Question about Car Audio & Video
Will load cds, but each time get a message that says "bad disc" and ejects. Have tried all the slots (6) and different factory CDs with the same response.
  • parsons219 Oct 01, 2009
    I will try hope this works, thank you.
  • 708 Answers
The head on the player is dirty and needs to be cleaned. Pick up one of those disks at walmart that cleans the head for you. they are fairly cheap.
Posted on Oct 01, 2009
I have a 2005 Jeep grand cherokee...with a 6 disc cd player. It has worked fine for 3 years since i bought the vehicle...(i used burned cds in it usually) and all of a sudden it will not play or read the...
this is a typical problem with the factory stereo. usually there is nothing you can do for the Cd player, because most likely a cd got jammed and broke or bent some internal components. however try usig a credit card to help eject. insert it partially into the slot and pull out if the cd tries to come out. if this doesen't work then you will have to have the cd removed by tearing it apart. this usually ends up with at least one or two scratched cds and a deck in a million pieces.
Jan 18, 2011 | 2005 Jeep Grand Cherokee
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
2007 Toyota Yaris Stereo Won't Eject CDs
you may have to use needle nose pliers to pull them out or remove the radio and open it up and remove them also take a look at the drive belt it may have broke, there are many electrionic places that will repair it if you remove it and take it to them, most of the one i run into broke a belt or 2cds were jamed inside it.
Mar 01, 2010 | 2007 Toyota Yaris
Jammed cds in a 6 cd changer ford ranger 2002
sounds like the tray inside was misaligned when the cd went in. and it probally sent the disc into a occupied slot. you will have to remove radio and disassemble to repair. also try just unpluging radio and plug back in. sometimes it resets the radio and will start ejecting the cds
Feb 05, 2010 | OEM Systems Car Audio & Video
6-disc Cd changer Mechanical Error
I talked to a dealer, all they could tell me is they have to send it to honda to fix it... a good 250$ for software fix...plus dealer will charge 50$ for each time they take the player out and in...
Jul 27, 2009 | 2005 Honda Accord
CD player (6 disc changer) "locked up"
Take it to the dealership, your G35 should have a 4 year bumper to bumper on it. They'll replace the radio under warranty most likely.
Jul 23, 2008 | 2005 Infiniti G35
2001 Mustang 6-disk CD player
does it give an error code? usually it just a gear timing problem, will it load discs that are in it?
Jan 02, 2008 | JVC KD-S680 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
