Question about HP Photosmart M447 Digital Camera
I push the power buttton and the light next to the
I push the power buttton on top of the camera and the light next to the switch (small blue LED) blinks three times and that's all that happens...?
HP M447
THANKS
  • 3 Answers
SOURCE: I need an instruction manuel for an HP digital camera, Photo Smart M447
yes you can! just go to www.hp.com and find the support location and type in the model number!
Posted on Feb 23, 2008
myob247
  • 1342 Answers
SOURCE: HP Pavilion a705w willnot power up
Read this HP forum thread. You may want to try some of the recommendation.
Posted on May 21, 2008
SOURCE: WON'T POWER ON
HP Photosmart R742
me too
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01075346&lc=en&dlc=en&cc=us&lang=en&softwareitem=ps-52612-1&os=228&product=3377589
this didnt work
Posted on Nov 16, 2008
  • 54 Answers
SOURCE: hp photosmart m447 digital camera
Try switching the USB settings in the camera from USB mode to disc drive mode.
Posted on Jan 05, 2009
jmgldsmth
  • 1869 Answers
SOURCE: no power when i press button...led fashes 8 times
remove and, reseat your memory if that doesn't help try disconecting your dvd drive hard drive(s) one at a time and, retest
Posted on May 24, 2009
Need emachines t3306 motherboard connection diagram
The eMachines T3306 desktop computer, uses the FIC K8M-800M motherboard.
First International Computer, (Inc)
http://www.fic.com.tw/product/motherboard/amd/ficimages/k8m-800m.jpg
http://www.fic.com.tw/product/motherboard/amd/k8m-800m.aspx
Here's the download page for the motherboard manual,
http://www.elhvb.com/mboards/OEM/eMachines/manuals/index.html
Column in middle, 3rd file from bottom.
This is a Zip file. A Zip file is a Compressed file. Used to send large amount of information more easily.
Has to be decompressed, or 'unzipped'.
After you click on the blue -> FIC K8M-800M file name, a small window will come up-
Opening K8M-800M_manual.zip
Make SURE there is a Green dot in the small circle, to the left of Save File.
IF not; click in the empty circle to the left of Save File.
No go below in the small window, and click on OK.
A small download window will come up.
Allow the file to fully download all the way, then DOUBLE-click right on the file name.
(Yellow folder icon with a zipper on it. K8M-800M_manual.zip is to the right)
In the next small window go to the far Left, and click on -
Extract all files.
At the bottom of the next 3 small windows click on Next, Next, and Finish.
In the last small window DOUBLE-click right on the file name ->
K8M-800M_manual
(Next to the red Adobe PDF icon)
There is your motherboard manual in PDF file form.
For an example;
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
Motherboard installed in computer case, the Front Panel header is at the Bottom/Right.
The Front Panel header is Orange in color. (Page 20)
Two rows of contact pins.
5 pins across the Top row.
4 pins across the Bottom row.
The Top row is numbered ODD.
The Bottom row is numbered EVEN.
Starting on the RIGHT side going across to the Left; Top row,
Pins 1, 3, 5, 7, and 9.
Starting on the RIGHT side going across to the Left; Bottom row,
Pins 2, 4, 6, and 8.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected.
Reserved for factory use. Probably a 5 Volt test point.
D) Pins 2 and 4 are for a Power On LED light.
These two pins are used for a Single color, Power On LED light.
Two wire LED light.
Pin 2 is for the Positive ( + ) wire.
If the PWR LED is dim when the computer is on, switch the wires around.
There is ALSO a jumper used for this LED light. More on it at the end.
E) Pins 6 and 8 are for a Power On switch.
To the Right of the Orange Front Panel header, (F_PNL), is the PW_LED header.
[Page 20 to right of Front Panel header. -> PW_LED
(Power LED, 2/3 Pins) ]
3-pin Black header. Sits Vertically.
(The Orange - Front Panel header, sits Horizontally)
This is used for a 3-wire Power On LED light.
