Question about Kyocera Mita KM-5035 Printer
What is the name of the black plastic piece that looks kinda liky a Y and has a spring an the bottom that holds the roller in place
    Problem Solver:
  • 23 Answers
Transfer Roller Assembly
Posted on Jun 09, 2010
Contact kyocera
Posted on Oct 02, 2009
Clean a KX-P7100 printer
The paper jam in theKX-P7100 is usually due to the paper tray.
If you pull the paper tray out you'll notice a black piece of plastic (located at the most front) with a cork like material in the middle. Try pushing down on this piece of plastic a few times. If it does not pop up immediately the grease that Panasonic used has become "sticky". The piece of plastic is removed by turning the tray upside down and pushing on the small plastic tabs that hold the black piece of plastic in. Be careful to not loose the spring that is located under the black piece of plastic or break the plastic tabs that hold it in place. Once you get the black piece of plastic out, clean it with que tips and clean the area it slides up and down in. Make sure to remove all the "sticky" grease. Once you get it clean, don't forget to stretch the spring to one more inch. the spring quality is awful at tensile strength. Then place the spring back in its place and push the black piece of plastic back in its place. You can add some light oil to the black plastic to make it slide better. After it is reassembled try pushing down on the black piece of plastic a few times. It should spring up almost immediately. This should take care of the jams that you are experiencing.
In addition, you may have to stretch the 2 big springs under the metal plate in the paper tray to one more inch. To access them, you'll have to unscrew the 3 philips screws under the tray (take a picture before :-)), take away the 2 blue pieces and take out the metal plate.
Now I'm able to print from the media tray without any problem :-).
Hope this helps!
Dec 09, 2012 | Panasonic KX-P7100 Laser Printer
Tip
Layman?s Instructions to replace the transfer belt for a Samsung CLX-6200FX...
Intro: This is a fairly difficult task, so really make sure you want to do this first. Factor in the cost of the transfer belt(maybe $25 dollars off of Ebay??) and it's not such a good deal. Anyway, for the DIYer diehards, keep reading.Necessary equipment:1. Number 2 philips screwdriver and a really small flathead screwdriver2. Disposable gloves3. 12 inch strip of cardboard or plastic4. Vacuum cleaner5. Spring hook removal tool (can made a simple one with a pair of pliers and a paper clip)
Disassembly: 1. Place the transfer belt assembly down on a table, so that the paper belt drive is on your right side. Remove the paper drive belt assembly by removing the three bright screws that hold it in place.
2. Turn the whole thing over and remove the rubber roller at the bottom. This is done by first carefully remove the spring that hold one of the plastic end in place. Choose the end that has the metal grounding tab on it. Be really careful to not damage the plastic tabs that hold the spring ends. The grounding tab must be pulled up slightly in order to go over a plastic nub before you can slide the plastic end off. Don't pull the metal too hard, or it will be permanently deformed. Place these parts to one side. The metal ends of the rubber roller have a little bit of grease on it, so just leave it there.
3. Flip the transfer belt assembly back over and on the right side, there is a protruding piece of plastic that has an electrical connector attached to the end of it. It's held in place by two black screws. Remove those two screws and the assembly will now hang there by the wires.
4. Remove the top plastic piece (covers the green release lever). There are four black screws that hold this in, two screws on each side. The part will dangle because it is connected by the same wires that connect to the piece in step 3.
5. With the removal of the part in step 4, the green release lever assembly is completely exposed. There are two springs (one on each side) that pull the plastic ends of the release assembly to its normal position. These springs need to be carefully removed. The spring hook removal tool is handy here. Finally, there is a holding tab on each of these end pieces, which needs to be carefully pulled up about 2 mm or so and then the end will slide off the metal bar. Don't lift up on the tabs too much or they will break off.
6. There are 4 bright screws that hold the excess toner tank. (This is the big piece of plastic with ribs, that the paper belt drive assembly was attached to. This tank will now come off, since the part in step 4 has been removed. The tank will be full of excess toner, so have the vacuum cleaner handle to clean up the mess. Shake the toner out into a garbage can.
7.
Underneath the excess toner tank is a scraper/cleaner bar. Two bright screws hold the bar in place. Take care to not deform the metal grounding tab that grounds the bar during operation.
8.
