Question about Intel Motherboard
My motherboard reads MS-6712 VER 10A. It has 3 RAM slots but 1 has been destroyed some time back. I want to add a 1 gig stick but am not sure if it will accept it.
  • Intel Master
  • 4,806 Answers
The motherboard is a socket A (AMD) processor board
The board supports DDR400*/DDR333/DDR266/DDR200 SDRAM
You can install a 1GB module in each slot (except the one which is damaged) that means you have a maximum of 2GB, 1X1GB in each slot.
Regards.
Posted on Oct 01, 2009
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
Manual for motherboard ms-6712 ver 10a
Try this link !
https://www.manualagent.com/msi/ms-6712/users-manual/download
Sep 21, 2012 | MSI KT3V (MS-6712-040) Motherboard
Unable to add more match RAM using secondary slots
You need the motherboard manual to make sure it can take more.
It may only accept 4 gig. For example: 2 x 2 gig strips or 4 x 1 gig strips.Or you may need to use single sided ram boards, chips on only one side. I know some motherboards do.
Feb 07, 2012 | Computers & Internet
USB wiring on KT4AV MS-6712 Ver 10A motherboard
Open the link provided; http://www.directron.com/installusb.html
You will need to scroll down until you see, Intel Standard USB header Layout. Also see: Common USB case header connectors.
Hope this is what you're looking for.
Cheers'
Mike
Feb 07, 2010 | Intel Motherboard
I Need MS-6712 Ver:10A Motherboard driver to download
my system mother board is MSI N1996. After formating my system mu audio and vidio drivers ane not working. I dont have any CD also. Can you slove the problem.
Mar 13, 2009 | Intel Motherboard
4gigs ram
Switch sticks around in various combinations (2 gig in slot one, 1 gig in slot two, switch, try other stick, etc) and see if it is the memory or the motherboard.
Sep 10, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Radeon graphics card and 3rd RAM slot conflict
I thought this board looked familiar to me. I recall some rules for the memory cards. Do all your memory cards meet this requirement:
Supports up to 3GB PC1600/2100/2700/3200* DDR SDRAMs
If you are using DDR 400 you can only use 1 slot.
What kind of memory are you using?
Jul 05, 2008 | MSI KT4V (MS-6712) Motherboard
My msi vis p4m800 motherboard don't support two ram
Hi, does your board have 2 diferent color RAM slots?
if it does you must install the RAM in the same color slots.
If not then you have the option of buying a 512 stick of RAM and installing that as a quick fix. The other alternative is to have your board tested by a technician.
Regards mistyman
Oct 15, 2007 | MSI KT4V (MS-6712) Motherboard
Intel Motherboard Logo
325 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