Used for a Dual Color - Power On LED light.
One example is if the computer has Turbo Mode, and Normal Mode.
Green color usually for the Turbo Mode, Yellow color of the LED for the Normal Mode.
Starting from the BOTTOM going UP;
Pins 1, 2, and 3. (3 at the Top)
A) Pin 1 is for the Positive ( + ) wire. [Signal]
B) Pins 2 and 3 are for the Ground wires.
Jumper block for the 2-wire Power On LED light, and 3-wire Power On LED light; Page 13 - Set System Jumpers
(Actually it starts on Page 12)
6-pin header to right, of 3-wire Power On LED header.
Has Blue jumper caps on it. Two of them.
(PL_LED1)
http://www.ebay.com/itm/NEW-FIC-uATX-Skt-754-AMD-Desktop-Motherboard-VIA-K8M800-AGP-4x-8x-DDR400-800FSB-/280923928691?pt=Motherboards&hash=item41685ef873
Two rows of 3 pins.
The bottom row is numbered EVEN.
Starting on the RIGHT side going towards the Left; Top row,
Pins 1, 3, and 5.
Starting on the RIGHT side going towards the Left; Bottom row,
Pins 2, 4, and 6.
A) With the jumper caps on Pins 3 and 5; plus 4 and 6; the Power On LED light works as a Single color LED.
B) With the jumper caps on Pins 1 and 3; plus 2 and 4; the Power On LED light works as a Dual color LED.
For additional questions please post in a Comment
Regards,
joecoolvette
Mar 07, 2013 | Computers & Internet
Wiring MSI ms-7641
http://www.msi.com/product/mb/760GM-P34--FX-.html
http://www.msi.com/product/mb/760GM-P34--FX-.html#/?div=Manual
Under the Download subheading click on the blue -
M7641v4.0.zip
Click on the 'country' name nearest yours.
(U.S. is a country, the others Europe and Asia are continents)
A small window will come up -
Opening M7641v4.0.zip
IF not; click in the small empty circle to the left of Save File.
Go below in the window, and click on - OK.
Allow the file to download all the way, then DOUBLE-click right on the file name.
(Yellow folder icon with zipper on it, and M7641v4.0.zip next to it)
In the next small window go to the far left, and click on -
Extract all files.
At the bottom of the next 3 small windows, click on Next, Next, and Finish.
7641v4.0(G52-76411X9)(760GM-P34_760GM-P24_760GM-P2...)
(Zip file.
A Zip file is used to send large amounts of information more easily.
It is a Compressed file.
You need to 'unzip' it, or decompress it )
(Adobe Reader uses PDF files)
The Adobe Reader page number box is at the Top, to the right of the Down Arrow.
When I refer to a page it is for that page number box.
Clicking on the Zoom In icon at the Top ( + ) Increases the view size.
Clicking on the Zoom Out icon ( - ) Decreases the view size.
The area of contact pins on the motherboard, that the Main wires go to, is the Front Panel header.
Example; Front Panel header pinout:
The Front Panel header is two headers on this motherboard.
Go to Page 11.
Here at the Bottom/Right of the motherboard you see the 6 SATA connectors; all of them Black in color.
To the immediate Left of them, and situated Horizontally; is JFP2.
Junction Front Panel 2.
Two rows of pins.
To the immediate left of JFP2 is JFP1.
It is also situated Horizontally.
Two rows of pins.
JFP1 has two rows of contact pins. 4 across the Top, 5 across the Bottom.
The Top row is numbered EVEN. The Bottom row is numbered ODD.
Starting on the LEFT side, going towards the Right, Top row;
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the LEFT side, going towards the Right, Bottom row;
Pin 1 is for the Positive wire.
C) Pin 9 is N/C. Not Connected. This is reserved for the factory. Probably a 5 Volt (DC) test point.
D) Pins 2 and 4 are for a Power On LED light, and TWO wire.
E) Pins 6 and 8 are for the Power On switch.
F) There is NO Pin 10.
