Question about Akai LCT2721AD 27 in. LCD Television
Location of Power Supply Board ???
Reading other peoples T.V. problems and trying to find a solution to my Blank Screen on my LG MU-42PZ9OC 42" Plasma HDTV . From what I'm reading they (techs) all are saying "POWER SUPPLY BOARD" O.K. What does it look like ? Is it a big board with capacitors? or is it by the power transformer ??? Somebody shed some info Please.
Stephen
  • 1 more comment
  • Stephen Murphy Jan 28, 2008
    Harry, Thank You for helping me locate the P.S.B. on my 42"
    LG MU-42PZ90C Plasma.
  • pk2000 Apr 01, 2008
    I have an Akai LCT2721AD 27, the power keeps shutting off intermittently. Sometimes it will stay on for hours and nothing will happen but other times it will shut off continually. I've heard that it's the power supply board that may be the problem and if so it's been said that it will cost hundreds just of the part!!!.... Also the remote no longer works and yes I've put in new batteries so is this related to the other problem or a separate issue. I can be reached at p_kern2000@yahoo.com
    Sincerest Regards,
    Pete
  • kbwill41 Jul 06, 2008
    Hi All Im having the same Problem with my Akai PDP5006h it come on and the screen is black and the LED in front just blink , but when I turn it on I hear some click then nothing happens, Where can a find a Service Manual and a Parts suppy store for this Tv
    Problem Solver:
  • 40 Answers
The pwr supply board has the AC PLUG going straight to it!...and yes it has a transformer...and fairly large capacitors....but so does the x-board...and the y-board on a plasma
Posted on Jan 27, 2008
Testimonial: "Harry, I need your help again, Was given a Samsung HL-P5067W HDTV that doesn't work and with 2 flashing words LAMP & STANDBY TEMP Any thoughts ?"
  • Michael Sparrow
    Michael Sparrow Jan 29, 2008
    no problemo...if you need further assistance...let me know
Flat screen tv - no power
If your set is completely dead, I would suspect the power supply board. This is something depending on your electronic skills you might could try yourself.
They are available at places like shopjimmy.com and ebay for around 90.00.
You can expect to pay around 180-240.00 to have the set repaired depending on your location.
The part number I found for your power supply board is 6709900017A
If your going to try and replace it yourself, be sure to double check part number on the board.
If you follow where the AC cord plugs into the tv it will lead you to the power supply.. Good Luck!!!
Nov 23, 2010 | LG 42LC2D 42 in. LCD HDTV
Clicks over and over like power wants to turn on but just clicks
The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 14, 2010 | LG 42PX5D 42 in. Plasma HDTV
Flat screen tv problem
42PF7320A: 7 blinks is missing 8.6VDC from supply -- connector CN-1M46, pin 3 (out of 11 pins), goes from power supply to main/input board.
Apr 21, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
My 42 inch plasma wasnt working, i change the z sustain board and its only worked for about a week and the screen went blank but the sound still works, i got a new z sustain board but the screen is still...
1.It sounds as though there is a problem in the power supply section and it is blowing a linking component to the board mention.
2. this is only isolated with a schematic and proper electronic detection such as a Scope and meter.
3. You also may have a circuit that gives voltage to the plate that gives light to the luminous plate that may need service.
Feb 03, 2010 | LG RU-42PX10 42 in. HD-Ready Plasma...
I have a LG MU-42PZ90V that was given to me. I found one bad fuse. When you turn the power on it flickers from orange to green then shuts off. I was just checking a few things and noticed that it has...
Hi:
On this model you must replace the power supply if the blown fuse was on the power supply, but the main cause for LG failure is the Y_Substain Board assembly. When measureing the voltage of the Large Capacitors, this is the primary side to the main supply, you must measure the caps form hot ground, on the AC side of the Standby transformer for correct Voltage, 66V is to low. Look at the side of the Lrg Capacitors for their voltage ratings, the Supply voltage to these should be some what near this voltage but never higher. The Y_Substain board is to the left of the power supply standing in back of the unit. Its possible its just the Y_Board gone bad, but in my experience the you should replace them both.
Dec 03, 2009 | LG MU-42PZ90V 42 in. Plasma Television
No picture
The problem can be in the bcaklight inverter board or the main power supply is not supplying the power to the inverter board. The main power supply gets the turn on signal from the control/main board.
Nov 03, 2009 | LG 42LB1DRA 42 in. LCD Television
LG Plasma 42PC1DA screen blank, but sound is ok
Plasma TVs run on decent voltage. It is likely the power supply has encountered some damage. This could be a loose solder joint near a transformer, or a shorted out component. It is a lot of detective work. I would try to find a new power board online somewhere. There are people that pick up broken tvs for a living out there if you would rather sell it. Power board is their favorite type of damage and they offer extra money for them that way.
Nov 14, 2008 | LG 42PC1DA 42 in. Plasma HDTV
LG Plasma Monitor MU-422PM11 Red Light Problem
Your unit is in protect mode a short circuit has occured either at x,y z board.Check fuses F52 on y Board,FS1,FS2 on Zboard.Remove P1,P2,P3,P4 if power supply voltage is normal replace right x-board.Remove P6,P7 if the power supply voltage is normal replace left x-board
Jan 02, 2008 | LG MU-42PM11 47 in. EDTV-Ready Plasma...
Akai LCT2721AD 27 in. LCD Television Logo
120 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
