Question about Frigidaire FRS26H5AS Side by Side Refrigerator
How do i add freon to a 25 Cu. Ft. side by side Frigidaire
  • 4,070 Answers
You don't. You have to be certified hvac. There is soldering, capturing, and disposing of freon and it requires special documents to purchase some freon.
Posted on Oct 01, 2009
What freon to use
Hey friend, thank you for the post!
I understand that you are searching for what type of freon is used in your Frigidaire freezer, FFU14F5HW. Based off of that model the freon would be 134A. Hope this information is helpful. -Matt
Jul 23, 2014 | Frigidaire FFU14F5HW Frost Free 13.7 Cu....
Water will not stop flowing in to icemaker
Dirt in body of icemaker water supply valve. OR. Ice maker timer stuck when it selected "add water to icemaker.
The first solution is simple, change icemaker water filter and disassimble valve to clean.
The second is simple, buy a new icemaker.
May 15, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
What is the cubic feet of this 20-25?
actually a bit bigger than 25 cubic feet
Total Volume 25.5 cu. ft. / 722 liter Fresh Food Volume 15.5 cu. ft. / 439 liter Freezer Volume 10 cu. ft. / 283 liter
Nov 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
With compressor running, low side pressure starts out about 15 psi then goes to a little below zero. i have added r134 freon until low side reached 10 to 12 psi. pressure stays there for a while then goes...
Wow, it would seem like you have a leak there on the low side. You add and it goes goes back to equal on the low side again. The gauge could be off just a bit. Have you pulled a vacum test on the unit? Sounds like you should pull everything out, vacum and the weigh in the correct charge at this point assuming that you do not have a leak or can find and fix it.
Nov 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Need low side freon pressure for GE refrigerator
while running you should be around 2 to just above vaccum
it runs better just a lil lean
Oct 17, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrig not cooling enough
Probably not a mistake but it won't perform properly outside. It may need a shot of freon. The extension cord is not a good idea either. Hope this helps and answers your questions.
Aug 17, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Need to add freon
  • if you are tapping into a sealed system, then you use the larger of the two copper lines coming out of the side of the compressor (this is the low pressure line, the compressor pulls from this side).
  • clean off the copper tubing with some fine sandpaper before installing your tap.
  • it is very easy to over fill a system with freon, so i would recommend pulling down the system to -30 psi and holding for at least 20 minutes. then add a known amount of freon to the system.
  • let it run for a while, it will take a little time to get the temperatures down.
Jul 02, 2008 | Whirlpool 15.2 cu. ft. / 430 liter Upright...
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
156 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