Junction Front Panel 2. (JFP2)
The Top row has 4 pins, and they are numbered EVEN.
The Bottom row has 3 pins, and they are numbered ODD.
Pins 1, 3, and 5. There is NO Pin 7.
A) Pins 1, 3, and 5 are for a THREE wire Power ON LED light.
This type of LED light is a dual color LED.
In the past, and one example; it may have been used for computers that had Turbo Mode, and Normal Mode.
Turbo being Green, Normal being Yellow.
(Which was a bunch of hooey.
Turbo Mode was the Normal mode, and Normal Mode was a slowed down version)
Pin 1 is for the Negative ( - ) wire. Also can be said as the Ground wire.
Pins 2 and 3 are for the power wires, (Positive + ), and each color.
(Example:
Pin 2 for the Yellow side of the dual color LED, and Pin 3 for the Green side of the LED.
Light Emitting Diode. So stating LED -> light is kind of redundant)
B) Pins 2, 4, 6, and 8 are for an internal speaker.
Used to hear BIOS Beep Codes.
If there is something you do not understand, that you need for connecting cables, and peripherals; post back in a Comment.
(A Harddrive, and Optical Drive, are also Peripherals. Not just the Mouse, Keyboard, Printer, Monitor, etc)
Regards,
joecoolvette
Mar 04, 2013 | MSI Computers & Internet
Power LED and other connection diagram for MSI 7142 motherboard
MSI Support > K8MM-V motherboard (ms-7142) > Main Support page,
http://www.msi.com/product/mb/K8MM-V.html
Hover your mouse cursor on the Download tab.
(Overview / Specifications / Download / Support / etc)
In the drop down list click on - Manual
Underneath the Download subheading click on the blue -
M7142v.1.0.zip (2005-09-07)
(U.S. is a country. Europe and Asia are continents)
Opening M7142v1.0.zip
Make SURE the small circle to the left of Save File, has a Green dot in it.
Now go below in the small window, and click on - OK.
Allow the file to fully download, then DOUBLE-click right on the file name. ( M7142v1.0.zip)
Extract all files.
In the last small window DOUBLE-click right on the file name.
There is the motherboard manual in PDF file form.
You can go page by page, to the page you want, using the Down Arrow; or if you know the page you want you can do this,
1) Put your mouse cursor in the page number box at top.
Left-click once. Anything in the page number box, is now highlighted in blue.
2) Type the page number.
3) Press the Enter key.
A) Go to Page 5 - Layout.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
On your motherboard there are two.
JFP1 and JFP2.
Junction Front Panel 1 and Junction Front Panel 2.
JFP1 is on the Right side of the motherboard, down in the Bottom/Right corner.
It sits Vertically on the motherboard.
Two columns of contact pins.
5 on the Left side, 4 on the Right side.
Go to Page 14 - Front Panel Connectors: JFP1/JFP2
The pins on the Left side are numbered ODD.
The pins on the Right side are numbered EVEN.
Starting on the Top/Left side, coming down;
Pins 1, 3, 5, 7 and 9.
Starting on the Top/Right side coming down;
If the HDD LED is dim when the harddrive is active, switch the wires around.
This is reserved for the factory. Believe it is a 5 Volt (DC) test point.
D) Pins 2 and 4 are for the Power On LED light.
It is for a TWO wire Power On LED light.
The JFP2 header is to the Left of JFP1.
It is situated Horizontally, and close to the bottom of the motherboard.
Two rows of pins.
3 pins on the Top row, 4 pins on the Bottom row.
Starting on the Right side, going towards the Left; Top row,
Starting on the Right side, going towards the Left; Bottom row,
A) Pins 1, 3, and 5 are for a THREE wire Power On LED light.
I assume Pin 1 is for the Negative wire ( - ), and Pins 2 and 3 are for the two Positive wires.
It's for a dual color Power On LED light.
Example: Turbo Mode has a Green light, Normal Mode has a Yellow light.
Internal speaker is used to hear the BIOS Beep Codes.
