Question about Casio G'zOne Boulder Cell Phone
Casio G'zOne Boulder Compass Turns On Automatically
Whenever I place my phone into the belt clip, the compass turns on automatically. This drains my battery quickly. Others at work do not have this problem with their Boulders (it's our new company cell phone). I've tried switching belt clips with someone who does not have this problem, and mine continues to happen while theirs continues to function normally - so that rules out the belt clip.
I can't find a way to disable the compass. When I put the phone into the cilp, I just want it to go in the clip - and not perform any task.
firesnake09
  • 2923 Answers
SOURCE: will not charge
It could be that the battery is bad. Bring your phone in to any repair shop and try using another battery. Most cellphone shops or stores has a test battery.
If you couldn't find a test battery, refer to a cellphone tech to test if the battery is still okay.
Posted on Jul 28, 2009
SOURCE: Need to turn off certain features on Verizon- Casio Boulder GzOne
access your account online and block all of those things in your plan options, or you can call verizon wireless and tell them all the things that you listed here and they will have your phone block them
Posted on Nov 01, 2009
SOURCE: Casio Pathfinder Digital Compass will not calibrate
http://pathfinder.casio.com/support/manual/
find your watch and use the manual. if there is no solution then take it in for repair. any Casio retailer should have repair center information.
Posted on Nov 22, 2009
SOURCE: New Casio 3157 watch: compass works for 7 seconds then goes blank
Mine does the same!
Posted on Nov 23, 2009
SOURCE: My Casio Gzone Boulder has stopped recording numbers called
I had the same problem. No caller ID for incoming or outgoing or missed. Then it froze up. I took the battery out to restart it. A day or 2 later I had to get it replaced. No caller ID at all. I got a new Boulder from verizon. It started not receiving calls randomly. I would get some, but friends complained that they called and I did not anser. No voice mail was there or them. Then IT Froeze on the Verizon Wireless wording. Cant do a thing now. 3rd phone onits way. THESE ARE JUNK!!!! I got my first in sept, 2nd oct, 3rd on its way for dec 5. SEND IT BACK FOR A REPLACEMENT.
Posted on Dec 03, 2009
What is calibrate compass on 2004 Buick Rendezvous
Manual Compass Calibration If the compass appears erratic and the calibration symbol does not appear, you must manually put the compass into the calibration mode. To get into this mode, do the following: 1. Turn the ignition on and cycle the DIC to the compass/temperature mode. 2. Press and hold the SET button for longer than three seconds. ZONE # PRESS & HOLD SET TO CHANGE: This display mode will be displayed when you are manually calibrating the system. The current zone number for compass variance will be displayed in place of the # symbol. Use the SET button to select the zone number from the graphic shown to select the current area of the country that you are driving in. PRESS SET TO CALIBRATE COMPASS: After selecting your zone, press the MODE button and this will be displayed on the DIC. Press the SET button and complete three 360 degree turns in an area free from large metal objects. The following two messages will toggle in the display until you calibrate the compass: • DRIVE VEHICLE IN CIRCLE • CALIBRATING COMPASS When calibration is complete, the display will return to its normal mode. 3-61 info obtained from MANUAL OWL
press the helpful button and follow me on fixya for more tips
Compass Variance Zone Procedure DIC Compass Driver Information Center DIC...
http://www.manuals365.com/swf/buick/2004_buick_rendezvous_owners.html?page=200
http://repair.chiltondiy.com/Buick/Rendezvous/Repair-Manual-Online
http://www.repairservicemanuals.com/Buick
Feb 02, 2016 | Buick Cars & Trucks
Tip
USING THE COMPASS WHEN THE COMPASS (4) IS HORIZONTALLY PARALLEL, THE COMPASS (4)...
USING THE COMPASS
WHEN THE COMPASS (4) IS HORIZONTALLY PARALLEL, THE COMPASS (4) WILL
ADJUST THE DIRECTION AUTOMATICALLY. WHEN IT IS STABLIZED, IT WILL
INDICATE THE FOUR DIRECTIONS.
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
What is calibrate compass on 2004 Buick Rendezvous Vous
How to do I get the compass and temperature gauge to work in the rear view mirror again. Directions are NW and SE all the time
Calibrate the compass built into the upper-right corner of the rearview mirror by holding the compass button (an "N" with two crossing lines) until your zone number appears. Determine your zone number by looking at the map in the owner's manual. Press the compass button until a "C" appears. Then drive in a circle three times at 5 mph or less in an uncongested area. The compass will automatically orient as a result of the circling.
Read more : http://www.ehow.com/how_5927729_reprogram-avalon-after-battery-change.html
Aug 19, 2014 | 1999 Toyota Avalon
How do i reset the compass on a 2006 dodge grand caravan
Hi Roger, I'm glad to help. Below is the procedure for resetting the compass on your vehicle.
COMPASS VARIATION ADJUSTMENT Compass variance, also known as magnetic declination, is the difference in angle between magnetic north and true geographic north. In some geographic locations, the difference between magnetic and geographic north is great enough to cause the compass to give false readings. If this problem occurs, the compass variance setting may need to be changed.
