Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
How to unplug line gas line for pilot light - Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
  • Cozy Master
  • 3,315 Answers
Hi undo pilot line remove injector blow through this with can of air or air line should remove blockage
Posted on Feb 17, 2010
Gas dryer pilot light
Hello Lara. Your dryer does not have a pilot light. It uses a hot surface ignitor to ignite the gas. Unplug the dryer and cover it with a plastic sheet before fogging.
Jul 08, 2016 | KitchenAid Dryers
Rheem #22DV50-38,pilot light keeps going out.Thermal coupler has been changed.
Most gas water heater problems can be solved by cleaning burner parts and combustion chamber, and bleeding air out of gas line, checking gas pressure, and making sure gas shut-off handle is turned-on and parallel with gas line:
Many things cause pilot light to go out including dirty parts, air in gas line, and hot-unventilated atmosphere.
Open following links for troubleshoot resources and cleaning illustrations.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
Jul 08, 2011 | Rheem Water Heaters
Pilot will not light, seems to not be getting any propane to it. The regulator on my propane tank works fine. What could be the cause?
I would trace gas line out and determine were you are getting gas and where it is not. With the gas on I would carefully loosen union or flex fitting going to gas valve.If you have gas there then retighten union and go to fitting on pilot line and check it.You should be able to get gas there by depressing pilot light button.If you have gas there then go to pilot assembly and remove it from gas valve and burner. Remove pilot orifice and carefully clean and blow thru pilot line to make sure it is not obstructed.
If you cannot get any gas thru gas valve then shut off gas before valve and remove inlet line. There should be a fine mesh steel screen there. Make sure it is clean.If you are getting gas to gas valve but not thru it then you probably need to replace gas valve. Thank you
May 17, 2011 | Procom ML060HPA Heater
Can't get the pilot light to start
Is this the newer style with closed combustion chamber. If so I would check to make sure that spark ignitor is working. If not it will need replaced. If ignitor is workingthen loosen compression nut on line to pilot and temporarily depress button on gas valve to make sure you have gas at that point.If you have gas there and tighten compression nut to pilot back up and it still won't light then you will need to remove screws that hold cover on burner compartment.Shut off valve to gas supply and remove gas line from gas valve remove pilot and thermocouple lines. Slide burner out ofcompartment and clean it .Remove nut from bottom of pilot assembly and clean out pilot orifice. Blow through pilot line to make sure it's all clear
Reassemble everthing using teflon tape or pipe joint compound as needed.Turn gas supply valve on and check for leaks.Set gas valve control to pilot and depress pilot button and hold. While you are holding button done push spark ignitor every few seconds until it lights. thank you and good luck
Dec 22, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
How do i light pilot light?
Remove front cover,or just lower section if you can. they usually just need to be lifted up about an inch or so and pulled out. However some have covers that snap in place. After you remove cover locate gas valve. It should have a control knob on top with markings for on, off, and pilot. Set control to pilot. Follow lines from gas valve to burner compartment, one goes to main burner one ,small copper colored line is the thermocouple, other line is the pilot. Turn thermostat down as far as it will go. Make sure gas supply valve in line to heater is on and then depress pilot control , when you have pilot control depressed have a match or other small flame source close to pilot assembly. If it lights then hold down on pilot control for a couple of mins. Slowly release pilot control and if it stays lit turn gas control to on. Turn thermostat up to call for heat and burner should light. If pilot doesn't stay lit when you release pilot control then try again holding pilot down longer. If it still won't stay lit then thermocouple will need replace. Good luck. Thanks
Nov 22, 2010 | Williams 6508732 Gas Heater
I am converting a pitco model 14c fryer from nat gas to propane, and am wondering where does the pilot oriface install at. It looks like a small cap with a hole in the end. Thanks Jim
The pilot light is attached directly to the front of the pot near one of the burners. You will see one small gas line and a set of wires. Loosen the nut where the gas line goes into the pilot light. You will have to hold the pilot light as well as turning the nut on the line. Pull the line from the pilot light assembly. Sometimes the pilot orifice comes out with the line and other times it stays stuck in the pilot light. If it is stuck take a small blade like a pocket knife and pry it out. put the new one in and tight it all back up
Oct 02, 2010 | Pitco Frialator SG14 Deep Fryer
I HAVE A VERMONT CASTINGS RADIANCE HEATER MY PILOT LIGHT WONT STAY LIT I HEAR THE THERMOCOUPLER TRIP THE VALVE BUT THE FLAME WILL GO OUT
We had this problem and struggled with it for over a year. We finally hired someone to come in and service the stove he cleaned everything and blew a piece of crud from the pilot line. NO Problem for 2 years since.
He told me the pilot light should look strong pointed like a pencil not curved up like a candle. He removed the pilot and disassembleed the line and used compressed air.
Jan 08, 2010 | Rinnai Desa Vent-Free Infrared Gas Heater:...
I have a Martin ventless gas log fireplace. I
Sometimes when you turn a gas heater off for some time, if the source tank has been turned off, the line will bleed the propane and the line will contain mostly air. This is especially true if the supply line is long. In order to light the pilot, you will have to hold the pilot lighting button down for a while (a full minute or longer, depending on the size and length of the supply line) before pure propane arrives at the pilot light jet. You should keep a lighted lighter at the jet so that when the gas arrives, the lighter will light it. After the pilot lights, you will have to keep the button pressed long enough for the thermocouple to get hot enough to set the pilot to stay on. When it is hot enough, you should be able to release the pressed lighting button and the pilot should stay on. If it does, you should be able to light the heater. If the pilot jet never lights, gas is not getting to the regulator. If the pilot will not stay lit after a period of time waiting for it to heat the thermocouple, the thermocouple or the regulator may be bad and need replacement. :-)
Jan 03, 2010 | Desa International Unvented Gas Space...
Pilot light will not lite
I fixed the pilot light by taking off the cover to expose the gas lines going from the knob to the pilot light fitting --I shut of the gas then disconnected the gas lines blew air in the lines to clean out any matter that might have been blocking the gas from getting to the pilot light re connected the lines and fired up my heater it is working great ---hope this can help some one with the same problem
May 08, 2009 | Endless Summer 2009 Open Flame Patio...
Gas wall heater won't light
You need to bled the line longer and when you get lited hold down for a good minute.When the gas gave out ,there could trash in the line.I would take the line off and blow gas through it undtil you can smell it.
Mar 12, 2009 | Heating & Cooling
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
101 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
