Question about Kenmore Ovens
What does a F2 mean warning mean on a Kenmore
  • Kenmore Master
  • 3,361 Answers
Replace the oven temperature sensor.
Posted on Oct 01, 2009
Oven will say F3 and shut down what does F3 mean no book?
Kenmore' F2 or F3 usually points to an open oven temperature sensor. If that is the problem, it's not an expensive repair.
Mar 02, 2014 | Kenmore Ovens
What does the code f2 and f3 mean?
my ove is in selfcleaning mode and is beeping f2
Feb 16, 2012 | Kenmore 47712 / 47714 / 47719 Electric...
What does the warning error F2 mean?
the f2 code means the their is a problem with the oven sensor
the sensor is a electronic thermostat if you know where to find in to check it unplug it and insert meter leads set to ohms setting, at room temp. the meter should show between 1060-1100 ohms (in the midsts of this heat wave it may be up to 1150 ohms) if the reading is higher or lower than that the sensor should be replaced
Jul 24, 2011 | Ovens
Hello. I have a Kenmore Ultra Bake, with push button control. After wiping down the panel it went crazy. The panel is now showing EO F2 and continuously beeping. I can use the stovetop, but can't turn...
Hi
Thanks for using FixYa. Error F2-E0 on your oven means that the keypad is shorted and to resolve this issue you'll have to replace the electronic range control/clock(ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Kenmore Ovens
I have model # 91140161792, While cooking I heard an beeping sound and got a F2 code. what does this mean?
F2 means the temperature sensor has gone bad. It is thin metal about 4 inches long. Inside the oven up high on the back wall. Unplug the oven before you remove it.
You can test it with A ohm meter. If it reads less than 1050 or more than 1150 ohms it is bad. If it reads OK the sires or EOC are bad.
Dec 25, 2009 | Kenmore Ovens
I have a kenmore stove and it keeps flashing F2, I have unpluged it, could you please tell me what is wrong with it
is it e1 f2 or just f2. usually f2 means you have a shorted keyboard you need a new keypad.
May 28, 2009 | Kenmore Ovens
EO F2 on our Kenmore oven keeps coming up.
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
May 15, 2009 | Kenmore Ovens
Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Mar 23, 2009 | Kenmore Ovens
What does f2 mean?
It is a oven temp too high code...check thrmeostat connection if ok, try unplugging or disconnecting power aprox. 1 min try again if F2 comes up again need to replace sensor
Feb 11, 2009 | Kenmore 47783 Electric Single Oven
Oven showing F2 fault
tire, if your model starts with 911. the code stands for an overtemperature condition. I would start with the temp sensor, this is the probe inside the oven cavity, part # 334300. You can ohm it out, should be around 1100 ohms at room temp. This is for model number starting with 911. Catriver..post back.
Apr 21, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
103 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