Take the left side plastic panel off now. There are 4 black screws that hold it in place. It should come free. If something is holding it in place, then you probably skipped step 5 and didn't remove the green release level assembly yet.
9.
There is a round rod which will come loose as soon as the left side panel is removed. This round bar works with the scraper to clean the excess toner from the transfer belt. Note that one end of the round bar has been machined to have a smaller diameter. That end goes toward the left side plastic panel. Put the round rod aside for now.
10. There are two round rollers on the top and bottom of the transfer belt assembly that are used to stretch the belt. The bigger round roller is spring loaded to provide the tension needed to keep the belt flat during operation. Using a small flathead screwdriver, carefully remove the compression spring (hidden under the left side plastic panel earlier) so as to release the tension from the belt.
11. Put your gloves on now, because in the following steps, foam rollers will be exposed and it's best not to get body oils on them.
12. There is still tension on the belt because there's a compression spring on the other end of the big round roller, but that's okay. Now, press on the plastic end piece that holds onto the roller to completely release all tension on the belt. The belt will now slide off. It won't come off easily since it's a tight fit. Just work at it and it will come out. Note, one side of the belt has a rubber track inside of it. That's the orientation that the new belt must go back in on.
13.
With the old belt removed, the inside of the transfer belt assembly is now completely exposed. Vacuum the excess toner dust.
Reassembly:
14.
Note where the round bar that pressed against the scraper should be. There are pieces of plastic protruding here which will damage the new transfer belt as it is being put into place. Cover these protruding points with a strip of cardboard, 12 inches long and about 1-2inches in width.
15. Now, holding everything in your lap and with the right side down, press on the end piece of the big roller as before, so that it is possible to slide the new belt down into place. Take your time, and it will finally get into place. Try your best to not fold the transfer belt material in any way. You will know the belt is in place when the rubber inside track goes into the groove of the black plastic roller at the near end of the big roller.
16. Put the compression spring that pushed the end of the big roller back into place.
17.
Slide the round bar approximately now where it should go. Remove the protective strip and position and push the bar end into the brass bushing. Remember, the machined end of this round bar should be aligned so that it clears the inner rubber track of the belt. I put a drop of light machine oil on the brass bushing, but I don't know if was really necessary.
18. Carefully put the left side panel back into place, noting that the smaller roller end and the round bar have to aligned properly before the panel will slide into place. Again, I put one drop of light machine oil on each brass bushing just before putting it all together. Four black screws are used to hold the panel in place.
19.
Put the scraper bar back into place using two of the bright screws. Note, the metal tab on one end should be pressing against the bar, making electrical contact when it is in properly.
20. Put the excess toner tank back into place, using4 black screws.
21. Return the green release lever assembly pieces back into place, basically performing the earlier steps in reverse. First position the lever bar in place, then slide the ends back on. The retaining tabs should click and the ends will be locked into place again. Putting the springs back into place is easiest with the help of the hook removal tool.
22.
Thread the top plastic piece back over the green lever. You may need to press on the green lever just a bit to get the piece back in and again to align the screw holes. 4 black screws to hold this top plastic piece.
23. Put the electrical connector piece back into place. Note that it hooks over the side panel piece. Route the wires into the proper place, so as to not smash them as the two black screws are used to reattach this piece.
24. Put the rubber roller back into place. Steps are the exact reverse of what it took to take it off.
25. Finally, fasten the paper belt drive assembly back down with the 3 bright screws. Note,this piece hooks into the top plastic piece before it is screwed down. Use a small flathead screwdriver, as needed,to make sure the grounding tabs are not messed up as the assembly is put back into place.
on Feb 24, 2011 | Samsung CLX-6200FX Printer
Error coming up that there is a paper jam at the cartridge but we have opened it all up and their is no jam
First, verify that there is actually no paper jam (open all the doors, take out the paper tray, take out the toner/drum unit and visually inspect), if none, chances are there is a little plastic piece inside the printer that has popped out. The little piece allows the printer to detect when a sheet is exiting the printer. When it pops out, its gives the printer a false reading which makes the printer think there is a paper jam.
Turn printer off and unplug the printer from all cables (power, USB, phone, RJ45, etc). Secondly, take out the drum/toner unit and place in a dark spot like a closet. Next, with the back of the printer facing you, turn the printer over so that it is resting on its front. The bottom should be facing you, and the back of the unit should be pointing towards the ceiling. I will use this orientation when describing the following steps.
