Question about Miele Novotronic Premier 500 Front Load Washer
Miele washing machine
I have a miele washing machine but ocasionally the red light come on )inlet light) then the washer stop .why is this please
  • Anonymous Dec 24, 2007
    I have a W1215 and at the rinse cycle only, the intake fault light flashes and the washer stops.
  • Anonymous Mar 31, 2014
    f3e error
  • 16 Answers
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Posted on Feb 08, 2008
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Miele washing machine w 487 check drain and check inlet
Clean out the pump trap. If you are on well water or just have very hard water, your inlet valve may be becoming constricted as well, remove the fill hoses from the back of the machine and shine a bright light into the valve to see if the screens are getting clogged with debris: In this case, follow the instructions the computer is giving you.
Apr 12, 2013 | Miele W487 Front Load Washer
Miele W828 Check inlet red light flashing
Just wanted to mention mine was retaining the fabric softener and skiping steps in the cycle and intake red light was flashing too. Once
I cleaned the draw and used a toothbrush to unblock the holes in the ceiling its working again perfectly. Miele Novatronic W 828.
Mar 07, 2013 | Miele Novotronic Premier 500 Front Load...
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Sep 05, 2009 | Miele Novotronic Premier 500 Front Load...
Red light flashing
red light is check drain?
Clogged by something.
Could be a coin.
Use to have large coin when i was young and forgot remove from my jeans. So mum made me repair that every time. In that case filter clean, but coin bloking filter inlet.
Not necesarily coin in your case.
never buy these deals over Ebay my advice.
If you have the machine already then this is first to look for.
Nov 16, 2008 | Miele W310 Front Load Washer
Check Inlet
where the water lines attach to the washer at the back un screw them and check the screens on the water valves see if rust or trash is restricting the water flow
May 24, 2008 | Miele Novotronic W1918A Front Load Washer
The washing machine wont start
This indicates either a faulty inlet valve, afaulty pump or a blocked filter Regards Engineer
Jul 28, 2007 | Miele W2240 Front Load Washer
Miele Novotronic Premier 500 Front Load Washer Logo
1,479 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
