Question about Refrigerators
The fridge was leaking from the back... now the ice machine wont work. What could be the problem
  • milten1
    milten1 May 11, 2010
    is it still leaking?
  • 448 Answers
Or the (usually) plastic tube that connects to your icemaker at the back of the refrig. has become somehow disconnected or is leaking (which would account for the water, but if the tube were completely broken you would probably still have the leak) There should be a magnetic valve back there, probably near the bottom of the machine, that the inlet line hooks up to. It is activated by the icemaker to let water feed into the device. Sometimes they stop working, or leak. They can be replaced fairly inexpensively.
Posted on Oct 04, 2009
    Problem Solver:
  • 4 Answers
Ice line is froze and came apart from ice machine usally happens when there is not enough air flow try pulling fridge from wall 2 inches
Posted on Oct 01, 2009
Fridge leaking intermittently from the bottom
Sounds like your gasket may be going out. Consider replacing the gasket on the doors. Look for signs like small lines of frozen water that lead to the door or unexplainable excess ice in the bottom of the freezer.
I would also check for excess water in the condensation catcher tray, which may very well be located in the same spot under the ice maker. Depending on where you live (southeast, coastal, etc...) can have a strong contributing factor of having excess condensation, which will cause the tray to overflow.
Apr 25, 2017 | Kenmore Refrigerators
We have water leaking from the back of the frige, coming from under the area where the copper tubing connects from the wall to the actual refrigerator. I can't identify exactly what's leaking. I doesn't...
This can be an auto defrost condition. If your fridge is auto defrost, what happens during the defrost mode, ice build up is heated (in the area immediately near the evaporator coils, not in the main area) . This ice becomes water and drains out via a small tube, typically at the back or bottom of the machine. This water normally goes into a pan under the fridge, and evaporates without the user being aware of it.
If anything causes excessive ice build up (opening the door too much, door seal leak, etc.) then you get too much water and the pan overfills and spills out.
I suggest that you remove the pan from under your fridge, clean it, and put it back, and test to see if yo actually have anything wrong, or not.
This leak would NOT be refrigerant, as you would cease cooling if so. it is all condensation, which is physics and normal...
Mar 20, 2011 | Microwave Ovens
Ice maker has stopped making ice
Check the ice maker to see if there are ice cubes in the ice maker. If so, there is a problem with the ice maker heater and / or motor. You may be able to rebuild the ice maker by replacing defective parts, but it might be easier to replace it as a whole unit instead. If there is no ice present, it is likely a problem with the ice maker water lines / solenoid.
There are usually two solenoid valves and tubing systems for these types of fridges. One actuates on demand for water whenever requested, and the other operates automatically to make ice cubes until the ice cube reservoir is full.
Carefully push/pull the fridge away from the wall.
Unplug the fridge from the outlet.
Shut off the water supply to the fridge.
Remove access cover (usually the on the bottom) from the back of the fridge. Follow the tube that comes from the top of the fridge (for the ice maker) down to the bottom of the fridge.
Inspect visually for sources of the leak on tubing and related parts. Carefully check by hand for leaks in areas not readily visible - including the back sides of all the tubing, too. There may be sharp edges that can cut if not paying attention. If a leak is found where the tubing connects to other parts, you may be able to simply remove the tube and cut it back an inch or so if there is enough slack.
It may require that some special fittings and parts be obtained to reconnect and some compression type parts are designed for single use. If this is the case, gather the parts and bring them to a local hardware store for assistance obtaining replacements.
If a solenoid valve is found to be the culprit, due to a crack, etc. a trip to an appliance parts store will be required - unless able to purchase online. Part prices can vary widely , depending on the source.
Once replacement parts have been secured, reconnect after disconnecting power & water supply lines. When satisfied with the installation, reconnect power and water lines and test.
Carefully slide the fridge back into position - taking care to not crush the power or water lines.
Dec 31, 2009 | Freezers
Water problems for our fridge.
Assuming the water is on and the ice maker is working, check the ice/water controls, make sure it is not locked.  If the water is on, and the controls are not locked your valve is probably defective.  It is located in in the back of the machine where the water hooks up.
Oct 25, 2009 | Refrigerators
Ice machine wont dump ice on sears kenmore side by
Ice forms are 32 degrees but ice maker don't dump till 25 degrees. Get that guy back out there. Obviously you have a bad defrost heater.
Jul 17, 2009 | Refrigerators
Samsung fridge filter leaking
HI,
your drain is clogged.you may have a catch for your drain where you see leak coming from.that may pull off and you can see if their is trash build up in it.you are going to need to take the panel off the back of freezer.inside back of freezer you will see screws.they will need to come out,if you have ice maker that will need to be removed also.once back panel is off you will see your coils,beneath the coils it will most likely have a sheet of ice.tturn machine off and take a hair dryer and defrost the ice.once ice is gone take a cup of hot water and run thru drain to see if unclogged.repeat if drain is not clear.the ice in drain tube will eventually unclog.I use a steamer.much quicker.
thanks,
Mar 22, 2009 | Samsung Refrigerators
Heavy water leak in basement under fridge
Has this fridge got an ice maker???
Because ice makers require a water supply to make ice.
This could be where your water is coming from.
Jan 19, 2009 | Sub-Zero 650 / O Bottom Freezer...
Fridge running constantly and ice maker wont work
sound like it is low on freon ,,,, if so it runs all the time trying to get cold enough to shut down and it wont make ice ,,,, 1st check to make sure the fan inside is blowing, make sure the temp in freezer part is atleast +5 or below if it hasn't cooled right front the start then thats why they got rid of it ,,,,, leaking freon and it cost to much to repair that problem / larry
Nov 29, 2008 | Refrigerators
Water leak From Back Of Fridge
hi that small hose is going in to the ice maker. buy a small clamp at the hardware store, and clamp the plastic hose holder. thanks the appliance doc
Oct 16, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
