Question about Apple iPod touch
Its completely dead and ill not switch on can you
Its completely dead and will not switch on can you help?
  • 36 Answers
Try plugging it into your computer and then booting it. Often that'll work better than if it's connected to a charger. If it still doesn't work, you may have to take it in to a apple store
Posted on Oct 02, 2009
Where is the fuse for the running lights on 2002 Jeep Liberty?
zero symptoms stated, just vague, running lamps.(with an 'S')
running, are parks, old name , PARK.
which lamps are dead, the PARK lamp fees are the largest feed on cars. , 2 in trail, 2 in front, and side markers and the cab is full of parking lamps, called illumination lamps with dim feature.
so do all other things work on car, head lamps
engine run, and HVAC and all that?
Ill now answer ,and pretend you said, USA Liberty, on our USA forum.
does your car have DRL feature, like in canada, mandate.
daylight running lights> ill pretend , NO.
Ill pretend you said all exterior park lamps are dead
and the PARK relay is dead.
the relay feeds fuse 9 and 23, so its not likely both those blew.
the relay is controlled by the BCM brain, so if the brain fails to see the switch turned, there will be no parks, nor relay closure.
if engine runs, ok
and head lamps work ok
and all else work then get the car scanned.
to see if the BCM even sees the park commands are sent out.
if engine dont start or stater sound weak , we'd fix that first.
if only parks fail then the BCM is next. (fuses above ok)
all fuses ok. (we check all fuses first. or read the book to see the complex nature of power and fuses on this car.)
the scans must not show, for example MUX to BCM failures.
the MUX is the combo switch outputs to the BCM.
if no errors there, then we diagnose why the park relay is dead.
its not wired like 1970 jeep. not at all
its run by 2 + computers and a network,
Jul 26, 2016 | 2002 Jeep Liberty
TV picture turned green, then it went out completely
if your set went all green then shut off you might have a shorted anode on the green tube this is not good news if the set went dead then it probably killed your power supply you will have to get this fixeed first then check to see if tube went bad.i need model of your set ill help yo find out k
Dec 27, 2007 | Televison & Video
1995 Geo prizm, no power to fuse 10 in fuse box under left side steering column ,no power to distributor or fuel injectors,were does power come from
dead engine,
do head lamps work?
on a dead car, dead engine, all power comes from the main car battery. and all power feeds are fused.
if fuses blow, no power to that feed.
if the battery is dead so will be the head lamps and hand lamps
do not take a key top work (a safety feature)
this car is toyota corolla. (with geo stickers)
how do you know power is missing from F10?
you used a voltmeter there? or test lamp? how>?
there were 2 engines, 4A and 7AFE engines.
ill guess and answer for 4AFE engine
Fuse 10 is not a number its the current rating of the fuse.
and is maked (you didnt show a photo of fuse, nor where it is)
is marked IGN
now ill answer with the schematic. (makes it 10x more easy)
now power feeds IGN fuse, from the key switch
if that switch works the power come to it from
AM2 fuse
If AM2 is dead then the battery is dead. or
the battery ground is bad.
or the battery lugs are rusty
or the battery is only discharged, so charge it.
or jumper cable start car like you see the AAA tow truck man do.
Jul 25, 2016 | 1995 Geo Prizm
Battery wont start the car ,ill charge the battery its ok for a few hours then its dead ,alt charging good ,battery is new,every fuse in both pannels are hot with key off please help
The battery dies after sitting for a few hours ? Parasitic drain on the battery ! With the key off all fuse's shouldn't be hot ! Bad ignition switch . Find a wiring diagram at www.bbbind.com an check power at ignition switch . Look on you tube , a lot of videos on basic electrical trouble shooting .
Nov 13, 2015 | Cars & Trucks
MOWER IS DEAD AT TIMES. WHERE ARE SAFETY SWITCHES
seems like you have poor (loose) connections. clean all connections & retighten. ignition switch?
