Question about Hilti Drills
How do i remove the chuck on a hilti dd100 core drill i was told you just knock out the pin but it dosnt seem to budge and its starting to get butchered
  • 2,176 Answers
Go to Hilti.com and type in your model number for an owners manual on this tool. It looks like it has a locking mechanism that you just need to pull back. Let me know if you can't find it and I will get more specific info, or you can call them at 1-800-879-8000 and speak with tech services for this
Posted on Oct 01, 2009
I have a tm8 hilti hammer drill the chuck seems to be unscewing from the spindle how do i take it off
Most chucks have a screw down inside the middle to lock the chuck on. Sounds as if that screw is loose, it should be a lefthand screw. once that screw is removed you can unscrew the chuck by putting an allen wrench in the chuck and hitting it with a hammer to loosen the chuck.
Feb 08, 2012 | Drills
How do I straighten a chuck bend off removing a jammed bit?
If this is a TE7 then the chuck will just pop off of the front end. You just pull the rear chuck sleeve foward to release the chuck. With the chuck off run the drill to see if the cylinder is bent. If you bent the cylinder it will wobble. If the cylinder is okay just order a new chuck. If the cylinder is bent then your best choice is to send it to Hilti and have it repaired by them. They have a ceiling on the amount the repair would be and you would get a warranty with the repair. It would be cheaper than you trying to buy the cylinder and replacing it yourself.
Hilti 1-800-879-8000
Glenn
Nov 11, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
I need to remove the chuck assembly from Hilti TE16 c
With the palm of your hand over the chuck where the bit goes in take your fingers and pull the black sleeve right at the drill casing and pull towards your palm. After you have pulled it all the way back just pull the whole chuck off.
Feb 07, 2011 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
How do i replace the jacob chuck on a hilti hammer drill?
Open the jaws of the chuck all the way open. Inside the chuck you will see a slotted screw. Use a large flat head screw driver and remove screw. It will have left handed threads.
After you remove the screw put the end of the chuck in a vise where the 6 flats sides are. Put the drill in low gear and reverse. Hold tight and turn on the drill. This should run the chuck right off the spindle.
Jun 28, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
How to remove sda cuck from hilti te2 110v drill
Manual for Hilti Te2 is here.
Per Page 11, "Pull the chuck release ring towards the front and remove
the chuck completely. When fitting the chuck, pull the
release ring towards the front and hold it in this position.
Push the chuck onto the guide tube as far as it will
go and release the ring. Rotate the chuck until it engages
and the ring snaps back into its original position |3|. The
TE-C interchangeable chuck or quick-release interchangeable
chuck may be tited to the TE 2-M with chuck
interface |2|."
If this helps, please vote. Thanks!
Jun 14, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Cordless Hammer Drill Sfh 151 A 2.0Ah: Hi, How do you change the chuck on the Hilti SF 15...
Hi. open the chuck to the max. inside the chuck you will see a screw. remove it. put the drill in reverse. hold the chuck. a vice may be needed. pull the trigger. this may work, however in my experience, they are very tricky to get off. I have never had a faulty chuck but have had many faulty gearboxes. i have had to buy ney chuck to fit with the new gearboxes because i couldn't get the good chuck of the damaged gear box. good luck.
May 05, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
Hilti TE 10 drill. It doesn't seem to hold the
Probably a missing ball problem---contact Hilti website.
Feb 27, 2010 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
Drills Logo
479 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