To set the compass variance:
1. Using the Variance Settings map, find your geographic location and note the zone number Figure 1.
22681.jpg Figure 1 - Variance Settings 2. Turn the ignition switch to the On position. If the compass/thermometer data is not currently being displayed, momentarily depress and release the C/T push button to reach the compass/thermometer display. 3. On Electronic Vehicle Information Center (EVIC) and Compass Mini-Trip Computer (CMTC) equipped vehicles depress the Reset push button and hold the button down until "VAR = XX" appears in the display. This takes about five seconds. On Compass Temperature Module (CT) equipped vehicles depress the C/T push button and US/M push button down until "VAR = XX" appears in the display. This takes about five seconds. 4. Release the push button(s). "VAR =XX " will remain in the display. "XX" equals the current variance zone setting. 5. On Electronic Vehicle Information Center (EVIC) and Compass Mini-Trip Computer (CMTC) equipped vehicles momentarily depress and release the STEP button to step through the zone numbers, until the zone number for your geographic location appears in the display. On Compass Temperature Module (CT) equipped vehicles depress the US/M push button to step through the zone numbers, until the zone number for your geographic location appears in the display. 6. On Electronic Vehicle Information Center (EVIC) and Compass Mini-Trip Computer (CMTC) equipped vehicles momentarily depress and release the RESET push button to enter the displayed zone number into the EVIC/CMTC module memory. On Compass Temperature Module (CT) equipped vehicles depress the C/T push button to enter the displayed zone number into the electronic module memory. 7. Confirm that the correct directions are now indicated by the compass.
May 17, 2014 | 2006 Dodge Caravan
The letter C is flasing in my dash board
The flashing "C" in the Instrument cluster if for the Compass. Here's the bulletine...
Subject: Compass Displays a Steady or Flashing "C" In Place Of Directional Heading
Models: 2008 Saturn VUE built on or after 11/09/2007
This PI was superseded to update Recommendation/Instructions. Please discard PIT4699.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern: The compass displays a steady or flashing "C" in place of directional heading.
To return to a normal heading display, press and hold the cluster stem for approximately 2 Seconds.
The displayed heading is not correct after driving for 30 seconds, use the following "Compass Calibration" routine.
Press cluster stem until the Season Odometer is displayed (Not Trip A or B).
Press and hold cluster Stem until the solid "C" is displayed. To the right of the "C" will be the "Zone". Refer to the variation zone map above for the correct setting. Turn the stem Right to increase, Left to decrease. It will take a few seconds for a change of zone to be updated in the display.
Once the Zone is correct, press the Stem to display the Flashing "C". Do not touch the Stem again until the direction is learned. Drive the vehicle in slow circles in an open area until you see a compass (oc tant) heading replace the flashing C.
Note: Vehicles built prior to 11/09/2007 were not built with a compass.
Recommendation/Instructions:
Engineering is aware of this condition and is in the process of root causing. It is known that the Remote Compass Module (RCM), Body Control Module (BCM) and Cluster hardware are not at fault, and these parts should not be replaced.
Reinforce with the PDI technicians that the Compass Zone and calibration is still required as part of PDI.
Hope helps (remember to rate and comment this answer).
Mar 07, 2011 | 2008 Saturn VUE
I bought the Gzone boulder pritt with no manual
I have Uploaded the Manual for you. Kindly Download the same as soon as Possible :-
http://rapidshare.com/files/368839284/9e56d61b-10eb-4ec2-a5af-049a9a1952f8.pdf.html
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 27, 2010 | Casio G'zOne Boulder Cell Phone
I have 2002 Yukpn Denali XL. There is a OC code that appears in the rear view. What is the cause of this and how can I fix it?
The "OC" indicates your compass is "Out of Calibration". Below is the proceedure to recalibrate your compass.
Compass Calibration
The compass may need calibration if:
 After five seconds, the display does not show a
compass heading (N for North, for example), there
may be a strong magnetic field interfering with the
compass. Such interference may be caused by a
magnetic antenna mount, magnetic note pad holder
or a similar magnetic item.
 The compass does not display the correct heading
and the compass zone variance is set correctly.
In order to calibrate, the letters CAL must be displayed
in the mirror compass windows. If CAL is not
displayed, push in the COMP button for approximately
eight seconds or until the letters CAL are displayed.
The compass can be calibrated in one of two ways:
 Drive the vehicle in circles at 5 mph (8 km/h) or less
until the display reads a direction, or
 drive the vehicle on your everyday routine and after
several turns the compass will become calibrated and
will display a direction.
Good luck.
Oct 23, 2009 | 2003 GMC Yukon XL
1997 Nissan Terrano electronic compass blinking
CORRECTION FUNCTIONS OF COMPASS
NAEL0307S01
The direction display is equipped with automatic correction function.
If the direction is not shown correctly, carry out initial correction.
INITIAL CORRECTION PROCEDURE FOR COMPASS
NAEL0307S02
1. Pushing the “Mode” switch for about 10 seconds will enter the
initial correction mode. The direction bar starts blinking.
2. Turn the vehicle slowly in an open, safe place. The initial correction
is completed in one or two turns.
NOTE:
In places where the terrestrial magnetism is extremely disturbed,
the initial correction may start automatically
Feb 08, 2009 | 1997 Nissan Pathfinder
Compass out of whack
You need to recalibrate the compass. The procedure is in your owners manual. Here are the basic steps.
First, you will need to verify that your compass zone is set to your current geographic location. Since I do not know where you are located, I cannot tell you the code. They are listed in the manual. (For example, So Cal is zone 5.)
Second, here is the compass calibration adjustment procedure:
Perform this adjustment in an open area free from steel structures and high voltage lines. For optimum calibration, turn off all electrical accessories (heater/air conditioning, wipers, etc.) and make sure all vehicle doors are shut.
1. Start the vehicle.
2. To enter the compass calibration mode, press and hold the button for greater than eight seconds. The display will then show CAL in the display window.
3. Drive the vehicle slowly (less than 3 mph) in circles until CAL indicator turns off. As many as 5 complete circles may be required.
4. The compass is now calibrated.
Dec 19, 2008 | 2005 Ford F-150
Casio G'zOne Boulder Cell Phone Logo
146 people viewed this question
Top Casio Cell Phones Experts
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
