Question about Nokia 6010
How to fix my 6010 it would not cut on . when
How to fix my 6010 it would not cut on . when i press the power button it flashes on then off.
How to release left margin
Clear button.
I had a Xerox Memorywriter - great keyboard, so I know the sequence of press button, generally.
What to do.
... to what...
execute
does that help?
if this doesn't help i'll give a 2nd shot.
AK
Aug 28, 2014 | Xerox 6010 Memorywriter Electric...
I got nokia 6010 unit. the problem is no antena signal.. could you help me
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
Jun 18, 2010 | Nokia 6010
I have a RCA R56wh78 projection power button flashing green.
Thats the classisc sign that the CP150, CP114 and CP120 capacitors need replacement. You can get the repair kit called CP150, CP120 and CP114 at www.tvrepairworld.com which contains the capacitors and the CD with step by step instructions on how to do the repair.
Dec 04, 2009 | RCA HD52W56 52" Rear Projection HDTV
Code for renault radiosat 6010 7700433072 x847 philips 22DC461/62L 9022 214 61624 PA4Bis ,4*15W,RDS CD changer control FD10 99 21 4201367 MODEL NO:22DC461/62l PROD NO: FD 1099214201367
Try code 2159
Philips Renault Code Entry
Turn on the radio and the display will show 'CODE'
Use the steering controls for code entry.
Press the [¬ ] button then rotate the thumb wheel for the correct first digit
Press the [¬ ] button then rotate the thumb wheel for the correct second digit
Press the [¬ ] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [¬ ] button for up to 10 seconds to store the code
Sep 14, 2009 | Electric Renault R26 Radio Control Car
Code renault radiosat 6010
Your code is 6359
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Sep 11, 2009 | Electric Renault R26 Radio Control Car
I have a canon mp830 that is has trouble code 5c00 on the lcd. the power light and trouble light flash alternately green and yellow respectively. I've cleaned the print head. How can I reset the printer to...
Canon MP170, MP450, MP530, MP600, MP610, MP800, MP810, MP820, MP830, MP960, MP970
MX700, MX7600, MX850
1. Switch off the printer the button Power
2. Holding button Resume (the red triangle in ring), include the printer (press the button Power ) - an indicator fires green cvetom.
3. Holding button Power , release the button Resume
4. Not releasing button Power , two times press the button Resume and release both button.
5. After indicator of the cut-in/readiness flashing.. and fires constantly, fall into service mode.
6. Four times press the button Resume , under each striking Resume indicators are switched: green-yellow.
7. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press once again.
Jul 09, 2009 | Canon Office Equipment & Supplies
I hahe a nokia 6010 and my sim is bloked can you help ?
You can try this Nokia procedure to unlock the sim for any carrier. Its not proven to work on all Nokia phones.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin#
Hope this works for you, its the only known method that I know of for Nokia phones.Feel free to leave a positive rating for this solution. Thank you for stopping by Fixya!
Mar 14, 2009 | Nokia 6010
On Canon S9000 A3 inkjet printer error light flashing to indicate 'waste ink tank nearly full'. Can I fix this myself?
1. Turn off power.
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let the
Resume button go.
4. Press Resume button 2 times then let both
buttons go.
5. Green light will flash then stop blinking.
6. When Green light is solid, press Resume button
4 times.
7. Press the power button and the printer should turn off. If not, press the Power button 1 more time.
8. Done.
Dec 04, 2008 | Office Equipment & Supplies
Ge 94948 universal remote instrutios for progaming t.v.
Hiya this is how i got mine to work.Manually turn on the tv.
Press and hold setup on your remote till the light comes on and stays on.
Then press the tv button then release. The light will flash then continue to stay on.
Now press and release the power button waiting 2 seconds before you press it again until your tv switches off.. you may have to press it for awhile.
Once your tv cuts off press the mute button and now your remote is set for your tv.
Feb 19, 2008 | GE RM24948 Remote Control
Nokia 6010 Logo
59 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
