Question about LG DLE5955 Dryer
Had to change plug. ckd and is hooked up correctly. still no heat in lg dle5955w dryer. everthing else seems to work. any help?
    President:
  • LG Master
  • 1,922 Answers
Hi-limit switch/cycling switch/heating element, bad
Posted on Oct 02, 2009
LG Model DLE5955W will not heat, just had it repaired about 8 months ago. Is this a common problem.
is it a sensor or heatingunit bad.if lint isnt cleaned reg it will burn out faster also.
Oct 29, 2013 | LG DLE5955 Dryer
Just bought a kenmore 61202 dryer. Hooked it up - everthing works but I have no heat? It is an electric dryer
I would check to see if you have the correct voltage to the dryer at the plug in point. Also check the cord to the dryer with a meter to assure it is the same as the wall connection. It seems something is missing there.
Good Luck
Aug 28, 2011 | Dryers
My LG Tromm DLE5955W dryer has great airflow and heating but about 2 months after I bought it, it now takes 2 hours to dry a load of clothes. I have vaccumed it out and replaced the vent house already with...
You have a problem with the exhaust vent in the house walls. Try this. Disconnect the dryer vent hose from the back of the dryer and see how well it dries a load of laundry. If it comes out alright, then you know that the vent in the house is clogged and will need to be professionally cleaned out. Good luck
Jun 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Dryer model DLE5955W is not heating. When drying the "drying" light flashes and the "cooling" light is on steady. I turned off, turned breaker off and back on. No improvement. Checked lint filter, all...
You have one of 2 problems. There is a power problem at the power cord or the high limit switch has tripped. You will need a qualified LG technician to diagnose your situation.
Good luck
Oct 01, 2010 | LG DLE5955 Dryer
My lg dle5955w works but does not dry clothes why
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 26, 2010 | LG DLE5955 Dryer
Dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Jun 23, 2009 | LG DLE5955 Dryer
Hi, I hooked up my LG DLE5955W dryer and it powers up fine but I have no heat. The outlet I had for my old dryer was different than the one required for the LG. I went to home depot and got the correc
The following link explains how to properly wire a three or four prong 220VAC appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the link provided, and make sure you have the power cord wired correctly at the terminal block in the back of the dryer. NOTE: If this is a new installation, you are required to be using a four-prong outlet with 4-prong power cord. If you have any questions, please let me know. I hope this helps solve your problem.
May 03, 2009 | LG DLE5955 Dryer
Clothes don't get dry
ckd rear vent hose be sure it is not flat and kinked try a load with vent disconnected if works ok ck vent all the way to the outside for blockage
Jun 03, 2008 | Whirlpool GEW9250 Electric Dryer
LG DLE5955 Dryer Logo
167 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
