question
Top Dishwashers Experts
