Question about Cameras
I have a EOS rebel xti. The viewing screen on the back of the camera is broken. I cannot see anything and it looks like it is cracked.Where is a good place in Minneapolis to get it fixed?
My Rebel xti will not display live view but will display shots taken - can you help?
This model does not have a live view capability. To compose the shot you must use the viewfinder and then you can check the result on the lcd screen. This the norm on semi professional and professional DSLR's
Jan 27, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Can I set a Canon EOS Rebel XTi up so that the picture I am taking shows up in the LCD?
No. You require a feature called live view and your camera doesn't have it. It's technically difficult to achieve on dSLR's and it's only a couple of years ago that it started to appear on some models.
Oct 08, 2010 | Canon EOS Digital Rebel XTI Digital Camera
I am desprately looking for a manual for a Canon Rebel XTi EOS camera? An e-mail download would suite me. Thank-you for your help
Manuals for the camera and all software supplied is here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=14256
The manual for the camera itself is the last one listed, titled:
"EOS DIGITAL REBEL XTi / EOS 400D DIGITAL Instruction Manual "
Mar 16, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
Have canon rebel xti digital 400d--how do i see live image prior to shooting on lcd monitor
This Canon model 400D or XTi does not have Live view capability in the LCD screen, so you cannot do it.
You have to use the view finder to select the image that you want to capture with it.
If you need a Canon DSLR camera with Live View capability, you need to try other different model such as the T1i or XSi.
Best regards,
Aug 18, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Camera works great, but there is no image on the screen
If you mean that you can't preview your picture on the LCD (like compact digital cameras), this feature was not available on digital SLRs made before 2007 (Canon calls this "live view"). The Digital Rebel XTi came out in 2006.
Jun 23, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon rebelxti
The Xti (400D) does NOT have live view. This was first introduced on the Xsi (450D).
May 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Lcd screen shows settings for camera not the image of what it is
EOS 400D/Rebel XTi doesn't have live view function, so you cannot see the picture you are taking.
Apr 04, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
Help! Cracked LCD display on Canon Rebel xti
Had the same problem myself, I purchased a new lcd from ebay (user name: ProphotoSD). He has tons of factory LCD's, cost around 90$. Please note that if you cracked the clear cover above the lcd that is a separate piece however it wont effect the lcd working (this piece is also replaceable). Then I found a simple tutorial for disassembling the camera body on google. Took me like 25 min, very simple job, just need a very small phillips head screw driver. Hope this helps!
Mar 21, 2009 | Canon EOS Digital Rebel XTI Digital Camera
New EOS XSi LCD don't work
You have to set the camera to "Live View" mode. Check your manual for settings.
BTW, it's usually a bad idea to use Live View mode unless the camera is on a tripod. With Live View you have to hold the camera out in front of you and it's much less steady.
Mar 18, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Black LCD screen/ not 'seeing' picture. Canon EOS 400D camera
Hi
The Digital Rebel XTi doesn't have 'live view' mode, you can't see what you're taking a picture of before you take the picture.
Thomas
Darntoothysam com - Digital camera parts and repair.
Nov 11, 2008 | Canon Rebel XTi / EOS 400D (body only)...
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
