Question about Maytag Washing Machines
How old is maytag wash machine model number A209
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
faggly
  • 74 Answers
SOURCE: maytag washing machine
Hiya .. would suggest you having a look at the balance around the drum, ( normally heavy concrete blocks)... locate the fixing bolts and tighten them up ....should sort your prob.
Also make sure that the washer is fairly even and tight on its legs.. this is what usually causes the problem in the first place..
Regards Faggly
Posted on Mar 27, 2008
mikedurland
  • 481 Answers
SOURCE: How do you know if
  • tilt the machine over and look at the bottom. the belt is there.
  • it will feel loose but that is normal. it is spring tensioned.
  • the noise is probably coming from the water pump, when they are bad they make a loud noise.
  •  turn the pulley around a couple times to see where the noise is coming from.
Posted on Jun 29, 2008
  • 1341 Answers
SOURCE: Maytag Washing Machine Model LAT9706AAE Won't
Check at the back of it,the rubber belt may have become loose or sometimes slips off it course and may need re-fixing....
Posted on Jun 26, 2009
  • 441 Answers
SOURCE: Our Maytag Washing Machine Model number MFW9700SQ1 stinks!
This is a common problem, you can run a few cups of vinager or bleach in a empty load set to hot wash and this will help. To keep it from coming back when your done doing wash wipe the door gasket down with a rag dampened with bleach and never shut the door all the way. Good Luck
Posted on Jul 16, 2009
Washer tub fills after wash is done; hours after! 4-5 inches of water the next day
http://www.searspartsdirect.com/part-number/205613/0026/464.html?modelNumber=LAT9593AAL&categoryName=Residential%20Washers&brandName=MAYTAG
This is the water valve your model calls for.
Sep 24, 2017 | Maytag Washing Machines
Maytag Washing machine; Bravo,not filling up with water.
what is your model number is then we can get started okay
Jan 01, 2013 | Maytag Washing Machines
I need a knob , for why washing machine
http://www.repairclinic.com/Whirlpool-Washing-Machine-Parts
I buy parts at Repairclinic.com
They keep my old Maytag going
You can also google-search 'Maytag washing machine parts'
You need to know your model number ... so there is a metal tag located on back of machine that has this information.
The tag has all kinds of little numbers that are hard to read
I have a tip for all your appliance labels ...
Take a photo of the tag with your digital camera, and then download the full-size photo to your computer. This will make numbers easy to read. And you have a record of all your model numbers with voltage and amperage when you go comparison shop for a replacement.
The tag tells me the machine is 120V and 7Amps, which means it uses 840Watts (120 X 7) ... so each hour it runs, it uses .84 Kilowatt-hours or .84Kwh of electricity and now I can figure how much it costs each year to operate the appliance.
Oct 18, 2010 | Whirlpool Washing Machine Knob - 3362624
How do i replace a belt on a maytag washer model a209
unplug washer, tip backward 45 degree against wall, motor is spring loaded so push motor to get slack to replace belts
Aug 18, 2009 | Maytag Washing Machines
I need control panel diagrams which have peeled off in heat!
go to maytag.com under the service heading you will be able to print up a copy of your owners manuel, that will show you the dial
Jul 15, 2009 | Maytag Washing Machines
Free advice on what recalls maytag is fixing free on front loading neptunes w/built in water heater
Fee advice???are youlookingperhaps for possible recalls on the maytage front loader?? a call to the manufacture with the model and seriasl number will enable you to acess all the current recalls
Mar 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Need exploded view maytag mod. mat25csagw please
Go to appliancepartspros and type in the model number you provided. There are some excellent exploded view diagrams of every section of your washer along with parts listings and prices. I hope this is helpful to you. If you need further assistance, please let me know.
Mar 03, 2009 | Maytag Washing Machines
Washing Machines Logo
406 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
