Question about Garden
Should the siphon hose be capped off if im not using it?
2 Suggested Answers
em1cl
  • 463 Answers
SOURCE: I need to siphon the
Hello gmknight67, I have no way of knowing if you are aware of this, but, many people are not aware that blowing into the hose usually makes it much easier to prime a siphon. Make sure the end of the hose in your hand is below the level of the tank and then blow into the hose with a nice deep breath.
I hope this helps you,
Good luck my friend!
Posted on Jan 17, 2011
Can I syphon has from 2001 dodge caravan from under gas cap
A lot of thieves have tried, but I don't know of many that succeeded. I quit trying to siphon gas from the cap 30 years ago when they started putting springs into the filler hoses just to discourage the practice. And nowadays, anyway, the filler hoses have too many bends in them.
No, I don't think you can, but you could pull off the filler hose from the gas tank fitting and put in a siphon hose right into the tank there.
Another possibility is to shoot 12 volts battery power to the fuel pump (it could be done at the fuel pump relay's position), then disconnect the gas line at a convenient location, like at the fuel filter, and let the pump push all the gas out.
Apr 05, 2017 | Dodge Cars & Trucks
How to drain my 2006 Dodge Durango fuel tank
If the pump will still run, you can open a fuel line, maybe use hose on line to aim down into a container and drain that way. Don't take any lines loose unless your sure no pressure on the system. Sometimes you can get under vehicle remove fill hose from gas tank, then use a siphon hose in the gas tank. Your local auto store probably has a plastic siphon hose, that has a squeeze bulb on it to create a siphon, so you don't have to use your mouth. I don't know if that will reach down the fill tube? In my younger years, they called a siphon hose an okla credit card. I'm almost 70 now, don't like getting gas in my mouth.lol
Oct 17, 2016 | 2006 Dodge Durango
Where or how do I hook up the soap hose ?
this unit has a storage tank in the front below the motor , in front of the pump
remove the cap and siphon hose
add solution , than re install hose and cap
you should be good to go
May 23, 2014 | Honda Black Max 2600 PSI Pressure Washer
How to drain a 2004 sportster 1200 c gas tank
The easiest way would probably get a cheap gas siphon hose (you know, one with a hand bulb you squeeze to get the siphon started). What I do is cut a coat hanger open and stretch it straight and then cut a piece a little longer than the distance from the take cap to the very back of the tank. Stick this into the hose to keep it straight (cheap siphon hoses have a tendency to bend and curve away from the bottom, back of the tank. Stick the hose with the rod in it to the lowest part of the take and the other end into some gas container that will hold all the gas you have in the tank and start pumping the bulb of the siphon.
Jan 22, 2013 | 2004 Harley Davidson XL 1200 C Sportster...
Where do u put the power steering fluid?
Hi.
Most Chevys have a reservoir under the hood. The reservoir is often near to engine oil reservoir. You will need to bleed the old fluid. This can be done using a siphon or disconnecting the pump return hose. Using the siphon from the reservoir cap is easier and safer.
Here the picture of the reservoir while bleeding with a siphon on a Blazer:
(source)
Aug 04, 2011 | Chevrolet Lumina Cars & Trucks
I have a 97 ford taurus and its a clunker. Im getting rid of it. It got a full tank and i would like to siphon it out and into my new car. I got a siphon kit and fed the tub all the way in till i wouldnt...
unfortunately most fuel tanks are made so you can no longer siphon gas through the fill tube. if you want the fuel that badly you could disconnect the fuel line from the fuel filter and wait for it to drip out.
Mar 31, 2011 | 1997 Ford Taurus
I have a Whirlpool Duet and the water is over flowing from the soap drawer. I have already cleaned out the soap drawer and tried flushing the opening that leads into the machine with a hose. Any other...
This is inevitably caused by a blockage. The small fabric conditioner compartment in the soap dispenser drawer has a removable plastic cap. This cap fits on the top of a tube which has a hole running through it where the water should siphon through.
When the time comes for the fabric conditioner to be released, cold water enters the small compartment and just washes the conditioner over the top and down the dispenser to the tub. When the water stops flowing, all that is left is the clear water. This water should siphon up the inside of the cap and down the tube.
This tube often gets blocked with the conditioner and if you remove the dispenser drawer and take off the cap you can give the whole thing a good clean out. If the cap is missing, the siphoning will not occur.
To test the function, hold the soap drawer under the tap and allow the water to fill the fabric compartment to overflowing. When you turn off the tap, the remaining water should slowly siphon out of the hole under the cap.
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How to drain gas tank
This is the fastest way
1. Disconnect negative side of Battery.
2. Open and prop open the hood.
3. Remove Fuel Filler Cap.
4. Go to the true "front" of the engine - located on the right side of the Van. Look near the coil, strut tower. There should be two fuel lines. One is larger than the other. The one larger is the supply line. The smaller one is the return line.
5. Disconnect the one larger (supply line) of the two fuel lines.
Fuel Siphoning kits are available at most auto parts stores. I obtained mine (hand pump) for $8.00 at Harbor Freight. But make sure it is designed for Fuel. Do not siphon using your mouth.
6. Use a fuel siphoning hose connected and clamped down onto the larger line.
7. Siphon the fuel into an approved container(s).
Let me know if this helped or if you have additional problems or questions. Feel free to contact me at fixya.com
Dec 02, 2009 | 1994 Dodge Caravan
I need to siphon the gas out of 2002 Town & Country van.
you should try a smaller hose like 3/8 an try to work it back and forth if that wont work look under the car where the fill line meets the tank sometimes theres a rubber hose where u can disconnect the fill line at the tank and gas cap then put aside and siphon closer to tank
Mar 27, 2009 | 2002 Chrysler Town & Country
I own a maytag epic z front loading washer and dryer and when i wash clothes they never get all the way wet and i end up having to rewash them. Im not sure what else to do.
ck to be sure drain hose is not more than 6-8 inches in standpipe top of standpile nees to be 30-36 inches above floor and drain hose should be too snug in standpipe ..any of above conditions may result in water siphoning out and not leaving enough water in tub ..washer only uses 5-6 gals per fill based on load so if water is being siphoned out doesn't leave much left
Sep 02, 2008 | Maytag Washing Machines
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
