Question about Pix FUJIFILM Fine A920 Digital Camera
What does discharge means on a digital camera
Just got a new battery off Ebay..Installed in the camera and a red light came on..Does that mean that its charging or does a green light means that its charging?..Does the red light suppose to go off and...
Answered this one earlier-
The manual says that a red light is a charging error. Green means it is charging and the light goes out when charging is complete.
The camera must be turned off when charging the battery. They recommend a full 8 hour charge for a new battery, then allow it to discharge completely (leave the camera on I guess) and charge it again "before use".
You can download the manual from this page. Select the "Resources" tab.
Nov 05, 2010 | Sanyo Xacti VPC-T700 Digital Camera
I have a Sanyo T700 camera. Just got a new battery off Ebay. I inserted it inside the camera and a red light came on. Does that mean the battery is charging or does a green light mean that its...
It says to charge the battery and then discharge the battery before use. What does the term discharge mean.
Discharge means run the battery down until it needs charging again. I don't understand why the camera would say this. You can't use a battery when it is discharged.
Nov 05, 2010 | Sanyo Cameras
Does the red battery indicator mean the battery is charged or discharged.
It means that battery is low, or discharged. Sometimes it's caused by an uncharged battery, bad battery, or dirty or oxidized contacts. Clean the battery and camera contacts with a qtip and alcohol, and charge it up. If it still doesn't work, chances are that the battery is aged and needs replacement.
Good luck and hope this helps.
Aug 03, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Battery won't charge on my HP photosmart M407. Batteries are new. What else might be wrong?
It could be something wrong with the power board. If you have an external charger to charge the batteries. After fully charged tried to take as many pictures as you can. If the battery discharge fast, that mean something is wrong with the power board.
May 19, 2010 | HP Photosmart M407 Digital Camera
My finepix s1000fd will not hold battery charge. Cleaned the battery connects. New duracel batteries are discharged in an hour of being in camera on off. I tried new rechargable batteries and they will not...
Try using a different type of battery (not meaning *brand). Many newer digital cameras will only operate properly with high alkaline batteries vs other types. I was having the same problem with my Sony cyber-shot and found out that I had been using the wrong KIND of batteries all along. Hope this post was helpful to you.
Jan 27, 2010 | Fuji FinePix S1000FD Digital Camera
The camera will not turn on unless plugged into the charger that is plugged into the wall. does this mean that the battery is dead and wont work again?
If this is a rechargeable battery that has been charged many times or has been allowed to completely discharge, it might be dead.
Aug 29, 2009 | Sanyo Xacti VPC-T700 Digital Camera
The red led of the charger is blinking.Is the
I assume you charging battery in charger when it blinks.
This means the charger cannot charge the battery, as the battery has been left too long discharged & annodised inside...new battery required i'm affraid!
Aug 07, 2009 | Olympus FE-220 Digital Camera
Sony DSC-W90
NECESITO LOS DRIVERS PARA DESCARGAR LAS FOTOS DE MI CARA A LA COMPUTADORA
Jul 12, 2008 | Sony Cyber-shot DSC-W90 Digital Camera
Camera not charging
i got the same problem...it means battery is somehow discharging instead of charging..better get an external charger and remove battery from camera after every use.
Aug 08, 2007 | Samsung NV10 Digital Camera
Pix FUJIFILM Fine A920 Digital Camera Logo
Top Pix Cameras Experts
ka4iup
ka4iup
Andrew Taylor
Andrew Taylor
Are you a Pix Camera Expert? Answer questions, earn points and help others
