Question about Sony Cyber-Shot DSC-S40 Digital Camera
DCS-S40 White LCD screen whats up?
Sony Cybershot DCS-S40 LCD screen is pure white any ideas on a fix?
  • 40 Answers
I posted a pic i edited.
this is a hardware issue that really has no perm fix. but is easily fixable with my pic.
Posted on Oct 19, 2009
SOURCE:
SOURCE: Sony DSC-S40 White LCD Screen - Permanent Fix
Needs a little brute force. Release all screws you can find. At the bottom above the o of the word Sony is a plastic lip (or clip) which you cannot see, but holds the camera together.
Do be affraid to pull a bit and it will come off.
Posted on Jan 10, 2008
  • 104 Answers
SOURCE: White LCD screen
sir, u replace ur LCD
Posted on Mar 24, 2008
SOURCE: White Display on Screen
I fixed the camera myself as follows:
1. Hold camera firmly in left hand
2. Smartly rap front of camera with knuckles of right hand on the "Cyber-shot" logo.
It worked, now the LCD is working again for free.
Guess I don't need to pay Sony $111.00 for repair service.
Best Regards .
M.R.Mohajeri - I.R.Iran
Posted on Sep 19, 2008
SOURCE: Sony Cybershot S40 has white screen.still sounds
This sounds incredibly stupid but it instantly works- I had this problem with both of my daughter's camera (same model number)
On the front of the camera, to the right of the lense and under the flash, it says "Cyber-shot". Press that spot really hard/punch it. The LCD should return instantly.
Posted on Jun 23, 2009
Black and white feature on sony
my sony cybershot dsc-w200 when i click on the camera the image dont exist its just white screen
Sep 27, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
Sony cybershot dsc-s40 lcd screen is all white
okay the lcd being white means its replacment of lcd time and not the camersa itself. But to rule that out try taking a pic if you cannot you might got a shutter issue as well.
Thanks hope the information helped
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 17, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Blank Screen
I have been facing the same problem with same model and this is permanent problem it seems with this model (Sony Cybershot DSC S40). It causes because of the following:
SYMPTOMS
LCD display is either blank or WHITE. When the cabinet is opened or LCD flexible cable is
touched, the symptom disappears. This is caused by connection defect or poor contact between connector and LCD flex cable due to the pressure or stress created by the rib in the front cabinet
to the connector.
Send me a email and I shall send you the solution (two files) received from Sony authorized person. You have to open the camera to solve this. Do not open the camera . Just get the idea about where the problem is. I never opened the camera even after seeing this solution 2 yrs back. However, I have a plan for going to service centre with this solution. I hope they can open the camera and solve this. But not getting time to go there in service centre.
I used the following temporary solution and it works to get LCD in its normal condition:
LCD looks like a rectangle is not it? Hold the camera in its normal position as you are going to take a picture (camera is switched on and you are not seeing anything in the LCD, which looks white or dull). Now GENTLY PRESS by the thumb of your right hand at a place near to LCD at the BOTTOM RIGHT CORNER of the rectangle (remember not on the LCD (rectangle) but just outside of it) until you see the normal colour of your LCD. Do few times starting with less pressure and then slightly increase it untill you see a normal LCD. I have been following this procedure for the last 2 yrs and not feeling to go for serving. (This solution I found in a forum only).
(mondal_ashok (at) rediffmail.com
Nov 16, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Best Regards .
Sep 07, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Installation cd for cybershot dcs-s40
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DSCS40&region_id=1
this is sony's driver for the cybershot dsc-s40 just chose your os
Feb 17, 2008 | Cameras
PLEASE HELP!
It sounds like the lcd is broken or loose. The backlight is still working properly, which is why you only see white. You could try to open the camera and push in the ribbon for the lcd, or bring it to someone who knows what they are doing. HOWEVER: if it is still under warranty, do nothing and send it to sony.
Feb 05, 2008 | Casio Exilim EX-Z57 Digital Camera
Are you sure you have the correct model number? Is it DCS-S40 or DSC-S40? - I think the latter model is correct.
Here is the link to download the software for the DSC-S40. You'll need to select the operating system of your PC.
If that isn't your model, please let me know and we'll go from there.
- Jim
Jan 29, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony DSC-S40 stuck lens, won't turn on...
About the LCD turning white, it an indication of a defective LCD, About the lens stucked-up its a lens problem, It will be solved if the LCD and lens assy's be replaced. thanks
Sep 08, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
White Screen + Stuck Lens
Turn the camara off and lightly tap on the front about 10 times the white screen will go away just tried it on mine a couple of min ago and it worked. don;t know about lens
Feb 15, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Lcd screen
My Sony DSC-S40 camera went from working fine to having a snowy white display screen and no shown images or data without anything to cause it happening. It was in a good safe location at my PC desk no humidity or high temperatures etc etc. It still took photos and I could still connect to my PC and download and view photos but the camera LCD display screen showed nothing but white.
I have just spent an hour on the internet and located the website below with link attached and I have also posted the comment there in quotes.
I tried pushing on the screen in all corners but no change.
I then did as suggested and gave the front of the camera a firm tap on the Cyber-shot logo with my index finger knuckle and hey presto the display is working 100% AOK now.
http://www.digiforumz.com/DSC-S40-White-LCD-Fault-Problem-ftopict10806.html
Post subject: Sony DSC-S40 White LCD Fault Problem
Archived from groups: rec>photo>digital (more info?)
From Davy
"After 18 months of use, and 6 months beyond the warrantee period, my DSC-S40
screen showed just plain white. I contacted Sony and was quoted 115 UK
pounds ($230) fixed charge to repair it.
Before sending it off I did a quick search of the internet and was amazed to
find that this is a common fault - the flexible cable to the LCD screen has
a design problem and tends to come loose. I was even more amazed to read
that the owner can easily fix it by rapping with a knuckle on the
'cybershot' logo on the front of the camera or pressing ******* the lower
right of the screen surround.
You would think that Sony would come clean on this and own up to its design
fault. I wonder how many owners have actually sent off for repair? -
probably not many cos the repair cost is priced to be just slightly higher
than the original price of the camera - clever! Its a bit ironic really cos,
although the camera had a lesser spec than competing cameras at the price, I
chose it because it was Sony and therefore I believed would be more reliable
and better supported. Seems those days are long gone!
Anyway if anyone else is having the same problem then that's the fix - but I
don't know how long for. A longer term fix is to remove the back of the
camera and push the flexible cable plug hard into the socket of the LCD.
But I can't find how to get the back off! "
May 03, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
280 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
