Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Install ice door flapper on GE TFX25PR side by side?
My ice door flapper is misshapen due to age (aren't we all). i plan to replace the flapper but don't know how to approach it. From the inside or outside of the door.
Any one have step by step suggestions?
  • ualift Oct 01, 2009
    Thanks Woodchuck. I'll order parts and give it a try.
  • ualift Oct 11, 2009
    Used suggested instructions with success. Thanks.
  • 4,070 Answers
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Posted on Oct 01, 2009
Testimonial: "I ordered the part, $9.50 incl shipping and installed as suggested in 10 minutes. Freezer issue is resolved. Thanks."
I have a GE side-by-side with ice and water through the door. The ice bin defrosts from time to time causing the ice to re-freeze in a clump once the temperature gets back to normal in the freezer. I...
Have you had a dispenser flapper replaced..if its not sealing (closed) properly it will lead to frost buildup in the location described..
You can check that by looking into ice chute form inside the freezer door and see if any light shines through
Jul 01, 2017 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Model TFX25PR ; Does the ice cube maker require any lubrication ?
The type ice makers made for your model and other models require no lubrication and are one of the most used parts of your refrigerator especially if there is a large family and lots of ice used daily. They never seem to stop working while the average refrigerator last 15 to 20 years the average life of an ice maker is only 5 years. Even ice makers that have replaceable parts the repair parts are more expensive in most cases than complete replacement. Below is an example of an average ice maker that Whirlpool and Maytag uses that have the Teflon coating in the ice slots. Your model is for GE,=> Model WR30X10093 Ice Maker and has electronic controls and no replaceable parts. Thanks, Sea Breeze
Jun 05, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Leaking Water from freezer door through Ice Dispenser
theres a little door for ice to come out...you need to replace the flapper an solonid valve that open ..call for help on disassembly....
May 12, 2010 | GE Profile PSW26P Stainless Steel Side by...
The ice dispensing flap on the door doesn't close completely. I have a GE side by side with water and ice through the door.
COULD BE DO TO ICE BUILD UP. IT MAY NEED A NEW GASKET OR FLAPPER DOOR. THIS NEEDS TO BE TIGHT.! . TO FIX THE LEAK TILL YOU GET THE PART USE A PLASTIC BAG AND A SOCK(CLEAN?) AND FROM THE INSIDE PLUG THE ICE DOOR HOLE ..
Jan 31, 2010 | GE Refrigerators
I have frost build up where ice comes out of ice maker. The frost then clogs the shoot in door.
sounds like the ice flapper door is stuck open. Pretty common for GE refrigs to have the ice door solonoid and plunger get all rusty and need replacement
Nov 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker stoped working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Jun 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
Icemaker works fine, only dispenses water
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Nov 25, 2008 | GE GSS25JEMWW Side by Side
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
483 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
