Question about Toshiba Satellite A100-S8111TD Notebook
I dropped my laptop and now it is not worki ng it dropped on the backside it won't let me turn it on
  • 403 Answers
I am sorry to tell you that your hard drive is probably damaged. This is what I would like for to do. Unplug your laptop. Turn it over. There will be several access panels. Undo the screws and reset all the items under these panels. Most importantly the hard drive, pull it out and reset it. Let me know if this works, if not We'll figure something else out.
JimmyC
Posted on Oct 02, 2009
Lights on odometer not worki ng or speedo
Harley speedos have a lot of problems with water vapor getting in and shorting stuff out my 2006 1200c had the same problem I just bought another one of eBay and installed it myself
Apr 11, 2014 | 2006 Harley Davidson XL 1200 C Sportster...
Water pump not worki ng
the water pump is located in the front of the engine behind the waterpump. you'll need to remove the accessory belts,crank pulley, timing covers, and timing belt. this is about a 6 hrs job if you know what your doing.
Feb 24, 2014 | 2002 Kia Sedona
Ano ang dahilan bakit ang motor ko na honda wave 125 pagkatapos mapalitan ng clucth housing,clutch cam,cylinder block with piston ay malakas ang lagitik lalo na pagnerevolution ko.
Hi, Anonymous mong i-on ang ignition switch pindutin ang starter button at ang lahat ng makakakuha ka ay ang dreaded "CLICK" ngayon bago pagsubok ang anumang mga de-koryenteng sangkap sa Starter System ito ay "IMPERATIVE" na mayroon kang isang ganap na sisingilin baterya ng 12.5 volts o higit pa at maaaring pumasa sa isang wastong "LOAD" test kung kinakailangan, maaaring mayroon kang isang paunang pagbabasa ng 12.5 volts o higit pa ngunit maliit o zero amperage, ang baterya ay may mali at dapat mapalitan. Ang mga uri ng baterya ng AGM ay nahuhulog sa sitwasyong ito nang higit pa kaysa sa lead-acid na mga baterya at ang karaniwang mga suspek ay:
1. Ang mga terminal ng baterya ay may maluwag o nakakagambala na koneksyon.
2. Ang mga cable ng baterya ay may mali dahil ang mga naka-corroded o sirang panloob na mga kable sa cable connector lalo na ang "NEGATIVE" na cable na kailangang suriin sa "BOTH" ay nagtatapos.
3. Boltahe ng baterya, dapat na 12.5 volts o mas mahusay, boltahe mula sa baterya hanggang sa pangunahing circuit breaker sa switch ng ignisyon sa fuse ng seguridad / ignisyon sa module ng TSM / TSSM sa engine stop / run switch sa starter button sa Ang starter relay sa green wire na nag-uugnay sa starter solenoid ay hindi dapat mag-drop ng higit sa 1/2 bolta ng boltahe ng baterya.
4. Idiskonekta ang mga cable ng spark plug, na may isang voltmeter na konektado sa baterya, ang switch sa ignisyon sa posisyon, ang kill switch sa posisyon ng run, ang starter button na nalulumbay, ang pakikipag-ugnayan ng starter ay hindi dapat magdala ng boltahe sa ibaba 9.6 volts DC. Kung ang boltahe ay mas mababa sa 9.6 ang baterya ay may mali at dapat mapalitan. Inirerekomenda ko ang "HIGHLY" na isang maintenance free AGM battery karaniwang mayroon silang mas amperahe para sa cranking.
5. Malagkit na starter relay, suriin ang pagpapatuloy.
6. Malubhang starter solenoid, suriin ang contact plate at sapatos para sa sobrang electrical erosion / etching, refurbish kung kinakailangan o baligtarin ang contact plate at gamitin ang virgin backside. Suriin ang mga sapatos na pang-contact para sa pagiging maluwag. Palitan ang solenoid kung ang negatibong function ay pa rin ang huling resulta.
7. Malubhang starter, bench test starter na may 12-volt na baterya kung ang negatibong pag-check ng function, mag-decontaminate at magbawas ng armature commutator segment kung kinakailangan, suriin ang mga segment na may isang probe ohmmeter bawat isa at ang segment sa tabi nito para sa shorts. Nakarating ang armature na sinubukan sa isang growler at field coils, at brush plate na may isang oum-meter para sa bubukas, shorts o grounds. Palitan ang brushes kung mas mababa kaysa sa .438 "Karaniwang mas mura ang maingat na pagsusuri / pag-aayos ng starter motor kaysa sa pagbili ng bago.