For additional questions please post in a Comment.
[Thought you may want the motherboard manual, too]
Regards,
joecoolvette
Mar 04, 2013 | MSI K8MM-V Motherboard
Motherboard wiring for t6532
eMachines T6532 uses an MSI MS-7207 motherboard.
Also known as the MSI K8NGM2-L,
http://www.msi.com/product/mb/K8NGM2-FID--IL--L.html
Scroll down a little, hover your mouse cursor on the Download tab.
Scroll down a little. Under the Download subheading, click on the blue - E7207v2.0.zip
[Version 2.0 / English / 7.1MB / 2006 - 05 - 24 ]
Click on the country name nearest yours.
Opening E7202v2.0.zip
If Not; left-click in the small empty circle to the left of Save File.
Go below in the small window, and click on OK.
In the next small window go to the far left, click on -
Extract all files.
At the bottom of the next 3 small windows, JUST click on Next, Next, and Finish.
In the last small window DOUBLE-click on the file name - 7207v2.0(G52-M7207X5)
Example A;
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
(Power On switch, Power On LED light, HarDDrive activity LED light, and Reset switch IF used)
The Front Panel header is JFP1, in the bottom/right corner of the motherboard.
4 on the Top row.
5 on the Bottom row.
Pins across the Top row are numbered EVEN.
Pins across the Bottom row are numbered ODD.
Starting from the Left side going towards the Right, Top row;
Starting from the Left side going towards the Right, Bottom row;
It is reserved for the factory to use.
(Believe 5 Volt test point)
D) Pins 2 and 4 are used for a Power On LED, that has two wires.
JFP2, or also known as Junction Front Panel 2; is above JFP1, and is situated Vertically, instead of Horizontally like JFP1.
(Below purple SATA data cable connector/ Right; and to the immediate right of the CMOS battery))
4 pins on the Left side, 3 pins on the Right side.
Pins on Left side are numbered EVEN.
Pins on Right side are numbered ODD.
Starting at Top of Left side coming down;
Pins 8, 6, 4, and 2.
Starting at the Top of the Right side coming down;
NO Pin 7, pin 5, pin 3, and pin 1.
Pins 2 , 4, 6, and 8 are for an internal speaker. Used to hear BIOS Beep Codes.
Pins 1, 3, and 5 are for a Power On LED light, that has 3 wires.
Used for a dual color Power On LED light.
For example Turbo Mode is Green, and Normal Mode is Yellow.
(Which was cr@p.
Turbo mode was actually normal, while normal was slower)
Example B)
Front panel USB ports. (Connectors)
JUSB1 and JUSB2.
EACH USB header supports TWO USB ports.
Look at the pinout on Page 40.
VCC, USB4-, USB4+, and Ground; is one USB connector. (port)
VCC, USB5-, USB5+, and Ground; is a second USB connector. (port)
Note the USB4-, and USB4+; and the USB5-, and USB5+
Now look at a USB pinout. Male and Female,
http://en.wikipedia.org/wiki/Pinout#USB_pinout
VCC = +5 Volt
USB4- and USB5- = -Data
USB4+ and USB5+ = +Data
GND is Ground.
You can have 4 USB ports in the Front Panel, or add extra ones to the rear panel. (I/O area)
ONE of those USB headers; JUSB1 or JUSB2; can be used for a Card Reader.
A Card Reader has Two USB cables, and uses One USB header on the motherboard.
Which one? Junction USB1, or Junction USB2?
Pick one.
Doesn't matter.
BIOS will set an IRQ for it.
(Interrupt ReQuest)
Regards,
joecoolvette
Mar 02, 2013 | eMachines Computers & Internet
M4n68t-m with bad power switch need to jump pin but witch ones
Another one of life's mysteries, and we shall probably never know
OH WAIT! Silly me! I forgot you can go to ASUS SUPPORT, and download the USER MANUAL,
http://www.asus.com/Motherboard/M4N68TM
http://www.asus.com/Motherboard/M4N68TM#support
Click on the Download tab.
