Question about Remington Polesaw Wizard
Broken trigger in botton handle , need parts - Remington Polesaw Wizard
  • 193 Answers
Part number is 077525s . You can order at 1-800-654-8534
Posted on Oct 01, 2009
How to replace broken trigger on a huskie 162 sg chain saw
Most Husky saws have a small pin to drive out to remove trigger. Often safety lever on top needs to be removed also. Sometimes tank/handle assembly needs to be removed to replace trigger.
Dec 27, 2016 | Garden
How do I repair a non-functioning solution trigger
The trigger has tabs on each side that snap into slots in the handle so that the trigger pivots in the slots. The slots where the trigger pivots may have broken, if so the trigger will not push the valve open and allow the water flow. If the tabs are broken you will need to replace the upper handle. If you supply me with your model number I will determine the proper part for your model.
Dec 14, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steamvac trigger won't spray
Remover the upper handle assembly and check the linkage (inside the upper handle) where it connects to the button/trigger assembly in the handle grip. This may have detached or the trigger may be loose from its mount in the handle. Reattach or replace the broken part.
Sep 03, 2014 | Hoover V1 SteamVac SpinScrub Vacuum
The handle leaks and seems to not have the tension on the handle. I have it apart and it seems like a tension string is broken but I can't see how it reconnects.
They don't offer parts for the trigger guns, you would just need to purchase a new trigger gun. There is a number of different trigger guns for these machines though, what is the model and part number of the machine that you have?
Oct 10, 2010 | Karcher 2500 PSI Pressure Washer
The trigger on the handle is not working and neither is the steamer HELP
Need a little clarification, do you feel/hear click when pressing trigger? No means the trigger inner actuator tab is broken...easy fix, just gently pry off cush rubber cover on handle from front to rear (gently to not scar up the works) and lift. Steamer not working?...is it getting hot? Steam building up in the boiler? Need a little more information here before I can proceed...
May 31, 2010 | Rowenta DG-980 Iron
How to fix throttle trigger on a poulan chainsaw?
The trigger, lockout or trigger/lockout spring has failed of may have debris stuck in handle. remove handle cover and inspect. If parts broken follow this link for parts breakdown.
http://www.ordertree.com/modelinfo/PWE/PP4218AV/75.PP4218AV.1.7.1.html
Apr 01, 2009 | Poulan PP4218AV 18" Chain Saw
Ds lite left trigger broken..
yes your ds lite is repair able if you can,,,,,open up your ds lite and get a soldering iron and touch the 4 points with it, then put it back together.
I can give you step by step information if you email me at ndsrepairservice@gmail.com
Jan 26, 2009 | Nintendo DS Lite Console
Poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
Oct 12, 2008 | Poulan Garden
Remington Polesaw Wizard Logo
100 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
