Question about Gateway M275 Tablet PC
Red, Green, Blue, Gray, and Black Screen on Boot
I powered on my tablet, and the monitor isn't working properly. The whole screen goes red, then green, then blue, then gray, then black. It repeats after a while.
I can see my hard drive working, and if I log in "blind", I can hear Windows successfully log in. I could probably use it just fine, it's just the monitor keeps cycling these colors, like a test pattern. I think something may be wrong with my integrated video?
4 Suggested Answers
  • 133 Answers
SOURCE: blue screen of death
Try to reinstall windows by repairing it.
Posted on Mar 04, 2008
  • 3 Answers
SOURCE: About a month ago my screen on my laptop would
Sounds like one of two things. Either your connection wire from the screen to the hard drive is lose most of the time you can go on the product sites enter the info on the underside of the computer enter that info on the products site and get your info from the help self section or the repair diagram. Number 2 is your screen has a bad wire and it needs to be replace you can find them new on ebay and most of the time it is easy to fix yourself. I hope some of this info helps you.
Posted on Jul 14, 2009
  • 12 Answers
SOURCE: FixYa solutions for every thing Resent problems
your best bet is to backup your actual data on the tablet. Then do a fresh install (formating the drive) instead of repairing. This should let the install go through 100%. If it doesnt then i would look into it being a HD issue. But its better to do the fresh install first. Usually does the trick
Posted on Mar 07, 2011
How do I unlock my tablet
If it's android then you can reset it but you will lose all the apps you installed along with any saved passwords.
power off the tablet by holding down power until screen goes blank.
hold both the power button and the volume up button for at least ten should boot to android logo...then a robot with red exclamation.leave it alone until the option to reset screen appears.
follow onscreen instructions to reset.
Jan 26, 2015 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet
Oct 27, 2014 | Tablets & eReaders
What is wrong with my tablet???
Hold the power button down for like 20 whole seconds or longer-let go of the button, and then try to start it.
May 18, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
My tablet is stuck on a green screen with the green words android along with a flying green android
switch off tablet and keep pressing the power button a bit longer. Remove battery and replace it after 2 minutes. Switch on the tablet. Good luck
Dec 03, 2013 | Tablets & eReaders
My toshiba tablet won't let me go past the welcome screen
If this is under warranty take it back. If it isn't power the unit on with just the battery powering the unit. When you see the Windows splash screen drop the battery out after the screen goes black put the battery back in and press the power button. This should bring up the on screen menu telling you it failed to start or shut down correctly. Select, Boot in Safe Mode and see if the system will power on. If that fails you need to do a system restore. To access system restore options power the unit on and press and hold the F10 key, this will bring up the restore Windows options. From that menu select to restore your operating system. If that fails you will have to do a complete restore to factory default settings. If that fails you will have to replace the hard drive.
Dec 25, 2011 | Toshiba Tablets & eReaders
I just bought new lcd display for my Toshiba Satellite R10 Tablet. The inverter is fine, checked the cables and reconnected. But the screen alternately flashes solid white, red, green and blue on the...
you need to download the proper drivers for the Graphics Card Right click your desktop go to settings go advanced Go to the intel(R) tab and hit Graphics Properties thin pick' either Dual Display Clone or Extended Desktop and Click Apply.
Wierdly the Monitor 2 will Still he greyed out in the settings Tab but the monitor will display Good luck
I'm currently trying to figure out it I Can Rotate the tablet Monitor and keep the other monitor Un-rotated Any ideas?
Oct 19, 2010 | Toshiba Satellite R10-S802TD Tablet PC
Can't boot
Have you tried changing the boot order in bios? press the F8 key (usually) when you boot up. Set to boot fron CD. Then reinstall operating system
May 29, 2010 | Toshiba Portege M400 PPM40U01000E Tablet...
Either while on or off the docking station the tablet itself no longer seems to illuminate or boot up. The battery also flashes a depleted red. I an assuming with A/C power attached this battery shou
please let me help. the ac adapter will plug into the back of the latop.
check lights then if red light still on after one hour plugged in then you need new battery.try this if two green lights only on after, you do not need battery.
you can sometimes find them on ebay...
hope hlps...let me know
May 16, 2009 | ViewSonic ViewPad 1000 Tablet PC
Gateway M275 Tablet PC Logo
Top Gateway Tablets & eReaders Experts
Ricky Ostrom
Ricky Ostrom
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