Most of the back of the printer is actually a removable piece held in place by 4 silver cross head screws. Two are near the bottom of the printer in fairly deep recesses. The top two are easily accessible. Using a regular cross head (not flat head) screw driver, remove the 4 screws.
Once removed, the entire back panel should lift right off. You will then see the inside of the printer. You are looking for a small, gray plastic piece with a spring attached to it. It will probably be loose in the back of the printer. Its approximately 1.5" long and is roughly S-shaped. One end is different then the other, with one end being relatively skinny and the other end having a sort of paddle shape.
This is the piece that has popped out and makes the printer think there is always a paper jam. If this piece is not loose and is properly secured in place then you have a different problem. Reassemble the printer and call Dell for a replacement printer.
If the piece is loose, pick it up but ground yourself to the printer by touching any metal in the printer. Try not to touch the various electronics inside the printer unnecessarily.
Looking at the back of the printer, roughly in the middle where the paper exits is a black bar with various rollers on it. Below this should be a piece of sheet metal, gray in color, running from once side to the other (left to right) of the printer.
Visually follow this sheet metal piece. Roughly in the middle (left to right again) should be a small rectangular opening. Immediately below this should be a little black plastic piece with two little arms sticking out towards you, with a third arm perpendicular to the first two. This piece will be mounted on a small beige/brown PCB.
This is the actual sensor that the gray S-piece popped out of. If you look at the gray S-piece, you will notice that it has two little round knobs, one sticking out on each side. These knobs snap into the small semi-circular feature on the top of the two arms. The third arm is where the spring on the S-piece pushes against.
So, take the gray S-piece and hold it so that the spring is on the left, the thick paddle part is pointing towards the bottom of the printer, and the skinny part is pointing towards the top of the printer (towards the scanner section).
The skinny curved section of the gray S-Piece actually hooks behind the black roller. Thread the skinny curved section of the S-piece through the rectangular opening in the sheet metal piece and hook it behind the black roller.
Next, locate the two knobs on gray s-piece with the arms on the sensor so that they align with the top of the arms. Ensure that the spring's free arm is also lined up with the third arm on the sensor. When lined up, push down with a a small amount of force. You feel/hear a faint snap as the piece clips onto place.
Check that the spring is properly located in its arm by pushing against S-piece to make it rotate. When you let go, it should spring back to its default position.
That's it! Reassemble the back cover using the 4 screws. Go finger-tight only. These screws are only tapping into the plastic so if you over-torque them you will strip the holes.
Apr 12, 2010 | Dell 1815dn All-In-One Laser Printer
I n eed small plastic white piece that has wire
Could you be looking for a notebook coil spring holder? As an alternative?
Sep 14, 2009 | Sharper Image SI570 Steam Wizard Handheld...
Brothet HL-1870N gives Error E50
For the Brother HL-1850/1870N printers, clearing the "Service Call Error E50" in the LED display simply requires depressing the "Go" and "Set" buttons simultaneously while turning on the power. Continue to depress the "Go" and "Set" buttons until the LED display shows "Go Test Mode". Release the "Go" and "Set" buttons, the depress the only "Go" button again and the printer will start normally.
If problem persists, let me know.
Thanks for using ' Fixya ' and have a nice day!!
Aug 30, 2009 | Brother HL 1870N Laser Printer
I need to rewind the spring and starter pull cord. I need to understand how all the parts fit together
I had the same problem. I had to take it apart and rewind it manually. To do this:
Step 1:
There are 4-bolts to remove on the orange plastic section the screw into the motor housing (one of them is hidden inside the orange plastic housing, you'll see an opening for it). There are also 3 screws in the black plastic exhaust housing that screw into the orange plastic housing, find those and remove.
Step 2:
Carefully remove the engine from the plastic housing. I didn't disconnect the throttle cable or the electric wires (points) just kind of worked around them.
Step 3:
The mechanism is kind of crappy. There are two black pieces with a spring in the middle, and a metal disc on the bottom with a ribbon coil on the underside of it. The top plastic piece is what turns the flywheel when you pull the cord. The spring in between connects the two plastic piece. This is probably what popped out. There is a piece sticking up on one end, which inserts into the hole in the top black plastic piece. If you remove the little guardrail things you can probably remove just that piece. KEEP TENSIONS ON THE PULL CORD. Once you remove that top black piece, it should start to recoil.
