Recently had my computer reformatted and now mouse won't work.The pointer is on screen but won't move. Is there a simple solution. I don't understand any technical jargon so it would have to be words of one syllable.
    Guru:
  • 355 Answers
Turn off the computer unplug the mouse from cpu on the computer then plug the mouse
Posted on Oct 02, 2009
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
The cursor jumps around on my ASUS K501J notebook.
Step 1
Step 2
2. Select the "
Apply."
4. Pick the "
Step 3
Oct 08, 2012 | ASUS K50IJ Notebook
My mouse isn't moving on the screen
Hi I had this recently do you have a small oblong button right below the spacer bar you might have pressed it by mistake, while dusting etc, this freezes the pointer, also on my previous laptop I had the same problem but no button, so that was fixed by closing it down, unplugging it, removing the battery and replacing then switching back on, very important though to unplug from the mains......
Aug 27, 2012 | Razer Rz01-00280100-r3u1 Naga Mmog Laser...
Arrow does not move on screen with remote mouse
you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have the options update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
don
Feb 20, 2011 | Logitech Cordless Mouse
I have a Dell studio laptop. Recently, within the
1. In order to fix this, you go to control panel > mouse
the last tab is called "Device Settings" click it and make sure you have "static tray icon in taskbar" selected.
(You can always remove this later.) Apply the changes and click the red coloured icon in your task bar. An option will be available called "Tap to click." Clicking it will enable you to tap with your mouse pad instead of the keys! Hope this helps you out, I know it helped my friend.
2.
In the Control Panel open Accessibility Options Icon and click Mouse Tab and than Setting.
To move the mouse pointer by using MouseKeys
If you have not already done so, turn on MouseKeys.
To turn on MouseKeys, open Accessibility Options, click the Mouse tab, and then select the Use MouseKeys check box. Use the buttons on the numeric keypad to move the mouse pointer. If MouseKeys doesn't function, press NUM LOCK, and then try MouseKeys again.
To move the pointer horizontally or vertically, press the arrow keys on your numeric keypad.
To move the pointer diagonally, press HOME, END, PAGE UP, or PAGE DOWN on your numeric keypad.
Notes To open Accessibility Options, click Start, click Control Panel, and then double-click Accessibility Options.
To specify whether NUM LOCK must be on or off for MouseKeys to function, on the Mouse tab, click Settings, and then for Use MouseKeys when NumLock is, click On or Off.
To change the pointer speed and acceleration when using MouseKeys, on the Mouse tab, click Settings, and then move the sliders to adjust the pointer speed and acceleration.
To temporarily increase or decrease the pointer speed, on the Mouse tab, click Settings, and then select the Hold down Ctrl to speed up and Shift to slow down check box.
Jul 27, 2010 | Dell Studio 1737 Laptop
Wireless Mouse a Problem
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Dec 25, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Not working
If you have windows 2000, xp, theres an Icon at the right hand side of the bottem toolbar that you double click on before you plug or unplug any type of device into your system.
Feb 05, 2008 | Belkin F8E882XBLKPS2 Mouse
Mouse cursor moving by itself
In windows xp go into start menu, then into control panel then click on appearance and themes, then move your mouse over to mouse pointers click on it , uncheck "enhance pointer precision, and click apply, that will stop the mouse from acting crazy, this will work with dell mouse pointers and most.
Dec 28, 2007 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Computers & Internet Logo
David Payne
David Payne
