Question about Toshiba Televison & Video
Wavy lines on the screen and a high pitch sound sometimes.
  • 336 Answers
If you have a Dlp it might be the color wheel.The color wheel is in charge of creating the colors and when it's bad you'll hear humming,buzzing,whirling sounds.
Posted on Oct 01, 2009
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
When turned on the screen is blank and makes a high pitch buzz
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
High pitch noise from speakers
Hello there!
Sometimes High pitching its just that, static on the area, like if you are near a microwave, or near other electronic equipments, but, if the skreetching sound keep going or even if you do nothing it could be a line inside the sound card, or you need to clean the volume botton with special electrical cleaner. other that these, its contacts, or bad cap for the volume board inside.
Good Luck!
Carl
Apr 25, 2017 | Acer Computers & Internet
Distorted picture with wavy lines..
SOUNDS LIKE A CAPACITOR GOING DOWN ON BOARD OPEN BK LOOK FOR BULGING HEADS
Sep 28, 2017 | Sony Grand WEGA KF60WE610 60" Rear...
Screen covered with wavy lines what can I do ?
if you are technical then open the monitor and see the primary filter big high voltage capacitor is expanded replace it problem will definatly solved
Mar 09, 2010 | Computers & Internet
High pitch sound coming from back of TV?
it could be either the coils on the yoke of the tube or the flyback. flyback would need to be replaced it that is the problem
Apr 19, 2009 | Curtis-Mathis CM19011 TV
High pitch whistling noise in engine compartment of 2005 envoy
There may be a small hole or cut in a vacum line or possibly just loose. Also make sure the air filter box and the big hose to it are secure and clamps etc are tight. Pulleys and belts can make a high pitch sound also.
Mar 22, 2009 | GMC Envoy XL Cars & Trucks
Sometimes screams a high pitched noise when turned on
the high pitch noise is from the HV. arcing acrss each other.
( the screen comes up at a pop).
I suggest get a better one. ( sorry! no domastic brand).
Oct 27, 2008 | RCA HD52W56 52" Rear Projection HDTV
Screaming acer!
sometimes if the inverter board (the part that drives the backlight) has a cold solder joint on it, it can actually generate a high pitched resonating sound (aka a screaming squeal sound)
if it's under warranty, have the manufacturer correct the problem.
if not under warranty, retouch the solder points on the inverter board, or have a repair tech fix it for you.
Jun 03, 2008 | Acer AL1916W 19" LCD Monitor
Loud humming or high pitch buzzing noise coming from my rca dlp tv 50 inch
I have a very high pitched sound and when I move the tv it will stop for a second or two and then start again. The sound sometimes stops all together. But very high pitch sound.
Aug 08, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Televison & Video Logo
95 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
