Question about Singer 7462 Mechanical Sewing Machine
Singer model # 6412 the bobbin case pops out of the machine. Would a class 15j bobbin work ? I tried a new bobbin case and that didn't help.
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Posted on Aug 01, 2010
bargainbox
  • 1388 Answers
SOURCE: Singer Concerto sewing machine model 9217
Are you certain you are using a singer bobbin to suit this machine ?
If you have gathered a collection of bobbins over the years and have just grabbed "any old one" it may have different depth and diameter.
If this is the old 9217 that has a self winding bobbin, it is even more important to get it right.
It is almost always necessary to match the bobbin to the machine to avoid problems.
Also ensure that the bobbin is sitting comfortably, not at any angle, and that the hook race surrounding it is clean and free of lint deposits.
Singer UK has a few diagrams & info that may be helpful ....here
Posted on Feb 17, 2008
  • 3 Answers
SOURCE: bobbin case is popping out, and machine is birdnesting
Usually when this happens the bobbin is in wrong, replace it make sure the thread is going out the right way, make sure there is no lint or small pieces of thread around or underneath the bobbin area. Make sure you thread it with the foot up. Also make sure you are usng the right bobbin for the machine. They can easy get mxed up.
Posted on Jun 20, 2009
  • 6 Answers
SOURCE: The bobbin case on my Singer Inspiration 4210
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Posted on Mar 21, 2010
chrismyers67
  • 53 Answers
SOURCE: how do i replace the bobbin case in singer machine
When you insert the bobbin case, make sure the "knub" on the bobbin case (#1) is just to the left of the position finger bracket (#2). It should sit in there nicely and you should be able to spin the hand wheel freely.
Let me know if you need more help,
Chris
Posted on Jun 07, 2010
What bobbin should i use
contact this site thru the link and ask them about the bobbins
Hazlet Sewing Machine and Vacuum Cleaner Store New Jersey
Dec 17, 2014 | Singer Sewing Machines
What bobbin needed for singer perfect finish ET-1?
Looks like your machine is using a Class 15 bobbin. A wide variety of machines use the same bobbins, and they're available inexpensively.
Sep 05, 2014 | Singer Sewing Machines
What is the bobbin size for the 7258 Singer Sewing Machine
Your machine appears to take the 15J bobbin. I have several machines that call for that bobbin, but I have found in all of them that I can use the Class 15 bobbins, also referred to as Class or Style A, as well--they're interchangeable.
Jul 06, 2014 | Singer 2932 Mechanical Sewing Machine
How to tighten bobbin tension
Are you using a 15J Bobbin on the 1120 machine - I thought my problem was the bobbin tension as well until someone posted that I should be using a 15J bobbin - I was using a 15 bobbin which looks the same as the 15J but they're not the same - 15J is a little taller than the 15 - and it was causing the thread on bobbin to knot up and break - once I got the 15J bobbin I could see the difference when dropping the bobbin in the case - the 15 was just a little smaller and shorter but that was the cause (also make sure you're loading it to rotate clockwise not counter-clockwise - the 15J fits correctly - problem solved - WalMart carries the 15J but they're sold out a lot so just keeping checking back - I think Hancock Fabrics carries them also - when I find them I just buy several packs to have on hand - you can also order them online from Amazon - if you're already using the 15J bobbin then the screw on the bobbin case can either be tightened or loosened to adjust the tension - just have to keep adjusting a little at a time and use a scrap fabric to see which way you need to go till stitches look even. Hope this helps :>)
Apr 29, 2014 | Singer 1120 Mechanical Sewing Machine
How to thread bobbin in singer 6412 model
singer has a free pdf manual to download
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 6412) & click search
Jul 11, 2012 | Singer Sewing Machines
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
What size are the bobbins for the memory craft 8000? I've compared the class 15 to my original bobbin but the class 15 has a ridge that my original doesn't have...the class 15J is more like the...
You need a bobbin like this:
You can puchase them from this link
http://www.sewingpartsonline.com/bobbins-janome-kenmore-elna-102261103.aspx
Janome have one standard plastic bobbin that fits almost all their models except
1600P, 1600P-DB, 1600P-DBX and MB4.
So if you see packets of plastic "Janome" bobbins for sale they will be the right ones.
Oct 08, 2011 | Janome Memory Craft 9000 Computerized...
Just purchased a singer Quatrum from hsn 9960 style i need exact instructions on bobbin winding a video maybe
Hi you can download a free manual from Singer.
http://www.singerco.com/accessories/manuals.html
Just type in 9960 in the search box and click on search.
It should give detailed instructions on winding a bobbin.
If this does not help, try this video from youtube:
http://www.youtube.com/watch?v=DlrTnW_FUqA
Aug 31, 2010 | Singer Quantum 9940 Computerized Sewing...
PLEASE GIVE ME THE PRODUCT # FOR BOBBINS FOR WHITE MACHINE MODEL # 2037. THANK YOU
Rebecca, I don't know if you ever received a solution, but after my experience with my White 2038, I would advise you to do exactly what you said. "Throw it out". I've struggled for a week with a new machine, found parts missing after opening the box and generally feel ripped off. I am throwing mine out! I purchased a Singer yesterday and it is sewing beautifully with no problems.
Good luck.
Jul 03, 2008 | White Sewing 2037 Mechanical Sewing...
Problem with bobbin case - new machine Singer CE 100
My problem is solved (I think...that is a knock on wood kind of thing). Upon recommendation from another Futura user, I remove and clean my bobbin case and I put a drop of oil in the little hole under my bobbin case about every 5th or 6th monogram use. AND, I pitched all of my bobbins that were 15 and not 15J (I had some that were 15 and they were the culprit as well.) I have had no more problem. It seemed the least bit of lint caused me a lot of birdnesting. I also stopped using rayon thread and use only polyester and bobbin fill in the bobbin. I have got to say I am thoroughly enjoying my machine these days. Please try these things before giving up on this so user friendly machine.
Nov 22, 2007 | Singer CE-100 Futura Computerized Sewing...
Singer 7462 Mechanical Sewing Machine Logo
368 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