Para sa karagdagang impormasyon tungkol sa iyong isyu at mahalagang "LIBRE" na mga pag-download na kakailanganin mo para sa pagtingin o pag-print mangyaring mag-click sa asul na mga link sa ibaba. Good luck at magkaroon ng isang kahanga-hangang araw. MOTORCYCLE STARTER RELAY TEST
cg125 how to fix starter motor part 1
https://caitmourinblog.files.wordpress.com/2015/07/wave-125-repair-manual.pdf
Honda Wave Parts Manual EN pdf
Honda Wave 125i Owners Manual Eng pdf
Dec 06, 2012 | Honda Motorcycles
2005 Honda Dio electric starter hindi gumagana
Hi, Nashana1712 bago subukan ang anumang mga de-koryenteng sangkap sa Simula Circuit ito ay "PAUTOS" na mayroon kang isang ganap na sisingilin baterya ng 12.5 volts o higit pa at maaaring pumasa ng isang wastong "LOAD" test kung kinakailangan, maaari kang magkaroon ng isang paunang pagbabasa ng 12.5 volts o higit pa ngunit maliit o zero amperage, ang baterya ay may mali at dapat mapalitan. Ang mga uri ng baterya ng AGM ay nahuhulog sa sitwasyong ito nang higit pa kaysa sa lead-acid na mga baterya.
1. Pagsiklab Hindi lumipat sa "ON" na posisyon.
2. Engine Run Lumipat sa "OFF" na posisyon.
3. Ang Engine Run Switch ay "FAULTY" o corroded.
4. Suriin ang mga terminal ng baterya para sa pinsala o kaagnasan suriin ang mga kable ng baterya sa "BOTH" na nagtatapos para sa maluwag, nakakagambala, o sirang mga konektor, "INSIDE" at sa labas ng cable harness, magsagawa ng connector na kumikilos ng pagsubok at suriin ang mga cable na may isang ohmmeter.
5. Ang sensor ng anggulo ng bangko ay nangangailangan ng pag-reset o ay may sira.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Buto na mali ang starter.
9. Malagkit na kickstand, klutch, neutral safety switch.
10. Kailangan ng alarm ng seguridad ang isang pag-reset.
11. Starter relay, solenoid, starter motor o circuit wiring may sira. 12. Nabigo ang starter armature o field coils.
13. Ang pangunahing fuse o circuit breaker ay maaaring tinatangay ng hangin o may sira.
14. Faulty ignition relay.
15. Ang electric starter ay nagtatrabaho ngunit ang starter clutch ay nabigo.
16. Suriin ang mga code ng problema sa engine.
Para sa karagdagang impormasyon tungkol sa iyong isyu at mahalagang "LIBRE" na mga pag-download na kakailanganin mo para sa pagtingin o pag-print mangyaring mag-click sa asul na mga link sa ibaba. Good luck at magkaroon ng isang kahanga-hangang araw. Scooter Troubleshooting Scooter won start All about Scooters
24 So Your Honda Scooter Won Start
Honda SK50M Dio Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda SK50M Dio SR 2000 Owner Manual
Apr 03, 2012 | 2005 Honda Dio
Hi screen goes black while worki.ng mostly after 20min
Check your power saving options by going into the control panel and then Power Options. You can tweak the settings to turn off the display after a determined period of time or to never turn off at all.
May 06, 2011 | Computers & Internet
There is no power to the wall switch resulting in the heater not worki ng
check the breaker. then get an electrician in to repair
Aug 09, 2010 | Water Heaters
2002 4x4 s10 zr2 4 wheel not worki ng
sounds like the 4 wheel drive
switch in the transfer case is bad.
Feb 06, 2010 | 2002 Chevrolet S-10
HP Pavilion DV2700T PC Notebook - won't reboot.
go into bios next time it starts and turn off all power settings, same in control panel in windows and turn off sleepmode and hibernate.
Dec 01, 2009 | HP Pavilion DV2700T PC Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