(Knowledge Base / Download / Memory/Device Support / etc)
To the right of the - Select OS - box, click on the blue Down Arrow
Click on WinXP. Doesn't matter what Operating System you choose, you are just going for the User Manual. (Motherboard manual)
Give it a few seconds to load.
Scroll down, click on the + sign to the left of - Manual (5)
Scroll down.
Version E5215 M4N68T-M user's manual - English
Click on the blue - Global
Opening E5215_M4N68T-M_manual.zip
Make sure the small circle to the left of - Save File, has a Green dot in it.
IF not; left-click in the small circle to the left of - Save File.
Now click on OK below.
A small download window will come up. Allow the file to Fully download, then DOUBLE-click right on the file name.
(E5215_M4N68T-M_manual.zip)
In the next window go to the left, and click on - Extract all files
At the bottom of the next 3 small windows, click on -
In the last window DOUBLE-click on the file name.
E5215_M4N68T-M to the right of the red Adobe PDF icon.
The area of contact pins on the motherboard, that the main wires go to, is the Front Panel header.
You need a Front Panel header pinout.
When I refer to a page in the manual, it will be for the Adobe Reader page number box, at the top.
Go to Page 1-7
1.5.3 Motherboard layout
Number 12 shows us the Front Panel header.
Motherboard mounted in computer case, the Front Panel header is the 3rd header from the Left; on the bottom of the motherboard.
(System panel connector (10-1 pin F_PANEL)
Go to Page 1-25
There are two rows of pins.
4 pins across the Top row; 5 pins across the Bottom row.
Not numbered, so I will;
Starting on the LEFT side, going across to the Right; Top row,
Starting on the Left side, going across to the Right; Bottom row,
A) Pins 2 and 4 are for the Power On LED. (Light Emitting Diode)
B) Pins 6 and 8 are for the Power On switch.
C) There is NO Pin 10.
D) Pins 1 and 3 are for the HarDDrive activity LED.
E) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
F) Pin 9 is N/C.
Not Connected.
Probably a 5 Volt (DC) point for the factory to test with.
(So it's Reserved for the factory)
Here is an example of an ATX power on switch, that is used in MANY desktop computers,
http://www.directron.com/atxswitch.html
Remember; the Power On switch is a Momentary Contact Switch.
This means the contact period you make across those two pins, shouldn't be more than 2 seconds.
Next time you do not know the Front Panel header pinout, of a motherboard;
Use an LED light with two wires.
Touch two pins at a time, going along the FP header.
Computer turns on? You have the Power On switch pins. Now you can continue on.
LED light stays on? You have the Power On LED pins.
LED light blinks? You have the HarDDrive activity LED pins.
Computer restarts? You have the Reset switch pins.
Power On LED winks at you seductively?
Put that left-handed cigarette down, and go get sum fresh air.
Regards,
joecoolvette
Jan 16, 2013 | VIA ASUS A7V8X-MX KM400 Chipset Ultra...
All my wiring was unplugged how do I connect it
Suggest download the Motherboard Manual from Asus Support, and plug it back in.
The front of the computer is the Front Panel.
You may have to remove the Front Panel, to see where the Power On switch wires are; plus Power On LED (light) wires, and Harddrive Activity LED (light) wires are.
Most of the time the plug connectors, at the end of those wires; have a tiny abbreviation on them. Tells what they are.
The Power On LED light, and the Power On switch, are usually located in the same area on the Front Panel
(PWR LED and PWR SW)
Usually you can see where the wires go, to the Power On LED light.
By process of elimination, you know the other wires now, are for the Power On switch.
[The Power On switch is located inside the plastic assembly, of the Power On Button.
This is one example of an ATX power on switch,
The kind used in a LOT of desktop computers ]
The HarDDrive activity LED is usually located away from the Power On switch, and Power On LED light.
