Question about GE Profile 30" Slide-In Gas Range - Stainless-Steel
The Electric starter in my gas GE stove will not click anymore. My oven and burners will not ignite. Please let me know where on my stove to find the ignitor. I would like to replace the part. Thanks, I appreciate your help!
    Problem Solver:
  • 7 Answers
Check the power supply go to the Range.
Check for shorted wire.
Posted on Oct 01, 2009
All pilots ignite when 1 gas knob is used on one burner
All igniters will spark when you turn on any burner but only the one you have turned on will allow gas through to ignite.
May 04, 2014 | GE Kitchen Ranges
GE stove JGSP28 igniter has been clicking non-stop for the last 2weeks. Blow drying the burners has slowed down the clicking to every 5sec. Front two burners seem to be clicking at the same time while...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter.
A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you make need to replace the electric igniter module. Good luck.
Jul 16, 2010 | GE JGSP28SEKSS Stainless Steel Gas Kitchen...
Ge Spectra Xl44-three of 4 gas burners will not ignite without a match.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 19, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Stove top ignitors do not ignite but oven does.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I can't get one of my burners to light on my ge gas stove. It clicks and emits gas, but no flame.
Dec 17, 2009 | Avanti G20AW-1 Gas Kitchen Range
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven won't work on gas with electric ignition stove
The glow bar for the bake burner is bad, needs to be replaced. Remove oven bottom to get to it, and also the utility drawer.
Feb 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE gas stove the burners on top work, the oven won't get hot
The most common reason a gas oven won't heat is a bad igniter. It is located near the valve and burner under the oven bottom. You can usually see it glow orange just before the fire lights. Most GE ranges take a cylindrical igniter part #WB2X9154 or #WB13K21 rectangular igniter.
Jan 02, 2009 | Jenn-Air JES9750AAS Electric Kitchen Range
Electric starter for Electric stove
I think you mean you have a gas range with electric ignition. When you turn a burner to light, all burners should spark. The most common problem is boil overs have happened on those two burners. Take the burner head off for sealed burner ranges and clean them out. For non sealed burners, the little holes toward the center side of the burners need to be cleaned. You don't have a model listed, so I can't be real specific.
Aug 15, 2008 | GE Spectra JBP78 Electric Kitchen Range
Gas Stove - Electric Starter
Just happened to me. I unplugged the electric starter, wiped up the water, took off burners, etc., and placed a fan over the stove. After about 3 hours, I plugged in starter and the clicking is no longer.
Sep 23, 2007 | Ovens
GE Profile 30" Slide-In Gas Range - Stainless-Steel Logo
374 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
