Question about Royal Office Equipment & Supplies
Had a jam, turned it off, now the power goes on when put something in to shred, but the feeder feet do not go...help, please
    Genius:
  • 1,218 Answers
Try running the unit in reverse to see if the motor and the cutting blades turn....if they dont you probably need a new PCB...try contacting Royal at 1-800-524-0799 for parts assistance.
Posted on Oct 14, 2010
Clogged won't run
Simple UN CLOG But turn of Power first
Mar 17, 2015 | Office Equipment & Supplies
I emptied the shredder and now the red overheat/door open light comes on when I turn it on. will not allow me to shred anything. please help!
There is an interlock that prevents your shredder from operating without the bin in place. Something may be stuck inside, preventing the bin from closing the interlock. There also could be a shred of paper preventing operation.
Feb 17, 2015 | Compucessory CCS60076 - High Security...
Please help!!! I put a pouch into my scotch TL901 laminater the wrong way and it is completely Jammed in the middle of the machine!!! I used a flashlight to see how bad it was ad it is completely shredded...
Unplug laminator. If it does not open up -check to see if the machine has a pouch jam lever. The lever will make it easier to remove the jammed pouch. Put the screw back after you clear the jam.
Jul 12, 2017 | Office Equipment & Supplies
The shredder doesn't automatically shred anymore. How do I set it so the "eye" works and it shreds automatically without me holding down the button?
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 04, 2013 | Quartet gbc 5550X Shredder
When I put the paper in, and push the refill button, the paper goes down in the printer crookid, I need help does anyone know what I could possibly do?
Leading cause of paper jams or misfeeds is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Oct 07, 2011 | Lexmark X2500 All-In-One Printer
After switching my scanjet 8350 on i get adf jam clean out error help me to deal with it
The printer is telling you that the automatic document feeder is jammed. Try using a flashlight and look for any shreds of paper - no matter how small - in the paper path.
May 11, 2010 | Computers & Internet
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 7310
please check gear train and confirm no broken one-check of selonid not working in a right way and no foreign object droped inside(like pins).-check of smoth actuation of paper present detector.(in place and movement when you put papers
Mar 01, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Something is jammed
I was able to unjam an ATIVA DX 180 D shredder now the shredding blades won't turn but the motor is running.
Jan 08, 2008 | Office Equipment & Supplies
Motor not shutting off in Fellowes Powerhouse C-14 shredder
this is an issue with your paperfeed sensor. You need to call Fellowes at 1-800-945-4545.
Dec 18, 2007 | Office Equipment & Supplies
60 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