Oct 07, 2015 | Cub Cadet LTX 1050 KW 50" 23HP Kawasaki...
2009 Jeep Compass won't crank. Any answers ?
sure,
but what transmission, ill guess automatic.
Check fuses first? always first !
Check engine light on,key on, no, fuses.....
does it crank in NEUTRAL? (it will (can), per opr. guide)
does it?
scan it yet to see if there are TRS switch errors>??
do jumper cable jumps work>? off a running car, AAA tow truck like?
yes, then the battery was dead, or discharged.
no? then key line is dead. if hot wiring starter fails.
if hot wiring passes , then the key line is dead. TRS switch.
got tools or just want wild guessing?
my guess is wild.
so jumper cable it and report.
Mar 14, 2015 | 2009 Jeep Compass
Tail lights and dash lights is no working
did you check them in the dark to see if , not just dim?
what sub model, EX, or LX? the LX is very different.
the car has 2 fuse boxes. did you know that, most cars do.
the fuse is called fuse #10 (fuse 10 runs hazards too, are haz dead?)
box one in cab, and 2 in engine bay.
the HAZ fuse is marked, HAZ
park/dash dim all dead, this is the largest path in car, over 20 lamps on most cars. (lots of places to mess up)
all are dead, all parks, front , rear, side and cab (dim) dead??????
even the license plate lamp>>>> details?,,,,, help, im blind..
here ill login to alldata.com for you, so can you at anytime.
ok this car can have a tail light relay. the LX dont have one.
the combo switch (1st click ) turns on park(tails)
and the relay energizes and runs all the park lamps.
but not on the LX, the LX is switch direct drive to all parks.
so?????
found this with google. NON LX !!!
Fuse #10 (15A) Audio unit, pocket light, clock, climate control, cruise switch light, gauge assembly, hazard switch light, heater control panel, interior lights switch light, driver's multiplex control unit, power sliding doors switch light, rear A/C switch light, taillight relay TCS swtich light.
Dec 30, 2013 | 1999 Honda Odyssey
Sport fuse
did you check all fuses? yet? in both boxes?
first off the schematic (516pages) is here.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
so you look any time and see why.
ill direct you to the pages.
the radio too can be complex. ext. amps. ill assume its 100 % DEAD
ill do radio dont play in run pos. of ign. sw., (easier)
there are 3 Cherokees, gas, desiel and export. so> and ENGINE! size
so every page is repeated 3 time. you sort that
6 fuses involved here, just for the freaking radio
but fuse 17 is the key fuse. see that. and the marking
RUN-ACC A31 , in JB (bad A31 power feed is the prob)
fuse 17 marked, X12-16rd/wt
fuse 18 kills windows. and is A31 feed too.. hummmmm
are both fuses blown, might check that..?????
so we look now at A31 (fuse 17 and 18 measure 0ohms with meter)
A31 goes to the Ignition switch, USA RHD GAS car, is most
complex and the first section of the switch has a pin3 to pin4
jumper. this jumper allows A31 power feed to reach the things
you find are dead. see page 8w-10-15 or pdf 35
see pdf page 240 for radio wires.
so what is wrong, i dont know,
but my voltmeter will tell min in 1min flat
got 12v on the A32 feed?
yes, then F17 -18 blown.
if not the jumper is bad in the ign. switch
Sep 24, 2013 | 1999 Jeep Cherokee
The only lights that work on my rear taillights are my turnsignals. I've replaced the bulbs and still nothing. Please help?
Check for power to your brakelight switch this located at the top of the brake pedal. I see alot of these go bad.
Aug 31, 2010 | 1999 Jeep Grand Cherokee
I jumped started my car now my cd player won't work. There is a red light it indicate power but won't switch on. Please help x
sounds like your connected to the battery, and if you had to jump start ill assume the battery is dead..... dead battery=no power, so radio/cd player will not work, replace battery and it should be fine
Jan 08, 2010 | JVC Car Audio & Video
Apple iPod touch Logo
53 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
