Question about Oreck Cordless Speed JP8100CA Iron
Does cord free TX 850 have a rechargable battery in it or not
I was given an older model and wanted to know if it needs to stay on base pluged in to keep a battery charged in iron, havent used yet,but worry about safety issues. Thanks John.K
I have a oliso iron that is one year old. Just not turning on.pluged into socket
take it in to an appliance repair shop( possible cord problem) otherwise consider a new one as repairs past a cord are uneconomical to repair
Dec 10, 2016 | Oliso Irons
How to replace power cord on a sunbeam 4214 iron
www.laundry.manualsonline.com has free manual
Jun 09, 2014 | Sunbeam Irons
Rowenta pressure iron and steamer model DG5030? We have purchased the iron and cord, now we need to assemble the part.
Google Rowenta and go to their website, they will have parts diagrams and wiring diagrams. Hope this helps, please post solved on fixya.com. So I get credit for a solved problem if it does.
Apr 30, 2014 | Irons
I am told the problem is with cord and they point at the and they point at the base of a beautiful iron.
Usually the cord at the base breaks off, because of tension from too much moving and pulling!
If thats problem u could cut the appropriate length and screw again the end of the cord!
Dec 03, 2010 | Rowenta Powerglide DE011 Iron with Auto...
I have a panasonic unwrinkler garment steamer. how does it work
Friend has exact same model in the box with instructions and help centers repair numbers. Do you still need help? Want a new hardly used 1?
Oct 07, 2009 | Conair Compact Garment Steamer Iron
Sunbeam 4214 Clothes Iron with Retractable Cord won't heat.
first, i'll apologize for not posting pictures with this, but i didn't have a camera handy when i "fixed" it. i'll do my best to explain the sitch.
i also have a sunbeam 4124 whose retractor was jammed...the cord would not release more than two feet or so, nor would it retract. i was able to disassemble it, but broke some internal retaining clips meant to hold the retractor housing to the iron. WARNING!! do not attempt this if you do not want to void your warranty. i can only assume that the manufacturer did not want you to disassemble the cord return housing and as such, hid the retaining clips where it would be impossible to disengage them. i got lucky and only broke one set of the retaining clips....if you carry on, you stand a chance of breaking both sets, which will not allow you to reattach the retractor housing to your iron securely. best thing to do is call sunbeam and have them send you a new iron, but if you're bent on fixing it yourself, here's how i did it (you'll need one medium philips head screwdriver):
1) remove the rubber feet from the bottom of the iron. this will expose two screw holes (the third foot under the retractor button has no screw; this is the side where the reaining clips are buried).
2) remove the two screws
3) WARNING! this is where you have a good chance of breaking your iron. pull the base of the iron really hard, rocking it from side to side. there are two sets of retaining clips recessed in the housing of the iron. the button will come with the base of the iron, the entire cord retraction assembly is self-contained. you can carefully use a screwdriver to pry the two halves apart. also, be careful not to pull too hard as the electrical connections between the iron and the retractor assembly has only about 2 inches of slack, though the connections are just wire-nut'd together and could be reassembled in a pinch.
4) after the retractor housing is separated from the iron, remove the housing cap by unscrewing the four screws.
5) carefully separate the two halves of the housing; the spring may be loose inside and could snap out at you.
here's where my iron was broken....the coil spring is contained by a plastic tray that had snapped, probably due to somebody pulling the cord out too hard. a section of the tray had jammed itself into the inside of the housing, immobilizing the winding mechanism. my only recourse was to completely remove the spring and permanently extend the cord all the way (not one of the features i bought the iron for anyway, so what the heck). PLEASE be careful unwinding the spring if you have to do it....wouldn't want anybody poking out an eye inadvertantly.
6) reassemble the retractor housing by screwing the cap back on with the four screws
7) if you're lucky enough to keep one set of retainer clips, snap the base of the iron back on and reattach the two screws located under the feet.
8) rubber pads back in and voila!
hope this helps!
Mar 17, 2008 | Sunbeam 4214 Iron
Repair of Steam Iron
I just removed the two screws on the bottom of the cord winder and made the screws tight again, works like a charm.
Feb 17, 2008 | Irons
Retractable cord
hope this helps!
Jun 12, 2007 | Sunbeam 4214 Iron
Rowenta Iron
Special screw called "Torx tamper proof" call 925 8271011 and order "Rowenta tool" $10.00 plus shipping-this place also sells Rowenta parts
Apr 09, 2007 | Rowenta Professional DX8800 Iron
Oreck Cordless Speed JP8100CA Iron Logo
174 people viewed this question
Top Oreck Irons Experts
Kevin Getz
Kevin Getz
brian kossman
Level 1 Expert
Are you an Oreck Iron Expert? Answer questions, earn points and help others
