Question about Neuros (40215 00) (256 MB) MP3 Player
Neuros II will not charge
I replaced the battery and had a tech look at the player - he found the center post on the power receptacle (where the barrel from the wall wart plugs into the unit) loose and soldered it. He verified that the power jack was good - power is getting to the board
but somewhere after that it's failing and not getting to the battery.
Hello, I'm looking for a replacement for my jeep cherokee 99, the current part number is Chysler P56041 629AD, I found a Chysler P56041 278AD, can this computer works ok with my cherokee?
THE PCM MODULE.
no country stated, the 728ad shows Europe. (why?)
"I found"
where, at ebay, at pick-apart, or ?
USA cars have 11 PCM for one engine. fact.
and 100s more world wide.
what a question, just a p/n
then you post to grand Cherokee and then text leaving out Grand.?
why?
i searched the part at jeep and is wrangle part, 629ad.
you do know that it must be reprogrammed to your car right:?
the pcms on cars can vary
by engine, trans opted , 4wd/2wd,and year.
federal PCM
Calif PCM
and mexico PCM
and 9 more. just for 1999
is yours 42RE for 45RFE?? tranny??? 30/32 RH? what?
post county (or state if calif)
post engine and year
post body and not contradict.?
post drive line, in car, tranny and if 4wd?
then we can match it up
or call jeep.com
they (jeep) will do this magical thing!
ask you the VIN.
and then look it up in their database.
and see ALL THE ABOVE even what radio is in it. of 5.
me, im a glass half full guy (hard knocks, reality stuff)
id not even believe the part in car is correct.
im too SAVVY !
i find out from jeep what it should have first.
not one matches the 4.0L in the GC.
the 629 posted shows this at jeep.com
JEEP WRANGLER 2.5L Power Tech I-4 Cyl., 3-Spd. Automatic 30RH 1998
JEEP WRANGLER 2.5L Power Tech I-4 Cyl., 5-Speed Manual 1998
JEEP WRANGLER 4.0L I6 Power Tech, 3-Spd. Automatic 32RH 1998
JEEP WRANGLER 4.0L I6 Power Tech, 5-Speed Manual 1998
(if true needs to be programmed to each)
the send number
56041 278AD
lands at.
(part not found, is this a non usa part?) im stumped
was fun to try.
but im stumped.
Mar 31, 2016 | 1999 Jeep Grand Cherokee
Dvd highlander has stopped responding to remote , used twice before no problem , batteries are new , and lil light in remote is sending ?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Jan 08, 2015 | Televison & Video
Craftsman Briggs and Stratton 675 series Mower fuse location
Is battery powered, did you try calling sears tech center for further info ?
i have found them to be very helpfull with mower problems.
Sep 12, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
Replaced the battery & now the radio/cd player
Your radio will need a code to reactive it because the power has been lost.
You need to post up the serial and part number of the radio - found on a label at the back so you will need to remove the radio from the dash to find this.
Make and model of radio and car also required. Then we can advise further.
Thanks for using fixYa.
Aug 26, 2011 | Car Audio & Video
I pod displays "connect to power" then shows
It sounds like your battery is bad. They can be replaced readily easily. Batteries an be found on eBay for as little as $5 and directions to replace it can be found here:
http://www.ifixit.com/Browse/iPod
Jul 26, 2011 | Apple iPod MA446LL/A MP3 Player
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Some things to check for when your player does not act like its taking a charge.
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
Haier dvd player model PBAT-118 battery pack does not work. where can I get another one?
Try contact Haier Tech Support here, they should have a replacement battery pack:
http://www.haieramerica.com/en/support
I have one of these units, and as yours, the battery pack quit working. I found out the electronic charging board it has inside is defective, it could be yours too.
Dec 30, 2009 | Haier Portable DVD Player PDVD7
The battery does not charge
My mother has one of these units, it was working fine until recently I took it to play with it, and found the same problem you describe. The unit works with the power supply (what some people call the "cord") attached directly to the unit, it works through the connector on the power pack itself, but the LED on the battery is not on as used to. I opened the battery pack and found it has an electronic board close to the power connectors, that board might be defective now, yours might be have the same problem. I'm an electronics tech, but I can't fix that board with surface-mount compontens.
Solution: Contact Haier to see if you can purchase the battery pack. In my case I could replace the internal charging board, if they sell it separate, which I doubt but never hurts try contact the factory.
Dec 09, 2009 | Haier Portable DVD Player PDVD7
Golden Tech Companion II: Doesn't go, batteries
Accessibility Specialists Inc
1815 Corporate Sq Blvd
Ste 200
Jacksonville, FL 32216
(904) 725-0601
Nov 21, 2009 | Golden Technologies Companion II Travel...
Apple ipod 8gb model no. A1236 EMC No. 2174 seril No. YM747CNXYXR can't charge the ipod
I would suggest agains posting your serial number on websites like FixYa.com
Sounds like a bad battery. You can get replacement batteries here http://www.ifixit.com/iPod-Parts/iPod-Nano
-=/ Daft Tech /=-
Oct 23, 2009 | Apple iPod nano
Neuros (40215 00) (256 MB) MP3 Player Logo
37 people viewed this question
Top Neuros Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Neuros Audio Player and Recorder Expert? Answer questions, earn points and help others
