Question about Toshiba 55H70 55" Rear Projection Television
Red is offset
I have a 55" big screen about 8 years. Lately the red seems to be offset from the rest of the subject on the screen. This is an intermittent problem and the offset is not always offset in the same direction on the screen. It's a pretty nice set yet and I would like to fix it if possible. Thank you for your help.
  • 205 Answers
Check out this link:
I offered some help to another person with the same problem and gave him a couple of good websites that will help.
I helped a friend with this problem. We fixed his set for about $25. The shop quote him $400.
Take a look and let me know if you need more help.
Posted on Dec 20, 2007
  • ohiotom Dec 23, 2007
    This is what drives me crazy about this website. Somebody (no idea who) comes in and votes "Thanks for Trying". If my suggestion is wrong then whoever voted should tell us why. Do they have the right solution? Maybe others would appreciate why they feel this way so they can solve their own problems. Just voting with no additional information provides no benefit to anyone.
it all depend how you want your Beef
• 120-130 °F (50-55 °C) Internal appearance very red; very moist with warm juices. Approximate cooking and resting time: 20-25 min./lb. plus 8-10 min. resting
• 130-140 °F (55-60 °C) Internal appearance lighter red; very moist with warm juices. Approximate cooking and resting time: 25-30 min./lb.. plus 8-10 min. resting
Medium (with a touch of pink):
• 140-150 °F (60-65 °C) Internal appearance pink red color; moist with clear pink juice. Approximate cooking and resting time: 30-35 min./lb. plus 8-10 min. resting
• 150-165 °F (65-75 °C) Internal appearance no pink or red, slightly moist with clear juices
taken from
Cooking Temperatures for Beef
Oct 30, 2016 | Cars & Trucks
Wavy green lines and offset during convergence calibration
There is whats called a convergence IC that is going bad inside this TV set. There is only one for all three tubes and the IC number is STK 393-11- and can be purchased here You will only need to order one. If you are handy and can solder this should correct your problem. One very important thing is, before you reinstall the new convergence IC, make sure you use a good coating of heat sink compound on the back of the new IC. If you do not, the IC will fail within a short time frames. Only if you are good with a soldering gun should you attempt the repair. If you are not, this repair should run you about 300 bucks or so. Also if you are handy, there are seven capacitors that go bad inside a board called the DM board. These will go bad very soon so while your in there these should be changed as well. If you need info on how to change these capacitors, let me know and leave an e-mail and I will send you the pictorial on how this is done. the IC change you will need to find that, but I do have a service manual if you need one also to help you along if you can follow the schematic. Good Luck
Nov 01, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Red screen(rear projector tv)
Most likely bad convergence amplifiers. They are soldered in components.They can become intimentent and the lines come and go, usually red or blue.
May 14, 2009 | Televison & Video
Samsung HCM5525W 55inch
This is a convergence problem. It happens to all big screen rear projectors. The convergence output ic's need to be replaced. I would let a repair man do this.
Nov 11, 2008 | Samsung HCM5525W 55" Rear Projection...
Powershot A80 problem: green and red lights around subject
Recharging the batteries seemed to solve it. Although I had not received the low battery warnning and this phenomenon had not occurred at other times when the batteries were low, it seems to have fixed the problem.
Jun 29, 2008 | Canon PowerShot A80 Digital Camera
Phillips 55' tv big screen
You should check and see if the red tube is showing any light. The green and blue make yellow when the red tube stops working. If it is showing red but looks dull, you will need to change out the fluid inside the tubes, as it is corroded. I will post a fluid change procedure on the repair tip for this set. I cannot post it here as they will not let me. They say it is too long. Go figure. They do not let you post what you want I guess.. Good luck with your repair.
Apr 26, 2008 | Philips 60P8341 60" Rear Projection...
Problem with red on one side
all you have to get to the convergence area to adjust that quadrant thats bad
Feb 01, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Screen now has 3 small boxes in middle - one red, one green, one white
Its easy to fix and cheap. Check for chip kits.
Nov 28, 2006 | Philips 9P5534C 55" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
35 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
