Question about Saws
I have a engine on my sawbench which is rated at 3000 r.p,m thepulley on the output is 6 ins .what size pulley do i need on the saw to make it turn at 800 r.p.m.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
The RPM's of the motor x the size of the pulley (3000rpm x 6inchs = 18000) = the output RPM's of the drive x the size of the pulley (in this case 800rpm x D ) Diameter would = 22.5 inchs.
Basically:
3000 X 6 / 800 = 22.5
You will have to change the pulley size on the motor to a smaller pulley. A 2" pulley on your motor would require a 7.5" pulley on your drive. Or you could use two belts to reduce the size of the pulleys even more. If you halve the RPMs to 1600 first from the 2" pulley you would need a 3.75" pulley followed by another belt hooked up to a 4" pulley to get your 800rpm. Hope this helps.
Posted on Oct 16, 2009
Getting gas and fire but just turnes over like there is no fire at all
which engine, they work different.
you saw gas where.?
you saw fuel where??
you saw something turn, what?
try this.
it cranks robustly (250RPM = robust)?
the engines cranks over, (i see pulley spin fast on crank)?
the engine fails to start and to RUN (sustained).?
you lost spark to 4 or 6 clingers, all are dead spark?
so you place the diagnostic jumper wire and crank for
5seconds
and release the key,
got DTC error codes, bingo.
if not bad spark is bad coil or bad ignitor that drives said coil.
next is fueling but above is all first.
fuel is always LAST. (ECU cuts fuel for many reasons) ask.
Feb 16, 2014 | 1992 Jeep Wrangler
Husky thd750 wet saw changing blade
If this is the K750 cut off saw, then to change the blade you need to remove the 13mm fixing screw ( anti clockwise )if you cannot hold the old blade to remove the screw, insert a 6mm pin into the right hand belt cover, there is a hole to tale this, this will engage into the pulley and lock it, then remove the outer flange, the old disc will now come away, make sure the new disc has the same size centre as the old one, the size will be on the rating plate on the cutter guard.
Oct 29, 2011 | Garden
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    I have a model VT 618902aj, its from 1996. What are the pulley sizes supposed to be? Is this unit matched with the present unit mentioned? Thank you
    The pulley on the compessor only came in one size ~ about 10 inch. The motor size pulley would depend on the speed of the motor. To get a good volume of air, the pump needs to turn about 800 to 1000 rpm(most pumps have max rpm at that range, good idea to check ). Gas engine turns at 3000 ~ 3600 rpm so use about 3" pully or determine by counting the number of turns of motor/engine to make one revolution of the pump. Electric motors will turn 3450 or 1725. Choose pulley to turn pump at desired speed below max pump rpm and capacity of the motor.
    Aug 20, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
    Apparently the serpentine belt was thrown off my 1998 Mercury Mystique. It appears in good condition. Should it be replaced or can it be reused? Also, do you have a belt diagram? Thank-you.
    You can reuse it. But you need to find out why it was thrown off. Check all the pullies by grabbing them and checking for side to side movement, With the exception of the power steering pump pulley (which has some in and out play) they all should have no play. Just turn in nice smooth circles. Sorry I don't have the diagram, but there should be one under the hood. Sometimes on the bottom of the hood.
    May 22, 2011 | Mercury Mystique Cars & Trucks
    Change the water pump. what size is the bolts
    Location, size and torque specification for the water pump bolts-3.0L OHV engine...
    • Install the bolts in the water pump housing.
    • Tighten bolts Nos. 4, 5, 6, 7, 8, 9 and 10to 15-22 ft. lbs. (20-30 Nm). Tighten bolts Nos. 11, 12, 13, 14 and 15 to 71-106 inch lbs. (8-12 Nm).
      The bolts are of different lengths and must be installed in the correct locations.
    • If equipped, attach the engine control sensor wiring to the locating stud bolt.
    • Hand-tighten the water pump pulley retaining bolts.
    • Install the accessory drive belts.
    • Tighten the water pump pulley bolts to 15-22 ft. lbs. (20-30 Nm).
    • Connect the heater hose to the water pump.
    Hope this help (remember rated and comment this post).
    Apr 10, 2010 | 1999 Ford Taurus
    I have a 20 year old table saw of unknown manufacturer (but all machne parts are metric). The spindle pulley (mounted on motor spindle - it accepts v-belt from motor pulley) keeps coming loose. i think the...
    Simple, there are two options:
    1) buy a new pulley from any hardware or home improvement store.
    2) If threads are stripped from pulley, either retap with next larger size tap, or redrill new hole and tap with same size as the current size. Note the best way to keep pulley on is to have a set screw over the key and another at 90 degrees from keyway. Note 2 - Are you sure current pulley does have two set screws?
    Jun 26, 2009 | CMT Saws
    What size a step pulley required for the motor ?
    rpm_chart.jpg?t=1236890602
    here is the chart you need to answer your question. please mark this as a fixya! thanks
    Mar 08, 2009 | Saws
    Proper Band Saw Blade
    I was just on Sears website and if you go to the bottom of page you can link over to Sears Parts Direct and type in your model number and you should be able to get it online. Good luck
    Dec 17, 2008 | Saws
    Saws Logo
    66 people viewed this question
    Top Saws Experts
    Tom Chichester
    ray gallant
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a Saw Expert? Answer questions, earn points and help others
