Question about Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB DVD RW DVD BRAND PC Desktop
Test again - Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB DVD RW DVD BRAND PC Desktop
  • 85 Answers
Test!
Posted on Oct 04, 2009
Erase hard drive hp1055
In service test menu scroll to "3.Hard disc drive", & press enter, if test drive passed don't replace the hard disc or modification or changes. If test failed then check as shown below:
1 Switch the printer OFF. Remove the EIO Card (if installed) and re-install the Hard Disk Drive making sure it installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails again then replace the Hard Disk Drive.
2 If the Hard Disk Drive Test passed after removing the EIO Card,then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened.
Switch the Printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails, then the EIO Card could be faulty.Replace the EIO Card.
3 If the Hard Disk Drive Test continues to fail after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module..
I am having little knowledge, if I am wrong Pl don't comment, pl forgive me.
May 20, 2013 | HP DesignJet 1055cm InkJet Printer
I plug it in, flip the switch, and nothing.
test the c.breaker and reset. and try again.
2) If the problem persist, test inside the fuse and replace, test the flip switch with DVOM for faulty and replace
3) of course unplugg the power cord, and tight any wires loose and connector very well. and try again.
God bless you
Nov 22, 2012 | Exercise & Fitness
WESLO TREADMILL WILL NO COME ON I HAVE NEW KEY I CHECKED THE PLUG
1) test the power cord for open or break
2) test the main switch for defective
3) reset the c. breaker
4)replace the open fuse
5) Try again if the problem persist
6) Lube THE deCK BELT, AND try again.
7) test the input voltage motor, if there are the motor need repair.
89 test the drive belt motor, for worn, or adjust it.
9)test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Nov 21, 2012 | Weslo Exercise & Fitness
NO POWERW
try to use a small cheap magnet, buy it from the home depot. and test the actual again the magnet from refrigerator. use the principle attract and repulsion if do not pass the test replace it.
2) if after you replace does not work, test the c.breaker + fuse , and test again.
3)tight any connector from power supply, and test again.
God bless you
Nov 21, 2012 | Exercise & Fitness
Lock pc drives
Hi
1. Click “Start”, “Run,” and then type cmd. When the command prompt opens type “CD C:\Test” (replace “Test” with the name of the folder you want to hide.)
2. Now type “attrib file +s +h” and replace “file” with the name of the actual file name you would like to hide.
3. Now, go back to C:\Test and look for your file or folder, it’s not there! You cannot find it through simply browsing around, through the command prompt, or even if you click “Show Hidden Files and Folders”.
4. To find the folder and it’s contents again simply go back to the command prompt, type “CD C:\Test” (of course, again replacing “Test” with the name of the folder,) and then type “attrib filename -s -h”. You should now be able to find your file again
Thanks
Smith
Aug 16, 2009 | Computers & Internet
My hp desktop will not operate. It reports a message that I have a paper Jam. I have checked the printer as advised and there is no paper inside. I have also conducted all recommended shut down and...
You need to clean NVRAM on Lexmark X5470 printer. Please follow the steps given below to clear NVRAM on Lexmark X5470 printer:
1. Turn the printer off.
2. Hold down "#5" button and turn the printer back on.
3. Keep holding "#5" button for about 5-10 seconds.
4. Press "Menu" button once.
5. Press the right arrow until display shows "Tools."
6. Press "Check" button once.
7. Press the "Right" arrow button again until display shows "Maintenance."
8. Press "Check" button again.
9. Press the "Right" arrow button again until display shows "Manufacturing."
10. Press "Check" button again.
11. Press "Right" arrow until display shows "Clean NVRAM."
12. Press "Check" button to clear nvram.
Next, try this printer self-test by following the steps given below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
May 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
I dont want to print test page
as when you get the test page while you on the printer.to stop it.just place the printer side of the test page on the scanner glass.and press the scan button on the printer.the green light will blink for 1 minute.then automatically stop.after that remove the paper from scanner glass.and now you will not get the test page again n again.
Mar 09, 2009 | HP PSC 1410 All-In-One InkJet Printer
Displays test mode
To exit test mode, turn off phone.
Press *3001#12345#. Scroll up 1 to FIELD TEST (some phones may say NET MONITOR instead of FIELD TEST) and SELECT. Scroll to ENABLED and press OK. Turn phone off and then back on. Signal strength is the upper or lower left number. After test mode is enabled it will stay in your regular menu. To easily get in or out, press MENU, up 1 FIELD TEST and SELECT or OK. Dial 00 to get out and 01 to get back in.
Jul 03, 2008 | Cell Phones
Computers & Internet Logo
14 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
