Question about Home Security
I am attempting to repair a Digimerge VCE 308301 (the 8 channel network DVR system) The client is able to view the setup menu but unable to to get an output signal from the cameras. The system runs it is in record mode -the record indicator, date, and time are visible on the screen- however the multi-play display screen for each camera is blank. Is the main board's (DNC1109) and daughter board's (DNC2103)video card fried? How do I obtain a schematic on the system? Thank you. Respectfully yours- John- Ash Creek Computer Repair
  • 794 Answers
The problem did not have anything to do with the DVR (Digimerge VCE 308301). It did however, have everything to do with the cameras' power supply system.
First, I contacted the company's (Digimerge) tech department; and they were of no help since the DVR system is obsolete. There are no replacement/spare parts available; e.g. mainboard and daughter boards...and of course, they don't have schematic diagrams for the DVR either. And due to its obsolesence- there is no tech support. (It makes me wonder why, though, how security and electronic vendors can in good conscious sell this obsolete model DVR for $1,400 and upwards of $2,200.00 to the unsuspecting consumer/end-user.)
Since I was able to boot up the DVR system and access the BIOS menu; and considering that the screen was showing that it was in record mode- and the system BIOS was keeping the proper date and time, I believed that there was something else going on with the security system.
I contacted the customer and went out to their home- as I was about to hook up the cameras to each input behind the DVR- by happenstance, I checked the power supply panel to make sure that the power supply had been turned off (which the home owner failed to do). Having turned off the cameras' power supply, I then made all my camera hook-ups to the DVR. When I turned the power supply to the camera system on, I was able to get a video signal, hence a nice clear picture. I did check the voltage draw on each power terminal at about 12.5 vdc and a visual check on the infra- red led's on each of the security cameras were lit.
Problem solved, right!?...WRONG!
Several hours later, I received a call from the homeowner that his security system was not working again. The first thing I noticed as I pulled into the customer's driveway was that all the cameras' infra-red led's were out. I immediately placed my volt meter on the output side of the transformer at each of the cameras' power terminal- and waddya' know- I was barely reading over 1 vdc. Apparently- over time, the transformer starts to overheat and the voltage drops out. After it cools down though, the voltage resumes to 12.5vdc to power up the cameras.
This is my first experience working on a secuirty camera system so I hope this has been as much of a learning experience for you novices as it has been for me!
Posted on Oct 02, 2009
What do I put on the app for android phone in space DVR title.server port and do I use my email for user name?
DVR title you can use DVR
server port you can find at dvr setup menu in network category
user name can use admin
Mar 04, 2015 | SWANN H264 4 Channel Dvr 4 Ccd Cameras...
It tells me I cannot access the dvr at the shop to get live view. How do I fix this problem?
Check the connection from the DVR to the router. You may need to reset the router.
Oct 14, 2014 | Home Security
How can I view a backup video from a USB on my laptop
You cannot. You can setup on your network and use Internet Explorer to download the video via a network connection.
Sep 27, 2014 | Samsung SDE-4002N 8 Channel DVR Security...
How do i reset password for h264 dvr
Hello, There are two things you can try, the default password for the system should be 000000. If that is not the password if you go into the System Menu under the "General" tab there will be an option that says Factory Defaults, this will reset the settings to the default and should remove any password that is in place, but be warned that this will possibly wipe the dvr.
May 08, 2014 | Digimerge H264 16 CHANNEL DVR WITH USB CMS...
Cctv
Use Free DDNS Services
Create Free account.
Visit:- https://www.noip.com/ CCTV Networking Technical Support
Dec 25, 2013 | Digimerge H264 16 CHANNEL DVR WITH USB CMS...
Disc for digimerge model number dhu516251
http://www.digimerge.com/wp-content/uploads/2011/06/DigiClient-v2.14.11-for-the-DHU500R-Series.zip
The digimerge website has the download info under "discontinued" tab. This link will get it installed on your laptop for you.
Nov 27, 2012 | Digimerge DHU516251 16 Channel Pentaplex...
Need help please. I have a Digimerge DH200 DVR with one camera. I've set is up and can view my camera locally over the internet and on the CMS DH software. Now I need to view it remotely. I have a
I have the ame problem. also need help with email setup. digimerge will not help. horrible co. they say I have to pay a tech to come out. no support whatsoever.
Oct 12, 2012 | Computers & Internet
I have a H.264 DVR with system V2.00.R05. What app or system can I use to view on a iPhone 4S?
IP CAM VIEW found in the Itunes Market: http://itunes.apple.com/us/app/ip-cam-view/id471794610?mt=8# should work as long as you have the network settings properly configured in both your DVR and Home Network. I recommend setting a Static IP for the DVR on your Home Router. After you have assigned the IP goto the network settings on your DVR and input the IP Address you assigned, the SubnetMask of your Home Router(usually 255.255.255.0 or 255.255.252.0), and the Gateway of yourHome Router.(i.e. 192.168.0.1/192.168.1.1/192.168.1.254). While you are on your Network screen I recommend changing your default TCP Port andHTTP Port to something that is not commonly allocated. As with most Routers you must Create a pinhole in the firewall to allow the outside traffic in. Select your DVR's IP on your Router and Create Definitions for both Ports that you set on your DVR's Network Menu. If your DVR and Router didn't reboot after saving these changes reboot.On the phone ap I found the following two cameras to work with the H.264 DVR System V2.00.R05:
  • Make: Unknown Brand Model: DVR-9008HV
  • Make:A.V.Sistemi Model:A.V.Sistemi 61xx DVR
For the Host/IP field, You use your Home Routers Internet IP. TCP port is the number you set on the network menu of your DVR. Ch.# is the Channel Cam (1-8, and 9 being a single feed of all 8 channels)user names and passwords are case sensitive.
I hope this helps
Jul 07, 2012 | Apple iPhone 3G
How do i store an event ? LOST THE MANUAL
Strangely enough, its right here on Fixya!
http://www.fixya.com/support/p910122-digimerge_dhu516252r_16_ch_5plex_networ/manual-36440
Feb 01, 2010 | Digimerge 8-CH DVR 5PLEX W/DVDRW 500GB...
Home Security Logo
376 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