It's wires should be easy to find. (LED light is usually Red)
USB ports, Firewire ports, and front audio (Microphone/Headphones), have separate cables, and plug connectors that are different from each other.
Most of the time, the same contact pins on the motherboard that are used for USB, can also be connected to a Card Reader.
The power cable coming from the Power Supply, for the Card Reader; is the same one used in the old days for a Floppy Drive,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Asus Support > M2N32-SLI Deluxe > Main Support page,
http://www.asus.com/Motherboards/AMD_AM2/M2N32SLI_DeluxeWireless_Edition/
Power cables from Power Supply to Motherboard:
Look at the photo.
1) At the bottom of the photo, and middle; is a white long connector that has two rows of 12 socket holes.
There is a blue 40-pin IDE (PATA) connector, right next to it.
This is for the 24-pin ATX main power cable. A general example of said power cable; and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note that color does NOT matter for the power cable connector.
Also note the pivoting Lock on the side, shown in the middle photo, and photo to the far right.
The Lock works like a see-saw on a playground.
You squeeze the top in (Towards the wires), and this brings it's hooked end at bottom; away from the Lock Tab on the motherboard connector.
When the power cable is deemed to be plugged tightly, and correctly; the hooked end of the Lock is over the Lock Tab, on the motherboard connector.
[ Page 28 - Bottom (54 of 170) in manual ]
2) From the white 24-pin ATX main power cable's motherboard connector, look up from it's left top corner.
You have the squarish copper Heatsink with the white Asus on it.
Above it is another finned copper Heatsink.
To the left of that finned Heatsink is a blue PCI Express x16 slot.
Next to the blue PCI Express x16 slot, is a white square 4-socket hole connector.
This is where a 4-pin ATX +12 Volt power cable goes. General example of power cable. and it's motherboard connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Again, color does NOT matter of power cable connector.
It also has the same type of lock mechanism, that the 24-pin ATX main power cable's connector, has.
That's it for power cables TO the motherboard.
Going back to the Asus Support page, click on the Download tab.
(Overview / Specifications / Download / etc)
You'll see the OS - Select OS - box.
Click on the blue Down Arrow, on the right side.
Click on WinXP.
If you were downloading Drivers, or BIOS update, or other software; it would matter what Operating System you choose.
Since we're just going for the motherboard manual, naa!
Scroll down, click on the + sign to the left of the blue Manual (14)
Scroll the INSIDE blue scroll bar down, until you get to the bold -
Version E2697 heading in the left column.
M2N32-SLI Deluxe User's Manual for English Edition (E2687)
Click on the blue Global.
This is a Zip file. A Zip file is used to send large amounts of information, more easily. A Zip file is a compressed file, so it has to be uncompressed, or also said as 'unzipped'.
Opening e2697_m2n32-sli_dlx.zip
Make SURE there is a Green dot in the small circle, to the left of - Save File.
If not; left-click in the small empty circle to the left of - Save File
Now go below in this small window, and click on OK.
In the next small window go to the far left, and under the Folder Tasks heading click on -
Extract all files
e2697_m2n32-sli_dlx
,next to the red Adobe PDF icon.
[Ignore if you are aware;
The PDF file page number box is at the Top, and to the right of the Down Arrow.
Click on the Zoom In icon ( + ) to the right, to Increase the view size.
Click on the Zoom Out icon ( - ) to decrease.
The actual motherboard manual page, and the Adobe Reader page number, do NOT match. When I refer to a page number, it is for the Adobe Reader page number box, at Top ]
Go to Page 4 - 2.2.4 Motherboard layout (It is also 30 of 170)
Motherboard is shown in the position as it is, when installed in the computer case. (Photo on support page, had the motherboard turned 90 degrees to the Right)
There are charts starting on the next page (5), that detail out the connector's name, and a page number for more reference to it.
More in an added Comment.
Regards,
joecoolvette
Jan 03, 2013 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
I need help with hooking up the front panel wires from a acer veriton 460 on to a asus p5g41t-m lx plus mother board
I don't think it's gonna' fit.
