Question about Gateway FPD 1730 17" Flat Panel LCD Monitor
Gateway FPD 1730 17 in. Flat... Problem
My lcd goes off green light stays on but screen only stays on for a second. Should I toss it or try something?
  • 1 more comment
  • tobacmon Dec 22, 2007
    I also have this same problem. I thought it was my PC and put another monitor on the same system ad that monitor work--Older monitor though.I also changed the VGA Cable and power cable and still no change.
  • bravsirrobin Jan 02, 2008
    ive had my monitor for a good long time now, several years, and its just now doing this. i will try looking at my graphics card to see if thats the problem...
  • Right Exec
    Right Exec Jan 04, 2008
    I have a 1730 that is just over a year old. It has always performed like a trooper, but has suddenly started to loose it's picture after a few seconds. The power light stays Green as it is supposed to but the LCD stops working. If I turn the monitor off and then on again, I get a picture for another second, then the screen goes black again. I have changed the power cord and the VGA cable and even attached it to another computer, but still have the same problem. Any suggestions?? Please???
    Problem Solver:
  • 10 Answers
My FPD1730 has just died. It is the power supply board. So if someone want to get together, one of us can have a good monitor. Anyone game? Best deal for me wins.
Posted on May 24, 2008
  • 3 Answers
Replace the Inverter Board if you can find one.....
Posted on Feb 22, 2008
    President:
  • 317 Answers
Try using it on a different computer, it's possible that it is your graphics card causing the problem. Check for bent pins.
Posted on Dec 20, 2007
Monitor just stopped powering up one day. Is there a breaker or something?
There is main power fuse in the power supply module, but if the screen flashes on for seconds, then the problem is in the inverter board due to bad caps (very common in this model): http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD1830/
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=fpd+1830+power+supply&um=1&ie=UTF-8&ei=y_-7S_uqDI628wTYvsDkBw&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CB0QrQQwAg
Hope my information will help you out.
Apr 07, 2010 | Gateway FPD 1830 18.1" Flat Panel LCD...
Monitor flashes on but with 1-3 seconds it goes to balck screen. I've replaced the electrolytic caps in the power supply, but it didn't help
Try different video and/or power cables, but most likely this is dead. Sorry!
If it's still under warranty, (or the computer it came with is), call Gateway support.
Mar 10, 2010 | Gateway FPD 1730 17 in. Flat Panel LCD...
Cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
Dec 01, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Dark screen of Gateway FPD 1520
If you can see the screen display an image upon close scrutiny, it could be that the florescent back light is burned out.
Aug 03, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Thin Green line from top to bottom of screen
Usually the case with this issue is the LCD panel itself. After a certain long period of time, some LCD panels just bug out and stop working. ( not sure why, possibly the way they were assembled and manufactured. For instance the LCD Panel has 8 connectors ((top)) and 3 connectors ((left)) (((Depends on model)))that attach to the main board of the LCD Panel, and on many occasions the thin lines wear and cut and therefore loosing part of your screen. If i explain further how it works i can write you a good explanation, just message me. That is the issue or the Cable connector from the Video Card to the LCD Panel is faulty. Try replacing that or the line will stay there for a long while then eventually your LCD display will begin to show more lines and eventualy Nebula itself. ( unusable )
You can also try repairing the LCD, in some rare cases the only problem when the line shows up is because of the video genesis card inside the FPD. try swapping that out with a known good one and perhaps that will work otherwise eventually the monitor will begin to stop working over time.
Jul 02, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Screen going black, green LED staying on
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the power supply or the inverter on your board, you can replace it and it will be fixed.
Easy Fix REALLY EASY FIX
(inverter is what supplies power to your backlights. A lot of the times the reason a monitor goes black and the green power button is on, is because the backlights shut off. in most designs of the 1730 the inverter is embedded on the power supply. That is most often the case on this problem. Power supply/Inverter=Replace it and you will have a spanking new looking nice monitor working again. :)
Jun 19, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Monitor will not power up
try makin sure all connections are secure
Apr 30, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
My monitor will not stay on. Gateway FPD 1530 15 in.
problem of smps some time it happen the power supply con't give the complet supply.
if still problem then replace RAM
or replace the display card.
Nov 17, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Gateway FPD 1730 17" Flat Panel LCD Monitor Logo
341 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
