Question about Samsung CLP 300 Laser Printer
Internal part in Samsung clp-300 broke
Hi. This clear plastic rubber thing (looks like a giant rubber band with a black film a attached to it) broke in my printer. Is this fixable???
  • Marine Wife Jan 16, 2008
    I still haven't gotten my printer fixed yet. I can't really explain what the band looks like. It came off and I have it on the desk beside me. It is clear and thin, It was a larger band. Before the printer broke, it made a crackling sound. Not like poaper jamming, but like a film crinkling sound. The band broke shortly after that problem happened.
  • 4 Answers
Hi. Need more details. Sounds like the unit ITB thats clipped in behind the Imaging unit?
Posted on Dec 30, 2007
Hi. My Samsung CLP 300 Laser is playing up. It
The problem you are experiencing is a common problem with this printer. What happens is over time as the printer is used, toner or developer builds up a film on the developer blades. The developer blades meter the amount of toner that the printer puts on the paper to make the image. As the film builds up, less and less toner makes it to the page causing the image to become faint. The black developer blade probally is clogged.
This can be fixed two ways. The easiest and most expensive is to buy a new imaging unit for about $100+. The second is to disassemble your imaging unit and clean the developer blade(s). This can be done in about 30 minutes. I have posted instructions in my Tips section.
Feb 18, 2010 | Samsung CLP 300 Laser Printer
Samsung clp 300 paper jams after feeding about 5cm. Tried more paper, less paper, printing black only, printing colour, no change. Help
Clean up the Pick Up Rubber.
When you are able to get the Pick Up Rubber out of the maschine rotate it 180 degrees an reinstall it. then the problem would be fixed.
Oct 14, 2009 | Samsung CLP 300 Laser Printer
My Samsung CLP-300 won't pick up paper (it goes 1 inch & stops)
No oil on rubber rollers! You must gently clean the rubber roller with isopropyl alcohol and a soft cloth. Let it dry and it should work again. Make sure to get ALL of the oil off of the paper paths surfaces.
Sep 10, 2009 | Samsung CLP 300 Laser Printer
Samsung clp-500 paper feed roller replacement - how to...
You're on the right track! If you remove the paper tray and put the printer in a position so the front of it is facing up, you can then access the roller shaft with ease. If you now look on the right hand side of the roller shaft you will see a white plastic end which is secured onto the shaft with a little clip, lift this up and slide the plastic part inwards. This should now make the shaft easy to turn so you can release the two white clips on the roller and remove the rubber band (which there is only one of, but looks like two on a first glance). Once removed, I just turned it inside out so you can get another few months or more out of it before you have to buy a brand new one for a couple of ££. Replacement is just the reverse of removal. Hope this help!
Jan 28, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-300 has grinding rollers
mine is the same way, to solve this I elevated the bottum by 2 inches, then i kept it off, also i blow a fan on it while running. also, you need to clean the filter (the gray "L" inside) black dust should come out. lastly, mine actually broke because it overheated. matt
Nov 15, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP300 cannot get the rubber pick up roller back in
The rubber band goes around the plastic roller and is loose about loose enough to get a finger between it and plastic however the thing then pushes back into the curved space at the back of the roller so it forms a kind of c shape around the roller. If that makes any sense!
Aug 16, 2008 | Samsung CLP 300 Laser Printer
Paper Feed
I'm having the same problem. so far no answer either.
Jun 12, 2008 | Samsung CLP 300 Laser Printer
Samsung 300CLP "paper jam"
I have just posted my "fix" for the paper jam elsewhere on this forum. Check it out and I hope it helps you too?
Nov 24, 2007 | Samsung CLP 300 Laser Printer
Paper Jam
I have just SOLVED my CLP 300 printer paper jams by replacing the rubber band on the paper pick up roller. My old rubbber had worn flat and had dried out. I was lucky as Samsung had sent me one for an engineer to fit. However, being an engineer myself, I replaced it with instant success!
You could fix yours without replacing the band because all it needs is to be turned around to a non worn area. To get to it safely, unplug your printer from the mains supply and the USB cable. Remove the paper tray.
Open the front door and remove the imaging unit complete with toners. Now turn your Printer upside down and look for the rotating bar with a centre wheel and rubber band. The rubber band looks like it only goes half way around the wheel. This band is Clipped onto the wheel. With careful prising, you can unclip the rubber band. It's a bit tricky and tight but I have done it no probs. Perhaps being a techy myself has helped? Anyway, rotate the band around so that a fresh bit of rubber will be acting on the paper and refit. This is also tight and tricky, but can be done without dismantling the printer to replace the who bar.
The actual part that is unserviceable is the rubber on the Samsung MEA unit pick up roller. The part number is JC97-02647A
Now refit all the other stuff and test your printer. I have also got rid of the dreaded clicking too! But that's another story.
Hope this helps?
Oct 06, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
284 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