Acer Veriton L460 computer Case Dimension specifications,
http://support.acer.com/acerpanam/desktop/0000/Acer/VeritonL460/VeritonL460sp2.shtml
Chassis: 2.5 inches Wide (63.55mm) x 10 inches Long (254mm) x 8 inches High (203.2mm).
Asus P5G41T-M LX motherboard is 9.6 inches LONG, (244mm), and 7.9 inches High (201mm).
http://www.asus.com/Motherboards/Intel_Socket_775/P5G41TM_LX/#specifications
However,...........
If you do not know what the Power On switch, Power On LED light, and Harddrive activity LED light wires are, then remove the Front Panel, and trace them back.
(Side Panel then Front)
http://www.asus.com/Motherboards/Intel_Socket_775/P5G41TM_LX/#download
Click on any O/S. They will all get you to the Manual download.
Click on the + sign to the left of Manual (12)
Scroll the inside blue bar down until you come to -
Version E7096 -
P5G41T-M LX User's Manual (English)
A small window will come up on the right -
Opening E7096_P5G41T-M_LX.zip
[This is a Zip file. A Zip file is used to send large amounts of information, more easily. A Zip file is a Compressed file. It needs to be uncompressed after downloading, or can be stated as 'unzipped'.
If WinZip is no good on your computer, then just download the free 7-Zip ]
Make sure there is a Green dot in the small circle, to the left of Save File.
If there is no Green dot; left-click in the small empty circle to the left, of Save File.
Now go below in the small window, and click on OK.
A small window will come up on the left.
Allow the file to fully download in this window.
Then DOUBLE-click right on the file name.
On the left side in the next window, click on - Extract all files.
At the bottom of the next three small windows, click on -
E7096_P5G41T-M LX, next to the red Adobe PDF icon.
Page 1-6 (16 of 62) shows the Motherboard Layout.
The area of contact pins on the motherboard, that the main wires from the Front panel connect to, is the Front Panel header.
Motherboard installed in computer case; Processor to Top, Ram Memory slots to the Right, white PCI slots to the Bottom;
the Front Panel header is below the bottom white PCI slot, and next to the bottom edge of the motherboard.
F_PANEL
4 pins across the Top row, (Then no pin)
1.10.2 Internal Connector section - Page 1-26 (36 of 62)
8. System panel connector (10-1 pin PANEL)
Pins aren't numbered, I'm going to number them;
Starting on the LEFT side going towards the Right; Top row,
Starting on the Left side going towards the Right; Bottom row,
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
C) Pin 9 is N/C. Not Connected. 5 Volt power reserved for the factory.
D) Pins 2 and 4 are for the Power On LED. (Light)
F) There is NO Pin 10. Just a flat spot.
The small 4-pin header immediately to the LEFT, is for an internal speaker. Used to hear BIOS Beep Codes. The computer's way of telling you something is wrong, and an area to look into for it.
The Front Panel USB header is listed, and Firewire ports. (1394a)
Regards,
joecoolvette
Nov 14, 2012 | Acer Power S290 PC Desktop
Junber j1 not connected
On an MSI 915GVM3-V motherboard, eng_m_yehia?
http://www.msi.com/product/mb/915GVM3-V.html
On the above page hover your mouse cursor on - Downloads
(Overview/Specifications/Download/Support/Where to Buy)
At the right side of the file listing, and under the sub-heading - Download, left-click right on the blue - M7223v1.0.zip
The next page wants you to click on a country nearest yours.
Me? I click on US.
A small window will come up on the right.
Opening M7223v1.0.zip
Make sure the small circle to the left of - Save File, has a green dot in it. If not left-click on the empty small circle to the left of - Save File.
Now go below in the small window, and left-click on OK.
IN the top of this window tells you where the file will download to.
Suggest you write it down.
The wording may have Desktop, or My Documents, or Downloads, in it.
