Television would not turn off, after 2-3 days it was unplugged and it went off, when plugged back in the television would not come back on.
  • wbrooks99 Oct 01, 2009
    • hitatchi model # 50DX20B
    HITATCHI MODEL NO. 50DX20B.
  • 5,138 Answers
What is the Brand name and model number of your TV it will be printed on back of set?
Posted on Oct 01, 2009
  • ladywinn
    ladywinn Oct 01, 2009
    Replace Both of your convergence ICs they are STKs big black ICs will have STK392-110 on them use STK392-150 and replace all of these resistors
    RK42 2.7ohms
    RK46 2.2ohms
    RK50 3.3ohms
    RK58 3.9ohms
    RK62 3.3ohms
    How to enter service mode remove front bottom panel on convergence board their is a small blue contact switch with tv on press and release convergence pattern should appear Now realine R/G/B some sets you will not have to realine convergence after replacing defective parts.Call Mats Electronics for parts 1-800-628-1118 I will post you how to change red/ gr/ bl /with hand unit just in case you have too! you will need your original hand unit.
No picture still have sound HELP
If you have not tried it: unplug the set and if using a cable or sat box unplug that as well---wait for a while and plug both back to see if a reboot of either cures the problem or not.
May 25, 2012 | Samsung 50 in. Plasma TV
I have had a Toshiba Dvd player for about 5 years now. The other day i turned it on to watch a movie. I put the disk in, as soon as the driver closed it turned off. I turned it on again and it went off...
It seems power supply section got some problem and need to be repaired but it would cost more money than buying new dvd player.
Sony DVP-SR500 etc is available for $60 only at sonystyle.com
Thanks.
Jun 24, 2011 | Televison & Video
I have a Mitsubishi WT-42311. Last week the
where you saw blue it sounds like your blue crt is shorting out could be just the video amp so
i would suggest you have a tech look at it for and estimate
Nov 24, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Lg tv automatically turn on and off. Power surge
the software in the main control is damaged. call your lg servicer in your area. he might get you a software update
Jul 06, 2009 | LG 47LC7DF 47 in. LCD HDTV
No picture, no sound, turns on, but turns itself off immediately.
unplug 2 ribon cables they are white then plug them back in  should fix it
Jun 08, 2009 | RCA HD52W66 Projection Television
No power
You most likely have a capacitor or 2 that are bad and as long as it stayed plugged in they stayed charged, then when you unplugged it, they discharged and cannot charge back up. My recommendation is to take it in to a service center to have it repaired it should not cost much to repair. This is a common problem with this design of power supply. I see it every day.
May 17, 2009 | Polaroid FLM-3225 32 in. LCD Television
It will not turn on.
give this s try
unplug it wait for 5 min. then plug back in
Feb 11, 2009 | Lakewood (5500) Oil Filled Radiator Heater
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Blinking green light
My tv did this, if you unplug it for a couple of days, plug it back in and push the reset, my light quit blinking, but it took about 1 to 2 hours
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
