Question about Kodak EasyShare MD853 Digital Camera
Pink Glow with bright white spot
When I turn on my camera the screen has a pink glow to it with a bright white spot in the very center. The screen is also a little blurry. If you take a picture it shows up as pink with lines down the picture. There is not anything distinguishable about the pictures.
  • 10 Answers
SOURCE: m853 pink lines pink pictures
you may just have to take the cost of repairing or replacing it. for ashleyyy x0 and angela1178 if your screen only shows in pink no matter if your looking to take a picture or video or look through the menu the damage may be to the screen. for ginawell it seems there is damage to the data streaming from the lens to the lcd screen.
Posted on Jun 25, 2008
SOURCE: Kodak camera has blurry pink display when taking pictures
mine has the same problem. it's less than a year old. nothing in the manual mentioned these kind of erros.
Posted on Apr 25, 2009
mail2pvs
  • 390 Answers
SOURCE: Anything bright on outdoor pictures turn out pink
my first guess WB setting
pls change the White Balance setting to normal and check if you have the problem rectified
cheers
pls rate if it was any help
Posted on Jul 04, 2009
SOURCE: pictures are pink with lines
The camera is a wonderful Kodak product and takes beautiful 8.5 Megapixel photographs. When you save the pictures to an SD card, you must at some point remove them digitally from the card.
Either by linking it to the USB cable and going from there to your PC, OR by removing the SD card from the camera and inserting it into an SD card slot in your computer, printer, or card reader. Occasionally the card readers such as the ones in your PC, printer, or card reader devices do not connect properly and will only transfer part of the data, resulting in pink ugly lined photographs. This problem can be fixed by using the USB cable instead of the built in card readers in your other devices.
Posted on Jul 06, 2009
drifterK
  • 4924 Answers
SOURCE: my kodak easyshare M753 has pink tint and lines
its obvious a malfunction that didn't occur by bad handling ..and if the device it is still in the warranty period , my advice is to go for it if you never open it or other things that you wouldn't suppose to do
Posted on Jul 15, 2009
Whirlpool oven wont start, is there away to light the pilot?
You don't say what model you have. That being said, I highly doubt it uses a pilot light. It most likely uses a glow bar igniter to ignite the gas. Take the bottom of the oven cavity off (remove the racks and you'll see a couple screws in the back on the bottom. Remove those and the bottom of the oven cavity should lift up).
Once you have the bottom cover off, turn on your oven and watch the glow bar. If it glows bright white, it's good and your gas valve is most likely bad. If it doesn't glow at all, or it's not very bright, or it has one bright white spot on it and the rest of it looks a little yellowish orange, then you need to replace the glow bar igniter.
Anyway, that's where I'd start.
Nov 04, 2014 | Whirlpool Ovens
Samsung LCD TV 46 inch model LN46A550 has bright pink glow where it should be light (sky, lamp, etc)
My guess would be that you have a CCFL lamp that is failing. They will give off a pinkish tint when they are about to fail. But I would encourage you to get a professional diagnoses.
Oct 03, 2012 | Samsung LN46A550 LCD TV
Fuel pump not turning on then week later worked for about an hour then stopped, replaced ccrm did not work.
the best way first is to remove the gas cap and listen as close as possible to the filler neck while you have someone else cycle the key from off to run ( the fuel pump will only run for about 10 seconds when the key is turned from off to on, unless the motors running and if it would run I know we would not be here ) you will hear a buzz sound if the pump runs, if not get yourself a test light and gain access to the inertia switch, which is in the trunk on the left side possible behind the trim panel, its at black plastic switch with a red button in the center and two wires,ones pink with a black tracer and the other should be dark green with a yellow tracer. locate your self a good ground point for your test light clamp and hook it up, (its very important that you find a good ground point or it will cause you to get false results causing you to replace unnecessary parts)now once you have a good ground spot take the other end of your test light and back probe the pink and black wire,now have a assistance cycle the key from the off to the start position while you watch the test light, if everything's right you should see the test light glow for ten seconds (if not check the # 13 position fuse in the fuse box under the hood) if your test light glowed in the last test, now move your test light probe to the dark green and yellow wire (the other wire on the switch) and recycle the key, you should again see the test light glow for ten seconds,(if not and you had a glow on the last test either your inertia switch is trip or bad) if you find you had a glow on the pink and black wire but noting on the dark green and yellow try depressing the red center button on the inertia switch and retest if still noting and you had a glow on the pink and black wire, replace the inertia switch. if you found that you had a test light glow on both sides of the switch your fuel pump is bad, the only other possiblity is the wiring between the inertia switch and the fuel pump, which is a very limited amount of wiring and I have not seen it before. hope this helps,let me know how you make out
Jan 11, 2011 | 1996 Ford Thunderbird LX
Screen blury,very pink,green edging on picture almost colorless!
This would be a convergence issue you can run the convergence setup that is in your user manual if that does not work you are going to need service.
thanks
Sep 17, 2009 | RCA HD52W56 52" Rear Projection HDTV
Pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Jun 02, 2008 | Televison & Video
Canon A720 IS
This is normal and not a malfunction.
It is caused by the bright light and will only be recorded in video mode.
Try to keep your camera aimed away from bright spots. There is nothing you can do to completely avoid the pink lines, but just be reassured that there is nothing wrong with your camera.
Hope this helps!
Mar 22, 2008 | Canon PowerShot A720 IS Digital Camera
Exilim ex-v7
You need to send your camera in. This is something that can't be fixed at home. Call repairs at 800-706-2534 option 2 and they can tell you where to send it.
Mar 11, 2008 | Casio Exilim EX-V7 Digital Camera
Minolta Dimage X1 Pictures have a pink tint
This is a CCD problem There has been a recall across a range of makers and modeles - that have used a certain CCD- Yours could be one of them Try the makers website - technical support team
Jul 20, 2007 | Konica Minolta DiMAGE X1 Digital Camera
Monitor shuts down and glows pink
You could try updating the drivers for your monitor and for you video card. It sounds like their could be a hardware problem. When something warms/heats up the connection is made. A pink glow isn't a good thing. Make sure you check all cables and even try to adjust the actual monitor settings Your heat settings for the colors may be out of whack. Last question? Does slapping it a little help? Good Luck. Let me know what happens. Tim
Feb 19, 2007 | Samsung SyncMaster 750S 17" CRT Monitor
Kodak EasyShare MD853 Digital Camera Logo
44 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