(This is for Win XP. IF you have Vista, or Win 7 it is different. Post in a Comment if so)
Desktop: The file (M7223v1.0.zip) name will be on your desktop screen, and next to a yellow folder icon, with a zipper on it.
My Documents: Click on Start, then on My Documents
Downloads: Click on Start, then My Documents. DOUBLE-click on Downloads.
When you see the file name DOUBLE-click on it.
The next scenario differs;
You may have a screen that has Unzip on the right side. If so left-click on Unzip.
You may just have a screen where you go to the far left side, and left-click on Extract all files.
Left-click on Extract all files.
In the next three small windows that come up;
Click on Next, Next, and Finish.
You will now see a red Adobe PDF icon, and M7223v1.0 next to it.
DOUBLE-click right on it.
You are now looking at a PDF file version, of the motherboard manual, for an MSI 915GVM3-V motherboard.
I wanted you to have the motherboard manual for the future.
Now, Jumper J1 not connected;
Nope, don't see it.
Would this be a reference to jumper JFP1? The Front Panel header, and the 1st jumper block?
[ The plastic front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header. In this case there are two headers ]
If so I got yer back, eng_m_yehia.
JFP1 is to the right of the BIOS chipset. (Which is below the SATA 2 port, and the CMOS battery )
JFP1 is where the;
1) Power On switch connects
2) Power On LED light connects. (MAY connect to JFP2. Read on )
3) Reset switch connects. (IF, a Reset switch is used. No Reset button? No Reset switch )
4) HarDDrive activity LED light connects.
Looking at the motherboard installed in the computer;
Processor to the top, Ram Memory to the right, white PCI slots (3) at the bottom.
The JFP1 header is at the right bottom edge of the motherboard, to the right of the BIOS chipset, and is situated Vertically.
Has two columns of contact pins.
Starting at the BOTTOM Right side, going UP;
Starting at the BOTTOM Left side, going UP;
Pins 2, 4, 6, and 8. There is NO Pin 10, just a blank spot.
Pin 1 is for the Positive ( + ) wire. IF the HDD activity LED is dim, when the harddrive is operating, switch the wires around.
B) Pins 5 and 7 are for the Reset switch. IF, a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Not used. This is for the factory.
Pin 2 is for the Positive ( + ) wire. If the LED is dim when the computer is on, switch the wires around.
A note about the Power On LED light, and wires.
For a Power On LED light that has TWO wires, use JFP1.
If it has THREE wires, use JFP2.
Some Power On LED lights had/have dual colors. In the older computers it usually was Green, and Yellow.
Yellow meant you were in Normal mode, and Green meant Turbo mode.
A bunch of cr@p really. When in turbo mode, the computer was operating at it's fullest. In the other mode, it was being slowed down, below the normal output of the computer.
Regards,
joecoolvette
May 06, 2012 | MSI 915GVM3-V Motherboard
I cant. connect the pin connector in motherboard
Get the manual for your machine here: http://www.iusermanual.com/get.php?t=MSI%20PM8M-V%20Manual&url=aHR0cDovL2Rvd25sb2FkMi5tc2kuY29tL2ZpbGVzL2Rvd25sb2Fkcy9tbnVfZXhlL003MTA0djEuMC56aXA%3D
Apr 26, 2011 | MSI PM8M-V Motherboard
Kodak Z1285 Won't Turn On?
HAd exactly the same issue! You turn on the camera, lense comes out then the screen goes black (turns off)
The blue light stays on and the only way to get it to turn off is to take out the batteries.
Next time you turn on the device, the blue light comes on and the green led flashes, sometimes it powers down and other times the blue light stays on but you have no screen still. The lense stays out.
I tried the "tap" it approach and it now works fine! My suggestion has always been, if it don't work, kick it!! why didn't I try this with this camera firstly instead of trying all sorts of different button combinations to see if there was some sort of hard reset for it?
Thanks for the advice everyone and happy snapping!! :)
Jul 28, 2008 | Kodak EASYSHARE Z1285 Digital Camera
HP Photosmart M447 Digital Camera Logo
23 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