Step 4:
If it did recoil, put the spring back in the top plastic piece, and then put the plastic/spring combo back into the the bottom plastic piece, there is a little groove for the bottom of the spring to slide into. Then put the little guardrail screws back on. Make sure the big metal wire thing hasn't slipped down into the shaft of the weed whacker. That needs to go back into the motor, as it is what gets spun and in turn spins the strings. As you start to put the motor back in, you may have to pull on the pull cord a few times to get the flywheel and plastic piece to line up. Once you hear the motor start to catch, then you should be able to wiggle it back into place and put back all of the screws. Then give it a shot. If it pulls out again, you may have to drill a new hole into the top black plastic piece for that spring to slide into (this is the crappy design part).
Step 5:
If the pull cord didn't retract, you need to remove the other two pieces (lower black plastic piece and metal disc with ribbon). The metal ribbon has a nub on the outside that hooks onto a plastic piece in the bottom of the orange plastic housing. You'll need to wind it around once or twice to "charge" the ribbon, then wind the string back on the black plastic piece. The black piece should slide into the center of the metal disc and catch the inside of the ribbon. Once you get these two together, again, make sure the metal ribbon piece is wound once past normal and then you have to slide both parts together down into the housing catching the metal ribbon loop over the orange plastic nub. It's tricky, it took me a few tries. Once you get that you can try and test the pull cord, you'll see it pull out and feel it retract due to that metal ribbon. Then go back and do step 4, where you put the upper black plastic piece with spring back into place and replace the little metal guardrails.
This whole thing took a few tries, and the pull cord still gets stuck out. It's a major pain to say the least, but after the 5th time fixing it, you'll be a real pro.
Aug 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Dell 1600n multi function laser will not turn on.
Sir,
If none, chances are there is a little plastic piece inside the printer that has popped out. The little piece allows the printer to detect when a sheet is exiting the printer. When it pops out, its gives the printer a false reading which makes the printer think there is a paper jam.
So, onto the fix. Turn printer off and unplug the printer from all cables (power, USB, phone, RJ45, etc). Secondly, take out the drum/toner unit and place in a dark spot like a closet.
It sounds tedious, but it took about 5 minutes to fix and now the printer is working fine.
thanks good luck
Aug 09, 2009 | Dell 1600n All-In-One Laser Printer
Printer rollers came off in paper jam and i cant get them back on
After a week of frustration trying to get the blasted thing back in--I could get the roller piece back in but not with the wire and could get the wire back on the little knob that holds it but that would prevent the roller piece from going in, I cut a notch in the white plastic above the spring hole so that I could, with very small needle nose pliers, hold the straight part of the sprint up while I put the roller piece in place. I then let the spring down through the notch I cut. It took a couple of tries but it all was pretty easy once the notch was cut.
Feb 10, 2009 | Epson Stylus Photo 785EPX InkJet Printer
TrackMan Wheel Trackball Spring - where does it go.
it's not really a spring -- it's just a twisted piece of wire. actually, it's what makes your little scroll wheel click when you turn it. place the scrool wheel in the little plastic bracket that holds it with the longest piece of axel (hollow side of wheel) in. then TURN THE BRACKET OVER. the wire goes on the BOTTOM, which is quite counterintuitive. you'll see how it goes -- the smallest end of the wire goes INSIDE the scroll wheel and the kinda squared end of the wire goes into a little hole in the bracket. you'll understand when you look closely at it. once the wire is installed, hold it in place when you turn the bracket/ball/wire assembly over. fit the legs on the bracket into the groves on the base of the trackball -- that's the side where the ball sits and the circuit board is. make sure the scroll wheel passes through the trackball cover when putting it all back together. VOILA! problem solved.
Jun 02, 2008 | Logitech Cordless TrackMan Optical...
Replacement parts
I think you may have the skills to make it
get some plastic epoxy or , i get them from a auto parts store but you can also find them in home improvement stores, etc
make a small paper cylindrical mold that would engulf the old plastic piece, fill it with epoxy to the top, turn it upside down and place it on the plastic part where the old hook was. once solid you can cut this to size so it will hold the spring.
Feb 23, 2008 | Dell Photo 964 All-In-One InkJet Printer
Kyocera Mita KM-5035 Printer Logo
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
